Question about LG LFX23961ST Stainless Steel Bottom Freezer French Door Refrigerator
I have an ER 1F. I had this problem and took 6 months with LG to fix it. When they couldn't fix it they gave me my money back and said keep the frig. So I bought another and this sits in my garage. I now want to use it out there as a second unit. So 1) can it still be used with out the ice maker and/or in door water. 2) if so can I use the water only. 3) if so can How do I get rid of the error and set the temps. ? Thanks sabanim@aol.com
  • 1,543 Answers
1. yes. Open ice room door (back side of left hand refrig door) and turn toggle switch on icemaker to OFF. 2. yes. Do step 1 and connect water to refrig. 3. ER IF (Error Ice room Fan) may still come up. If it does and you don't like it, you could probably avoid that by removing the fan blade from the ice room fan, located in the freezer section, behind the back wall, upper left hand corner. The error code pops up when the electronic board does not see a feedback signal from the ice room fan. Removing the fan blade should allow the motor to run, thus sending the feedback signal to the board, preventing the code from appearing.
Posted on Mar 21, 2011
What does Er 1F mean on the ice maker display
LG Refrigerator Error Code Er 1F or Er IF
The ice maker fan is not working properly. Try defrosting the freezer first before trying to replace anything.
Jun 29, 2017 | Refrigerators
LG Ref/Frzr LFX 31925st ERROR CODE ER 1F NEED MEANING AND FIX
A F1 or 1F error code on the refrigerator's display indicates a problem with ice blower fan or ice maker motor.
search LG error 1f and u will find lots of info
Dec 09, 2016 | LG Refrigerators
LG Lfx31945ST . No ice and error ER 1F. About 6 weeks ago frost started to appear on the freezer drawer. Tried unplugging it for 4 hours and turning it back on but still getting error within a few...
probably heating element in freezer is broken.
Remove power and defrost. Remove wall panels in back of freezer to Check heater element behind panels With ohm meter should read 20 ohms or less. You could remove it and bring it to a local repair shop and have them test it and if required order you a new one. If this does not work it may be the control board
Oct 20, 2013 | LG LRBC22544 Bottom Freezer Refrigerator
The code er-1f displays on my control panel
the codes are listed back of your ref.and what they mean
Feb 08, 2010 | LG LFX25960ST Stainless Steel French Door...
ER 1F
It is ER IF and indicates that the ice maker fan is not working. The fan is probably frozen. If you can remove the fan duct and housing at the back of the freezer you may be able to defrost the ice in the fan enclosure. The fan may have frozen because of hight humidity or because the defrost cycle is not working.
Sep 08, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
LG refrigerator lrsc26944tt error code ER FF
I'm no major appliance repairman. However, after reading several posts, I investigated the issue further since I received an ER FF on the front panel. I have a LFX25960SW refrigerator. I pulled the top and bottom baskets out, and was able to take the back panel out from inside. There was a solid block of ice built up around both fans and wires. I took a blow dryer and gradually melted the ice around the fans and wires. Then, as I was able, I pulled the remaining ice chunks off of the wires. I put the thing back together and it cleared the message. My wife says no more LG appliances for us. :)
DAS
Jan 25, 2009 | LG LRSC26944TT 36" 25.5 Cu. Ft....
LG Refrig LFX25960SB
The service manual with the codes is available at:
LG LFX25960 Service Manual
"ER IF" show a problem with the ice maker fan motor.
Nov 06, 2008 | LG LFX25960 Bottom Freezer French Door...
LG Model LFX25960 has error code ER 1F
Turn off the switch for the icemaker, then flip the circuit breaker to off for a few seconds and turn it back on. The display should remain lit and operable, but you won't have an icemaker. See service manual pg. 32: http://136.166.4.200/contents/Fridge/LFX25960/LFX25960_Service_Manual.pdf
LG=JUNK!
Jun 14, 2008 | LG LRFC25750 Refrigerator French Door
LG LFX23961ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
610 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
