Question about General Electric Microwave Oven
Keypad shorted on JNM1541DN1BB micowave oven. Need new keypad. where can I get one?
    Brigadier General:
  • 8,909 Answers
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Posted on Mar 21, 2011
Micowave blows the fuse when turned on
The transformer that makes hi voltage for the Magnetron tube is causing the fuse to blow. This may be a bad Magnetron tube or a shorted winding in the transformer. Price for the repair may be too close to the price for a new oven, so check with a repair center before deciding to replace it.
Aug 08, 2015 | Sharp Microwave Ovens
Numeric keypad doesn't work on my microwave oven
if it got wet from cleaning just wait if its real old its more than not wore 0out
Mar 31, 2013 | LG Microwave Ovens
I have a GE JVM2070SH001 micowave . I do not have power to the under unit lights (work,nitelight) but everything else works fine. What is the likely problem?
Either the control board or the switch itself. I can't remember if that on is part of the main keypad or not. Does the unit beep when you press the light button? If it does then you need to follow the wiring to a point where you have power. Best guess...control board
Dec 05, 2012 | GE Profile Spacemaker Over-the-Range...
Rest all works,but not heating micowave xl1800
When the microwave does not heat the food, it means that the magnetron circuit has failed. It the part that generates the microwaves that heat the food. Often the part fails by shorting out causing a loud buzzing sound when you try to microwave something. The replacement part usually costs almost as much as a new oven, so it rarely cost effective to replace. Sorry.
Jan 18, 2011 | GE JVM1850 1000 Watts Microwave Oven
5E (SE) error showing on my samsung C106FL micowave oven (2 years old). None of the other keypad buttons are working. I unplugged the oven & re-plugged next morning but still saem result. Pls help.
The "SE" error indicates a shorted membrane keypad.
You can find support from Samsung in India here.
Dec 18, 2010 | Samsung MC5694 Microwave Oven
GE micowave, keypad will not work
GET THE OVEN NUMBER AND SEE HOW MUCH THE TOUCH PAD COST, SOME TIMES THE TOUCH PAD COSTS AS MUCH AS MICRWAVE OVENS NOW DAYS
Aug 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My emerson micowave mw8119sb blow the fuse, I replace with a new one same rating, it turns on but when I put something for heat it blew the fuse again. Any help! Thanks!!!
Could be a short in the HV system for the magnetron--usually the HV diode. Another possibility is the metal stirrer fan in the waveguide above the oven cavity may have a shorted bearing (plastic). The short occurs internally within the bearing.
Aug 01, 2009 | Microwave Ovens
Micowave is not heating up, and is making a
It may be a shorted diode in the HV power supply for the magnetron. Open the case to get to the part. Unplug the machine before opening anything. This is normally a high voltage area when running.
Jul 17, 2009 | Microwave Ovens
Kenmore micowave
IF IT IS THE KEYPAD THAT IS LOCKED, ONE OF THE TOUCH PADS SHOULD BE HELD FOR 5 SECONDS TO UNLOCK THE
TOUCH CONTROL.YOUR INSRTUCTION MANUAL WILL TELL
YOU WHICH PAD TO HOLD. IF NOT AVAILABLE, TRY EACH PAD, ONE AT A TIME. HOLD EACH PAD FOR 5 SECONDS.
IF NO RESPONSE, TRY THE NEXT ONE. WHEN YOU FIND THE ONE THAT UNLOCKS THE CONTROL, WRITE IT DOWN
FOR FUTURE REFERENCE. THAT PAD WILL ALSO LOCK THE CONTROL WHEN HELD FOR 5 SECONDS.
Mar 28, 2008 | Microwave Ovens
General Electric Microwave Oven Logo
406 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
