Question about Microsoft Xbox 360 Console
My xbox takes ages to come and load games, and when i press the centre button on the pad in the game and at the xbox main menu the console freezes
    Problem Solver:
  • 16 Answers
Your console may be overheating, or you may have a problem with your hard drive or disk reader.
Try turning off the console and waiting for it to cool down.
Posted on Mar 21, 2011
How to Livestream Minecraft for Xbox?
    -Open Minecraft game from games and app menu
    -Tap centre button on xbox controller twice
    -Select snap an app-Do this by pressing up on the D pad of your controller
    -Select Twitch-scroll through apps until you find Twitch, once you find it, press A button
    -Choose broadcast-when you find it hit a
    -Name broadcast, go down to text field and hit a button.
    -Begin broadcasting-scroll down to bottom of twitch screen and hit a on "start broadcasting". Tap centre button on Xbox controller one more time.
Oct 20, 2016 | Video Game Consoles & Games
My x box wont read any discs
Greetings,
Please go through the Website link mentioned below.
http://support.microsoft.com/kb/816779
Note 1 If a saved game file is corrupted, it can produce a disc error message in that game, particularly when the game starts. You can resolve this issue by deleting all saved game files for the affected game from the Xbox hard disk. This method is effective approximately twenty-five percent of the time. If you experience this disc error message with more than two games, this procedure will likely not resolve the issue.
Note 2 Do not use laser lens cleaners, or similar products. Microsoft has not determined the effectiveness of these products or the affect they may have on the Xbox system. Microsoft cannot promote or recommend any type of laser lens cleaner for use with the Xbox system.
1. Clean the disc and examine the disc for flaws or scratches
Hold disc by the edges without touching the surface with your fingers.
2. Clean the disc with a soft, clean cloth, lightly wiping from the center outwards.
3. Do not use solvents or chemicals to clean the disc.
4. After you clean the disc, examine the disc for any scratches or defects. If you find any defects that are not caused by typical wear and tear, return the disc to the retailer if it still under warranty.
Copy and delete any saved games from your hard disk
Note To copy saved games, you must have an Xbox Memory Unit (MU). You must copy saved games to a MU before you delete them.
1. Start your Xbox console with no disc in the disc tray. The Xbox Dashboard appears.
2. On the Main Menu screen, press the directional pad (D-pad) up or down to select Memory, and then press the A button.
3. On the Memory screen, press the D-pad up or down to select Xbox Hard Disk, and then press the A button.
4. On the Xbox Hard Disk screen, press the D-pad up or down to select the game title you want, and then press the D-pad left or right to select the saved game you want to copy.
5. On the Copy/Delete screen, press the D-pad up or down to select Copy, and then press the A button.
6. On the Copy To screen, press the D-pad up or down to select the memory unit you want to copy to, and then press the A button.
7.Press the B button to return to the games list on the Xbox Hard Disk screen.
8. On the Xbox Hard Disk screen, press the D-pad up or down to select the game title you just copied a saved game from, and then press the A button.
9. On the Copy/Delete screen, press the D-pad up or down to select Delete, and then press the A button. You receive the following message:
Are you sure you want to permanently delete this saved game?
10. Press the D-pad left or right to select Yes.
11. Repeat these steps for each saved game on the Xbox hard disk. If you have many saved games but you can remember when you started to receive the disc error message, you can just delete the saved game files that you created after that time.
Back to the top
Please let me know if you have any issues.
Regards,
Feb 11, 2010 | Microsoft Xbox 360 Console
Any game i play disk arcade or demos xbox freezes
Try the following:
  1. Hold disc by the edges without touching the surface with your fingers. Clean the disc with a soft cloth, lightly wiping from the center outwards. Do not use solvents or chemicals to clean the disc. Examine the disc for any visible signs of damage.
  2. Verify whether the Xbox console clock is set correctly.
    • Turn on the Xbox console without a disc in the drive.
    • Press the directional pad up or down to select Main Menu, and then press A.
    • Press the directional pad up or down to select Settings, and then press A.
    • Press the directional pad up or down to select Clock, and then press A.
