Question about McCulloch FG6000MK 5700Watt 13 HP 338CC Portable Generator
Model 338 chain saw, chain too tight needs to be loosened off
  • 710 Answers
There is a hole in the brake/clutch cover (that you take off when you change your chain) under the attachment bolts through which a bolt protrudes. Use a small screw driver or the wrench that comes with the saw to turn this bolt (it has a slot in it) to either tighten or loosen the chain.
Hope that helps.
Handie Andie
Posted on Mar 22, 2011
New saw.2025,bought new and they put chain on backwards and will not cut.runs great but having problem loosening pinwheel chain adjustment.flip up lever but cannot loosen it.too tight
If you can't even loosen it to get the chain off and put it back on properly take it back to the people who put the chain on backwards. That is absolutely ridiculous that a dealer puts a chain on backwards...they probably just tightened it too much...use a bigger screwdriver as to not strip the screw. It should never be that tight...they may even have the wrong size chain on it, check the chain package too , make sure its the right one for your bar......Take it back, If they can't loosen it easier and in a reasonable amount of time or you see them forcing it, demand a new saw. Seriously.
Apr 26, 2017 | Garden
How do I put back the chain on the saw?
clean all the debris along the side of the bar where it goes into the saw and you will see a screw this tightens and loosens the chain, but you will first have to loosen the one or two nuts that hold the bracket [plate] that holds the bar tight.
Sep 20, 2014 | Poulan Garden
I have started my McCulloch 338 chainsaw without any problem, but the chain will not move on the chainguide, when throttled up. I have tried to move the chain by hand ( after stopping the machine !!!) but...
The chain may have come off the sprocket.
There are 2 nuts about an inch apart down just past the bar which hold it in place.
Remove the 2 nuts, take off the cover which they hold in place and the bar and chain will loosen.
Check that the teeth on the inside of the chain are on the sprocket. Pull the chain tight against the sprocket and move it. Check that the sprocket turns. With the chain set in the sprocket replace the bar, chain and cover and try turning it again by hand. If it doesn't turn don't try to start the saw as you'll do damage.
If the chain was on properly and it still won't turn the clutch may be burned out. However the fact that you couldn't turn it by hand suggests that the chain was off the sprocket.
Dec 19, 2010 | Garden
When using the saw, the chain doesn't stay tight on the bar.
Should be a nut on the side of chainsaw that covers the chain, sometimes all that is needed is to loosen nut them pull outwards on chain bar and retighten nut. Chain should have some play in it so dont make the chain hug the bar tightly. There is also an adjustment screw next to the bar that will tighten and loosen the chain but is used for small adjustments only.
Sep 07, 2010 | Remington 111409 - 01 6" Branch Wizard...
Chain fell off poll, trying to figure out how to put it back on.
On the side of the saw where the bar (what the chain goes around/rides on) where it connects to the saw there are a couple nuts. Loosen them up, push the bar back towards the saw to put slack in the chain, wrap the chair around the bar making sure the bottom of the chain is in the groove on the bar and tip of the bar, then push the bar forwards away from the saw to take out the slack in the chain. Hold it tight and tighten up the two nuts. Depending on your model of pole saw, you may have only one nut and a plastic guide that keeps it straight. Same concept though. Loosen the nut, push bar in, put chain on, pull bar out, tighten nut.
If you've ever done it on a bicycle, it's the same concept. Loosen nuts on back wheel, push tire forwards and chain gets loose. Pull it backwards and chain gets tight.
May 11, 2010 | Remington Polesaw Wizard
How tight should my chain be? elect. model.
you should be able to pull the chain down from the bottom of the bar, and it should snap up with no space between the bar and chain. If you use it and it loosens up, you can tighten it, but always remember to loosen it again as soon as you're done, or it can damage the saw.
Apr 13, 2010 | Garden
Chain replacement.
Input "M12510US" in the model number here (if not your saw the procedure should be similar):
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
See pages 7 through 9, for use as a guide.
HTH
Lou
Are you aware RemingtonPower is no longer in production? Replacement parts are becoming difficult to find.
Jan 23, 2010 | Remington Electric Chain Saw
Need service manual for Homelite 16'' electric chain saw model UT 41320. Motor runs but chain stopped in middle of second cut.
chain is too tight on the bar or is lacking lubrication oil. loosen up the bar nuts and back off the chain tensioning screw a touch. make sure the bar oil reservoir is full and the chain is receiving oil when its running.
Oct 20, 2009 | Homelite Garden
The chain popped off and I can't get it to fit back on.
Losen the bar mounting nut, then losen the chain tension adjustment screw until the chain can be reinstalled, then tighten the tension screw until the chain just sags 1/8" or so at the center of the bar then retighten the bar mounting nut.
Sep 10, 2009 | Remington 16" Electric Chain Saw
Ryobi 540A need manual runs slow/ chain too tight?
Actually, I own one of these battery operated Ryobi chain saws too. It is normal for the saw to run slow. Remember it is battery powered, not gas, so its not going to be a high rpm saw. Be patient whit it, and you'll get about 4-6 cuts per battery. I take mine camping. It sure is nice not having to listen to a two-stroke while relaxing in the woods! Dont plan on cutting lots of stuff, either, or you'll burn up the motor. This thing works great for very mild workloads.
Aug 14, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
McCulloch FG6000MK 5700Watt 13 HP 338CC Portable Generator Logo
37 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Mike
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
