Question about Sharp AF-S120FX Air Conditioner
The styrofoam in the a/c duct seems to be affixed. Is this part of the unit or should it be taken out?
    Brigadier General:
  • 4,736 Answers
If it's in front of the air ducts at the top of the unit, Yes! Be sure what you're seeing is not the filter. If all else fails, consult your Owners Manual.
Posted on Mar 21, 2011
Possible remnant foam left in vent from manufacturing process
This needs to be taken out if not it will affect your system. Never cover up the vents on a unit hard on compressor.
Jun 24, 2010 | Heating & Cooling
Styrofoam insert for Peg Perego Infant Car seat
Hi, I figured I would post the outcome since I was searching for resolutions. I called Peg Perego. The piece that is cracked on my Peg Perego Primo Viaggio SIP Infant Car Seat is the top of the center section of the headrest. The representative said it can be replaced with a new headrest piece for $32.99 (including shipping). The new piece does not have stryofoam though. It's just a heavier material (almost pillow-like). The representative that I spoke to, however, said that if the styrofoam was a clean break (meaning not in a whole bunch of pieces) it's still safe to keep it together under the cover and use the car seat as normal. Apparently, that's not what's really protecting the baby anyway. To be honest, I don't even think that I broke the styrofoam while taking the cover off, I think it was broken beforehand probably by just use and the weight of the baby. I will get some styrofoam glue and duct tape and just secure it, and put my sparkly clean cover back over top of it. I think it's fine for use. Thanks and good luck to others with this issue out there!
Oct 23, 2009 | Peg Perego Primo Viaggio Verde Infant Car...
I WAS TOLD THE COOLANT FANS ARE INOPERABLE AND THAT THEY NEED TO BE REPLACED ISNT THERE A RELAY ORE SOMETHING THE FANS WORK AT HIGH SPEED.
There should be a relay that provides power supply for the fans.
If the fans only work on high speed, the fans are not faulty.
The most likely cause is a faulty fan speed control resistor module.
The resistor module is usually located in the blower fan ducting, in the fan air flow. It is typically a plugin unit, affixed to the ducting with a couple of screws.
Oct 22, 2009 | 2001 Volkswagen Beetle
Duct size
THREE TON CAN GET BY ON A 12 RETURN AND A 12 SUPPLY SPLIT INTO TWO 10S ONE FOR EACH SIDE OF A DOUBLE WIDE. EVEN BETTER IS A 14 RETURN AND A 14 SUPPY SPLIT TO TWO 12S . IF ITS A SINGLE WIDE I THINK I'D TRY TO PULL TWO 14S ONE TO SUPPLY ONE TO RETURN.BIGGER THE RETURN THE BETTER. LIKE SUCKING A MILKSHAKE THROUGH A LITTTLE STRAW. BIGGER IS BETTER.BE SURE TO ELEVATE OR BLOCK UP THE DUCT OFF THE GROUND WITH STYROFOAM BLOCKING 6 IN THICK IN 2 FT LENGHTS , WORKS WELL GETS DUCT UP OUT OF DIRT AND WATER AND RODENTS CAN CRAWL UNDER.
Jul 04, 2008 | Intertherm P3RA-036K Air Conditioner
Styrofoam inside of my Haier HWF05XC7
It should remain there it is the insulation seperating the condensing side from the evaporating side you may nve to reach in and move it around to prevent the destruction of the foam.
Jun 22, 2008 | Haier Mechanical Air Conditioner HWF05XC7
I makes a very loud noise
Had same problem with Ge AC. Unplug take out of window and remove all cover screws. Pull up on cover and pull cover off ac, Remove front cover as well there are a couple screws in the front. When looking at front of ac, hit the Styrofoam housing towards your left (towards control panel). Spin fan blade to make sure that it is clear. Plug in to double check. I put a couple quarters between the styrofoam and the metal housing, so it would not slide back. Also tape the styrofoam between the seams this helps with better cooling. Use some good tape nothing cheap. I used black duck tape. It took about 20 mins. The hardest part is re installing the AC.
Jun 02, 2008 | Heating & Cooling
Styrofoam inside
you may open and remove foam not included in unit , be sure return make align everything.
Jan 01, 2008 | Kenmore 335 CADR Air Purifier
Sharp AF-S120FX Air Conditioner Logo
67 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