    You can see the date and time from this screen. Correct the date and time as neccessary.
  3. Try to play the game again. If this does not work, you can try to clear the game cache on the Xbox hard disk. If you have a Xbox Memory Unit available, copy the game cache for this game from the Xbox hard disk to a memory unit:
    1. Insert a memory unit into a controller connected to your Xbox console.
    2. Open the disc tray and remove any disc, if present.
    3. Close the disc tray and re-start your Xbox console.
    4. Select Memory from the main Xbox Dashboard, and then press the A button.
    5. Select Xbox Hard Disk, and then press the A button.
    6. Locate and select the game you want to back up in the list of games.
    7. Select the appropriate save game icon. The Save game icons are located to the right of the game icon. Each save game is identified with a name, date, time, and size.
    8. Press the A button to display the Copy/Delete menu for the save game.
      Note: If Copy is not available, you have not chosen a save game file.
    9. Select Save, and then press the A button.
    10. Press the A button again to save to the appropriate memory unit.
    11. As soon as the copy is complete, press the B button to return to the list of save games.
    12. Repeat these steps as needed to back up your other saved games for this game.
    If you do not have a memory unit, deleting the game cache removes your progress in the game, high scores, and other information. To find the game cache, follow these steps:
    1. Open the disc tray and remove the any disk, if present.
    2. Close the disc tray and re-start your Xbox console.
    3. Select the Memory option from the Dashboard.
    4. Select the Xbox Hard Disk.
    5. Locate and select the game in the list of games.
  4. Select the large game icon to the left of the list and press the A button.
  5. Press the Abutton again to delete the game cache file.
    Note: Delete should be the only available option. If Copy is available, you have chosen a game save file and not the game cache file. Press the B button to return to the list, and then select the leftmost icon.
  6. Select Yes to permanently delete the game cache, and then press the A button.
  7. Confirm that the icon is no longer listed, and then re-start your Xbox console.
  8. Insert the game disc, and then either load your latest saved game from the memory unit, or play the game from the beginning.
Sep 19, 2009 | Microsoft Xbox 360 Console
Triangle button on psp
you need to open your psp and clean or replace they d-pad
Jun 02, 2009 | Sony PlayStation Portable (PSP) Console
Freezing & disc errors
hi, you need to update it to its latest firmware do this from xbox live
May 04, 2009 | Microsoft Xbox 360 Console
Ps 3 freezes when ps button is pressed
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up
Mar 26, 2009 | Sony Playstation 3 (PS3) Console
My son did something when he was playing the xbox and now its not in english and he cant play it.can you help me put it back in english please
  2. On the Main Menu screen, press the directional pad (D-pad) down two times to select Settings, and then press the A button.
  3. On the Settings screen, press the D-pad down one time to select Language, and then press the A button.
  4. On the Language screen, press the D-pad up or down to select the language you want, and then press the A button.
  5. Press the B button to return to the Main Menu screen.
Jan 31, 2009 | Microsoft Xbox Console
Not english
Note If the current language setting of the Dashboard is in a language other than English, the following steps will still work but you may not be able to read the menu options. If this is the case, you must follow the directional pad instructions exactly to make sure that you select the correct option.
Jan 17, 2009 | Microsoft Xbox Console
Console freezes
hey there, I would open the Xbox 360 dashboard, then go to memory, and press Y on the hard drive to open the "Device Options" menu. Then press the following sequence of buttons: X, X, LB, RB, X, X. You will be asked if you want to perform maintenance on your hard drive and delete all patches.select yes I hope this helps
Dec 07, 2008 | Microsoft Xbox 360 Console
Resetting the language on an Xbox
1. Start your Xbox console with no disc in the disc tray. The Xbox Dashboard appears. 2. On the Main Menu screen, press the directional pad (D-pad) down two times to select Settings, and then press the A button. 3. On the Settings screen, press the D-pad down one time to select Language, and then press the A button. 4. On the Language screen, press the D-pad up or down to select the language you want, and then press the A button. 5. Press the B button to return to the Main Menu screen.
Rate if this helps :)
Nov 05, 2008 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
27 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
