Question about Nintendo Wii Console
I have a WII and the screen keeps rolling. It's frustrating. I have a 10 year old TV and this didn't do it before. Any suggestions?
    Guru:
  • 592 Answers
Try a different channel or cable. If you are using a RCA to coaxial converter then check the coaxial wire from the converter to tv. Need to know more about the setup.
Posted on Mar 21, 2011
After connecting the Wii to LG TV (55 inch LD520C) the LG TV will not stay on! it blinks an image 3 times (maybe 10 seconds total), then turns OFF!! we disconnected the Wii, but the LG TV still turn
How old is the TV? LG warranties its TV's for 1 year unless you have a extended warranty from where you got it which is stupid not to have. Was the TV exposed to moisture or bugs? I've never heard of a Wii corrupting a TV. If no warranty then it could be a power supply or the main board. Find a repair service that gives free estimates, find out what needs to be fixed then go online and find the replacement part-Ebay.com and www.shopjimmy.com are good sources for parts. Replacing parts is easy, a screwdriver for screws and unplug cables by hand. If it's a power supply wait 1 hour before removing because the capacitors can still hold a charge and to be safe hold it by the edges of the board and put it on a non conductive surface like glass. If it's the Main board just switch it butsometimes after LG and Samsung main boards are replaced Solarization can happen. If it does just google it and you will find a easy fix. Good Luck
Feb 25, 2014 | LG 42LC2D 42 in. LCD HDTV
Tv blinks a black screen off and on, and also getting a green line at top and bottom at times any suggestions? 10 years old
I have same problem, over 10 years old, only started when turned on, but does it @ anytime now . any solutions ? and this thing does weigh a ton. never had a problem ever, great tv, great picture, etc., anytime a function is initiated screen blinks on off at will, stays on for the most part, no other problem, but can this be repaired or is it time to buy a new tv ?
Oct 17, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
We have Toshiba 42" Plasma TV about 4 yrs old. The past couple of weeks we've noticed that there is a horizontal rolling band of pinkish color (about 8-10" band.) We really notice it when there are people...
Im pretty sure its not the television. You are getting interference from either through your cable box or your electric in the house. Possible bad dimmer switch.
Dec 14, 2009 | Toshiba 50HP66 50 in. Plasma Television
Changed resolution and Wii will not stop rolling on screen. I have a lcd tv 101cm, will work okay on old 68cm tv.
For best results use the component cable for LCD TV.Make sure the screen is 16:9.Go on Wii menu and check the vertical frequency.If it 50Hz make it 60Hz or back.
Oct 08, 2009 | Nintendo Wii Console
Toshiba 40H80 Rear Projection TV Picture Rolling/Scrolling
problem is bad hyper module or can have tech repair it with capacitors
Feb 05, 2009 | Toshiba 40H80 40" Rear Projection...
Television Locked screen
I had the same problem on my TV (Nontaus N5119A). As suggested above, I switched the TV, pressed and held the 'Display' button for about 10 seconds and TV unlocked.
Thanks a lot for posting the solution. Much appreciated.
Aug 10, 2008 | Televison & Video
Vertical rolling on Hitachi 60SBX78B
It ended up being the Verizon Fios box. We recycled it and the picture stopped rolling. Thank you for being here to help. If I have any future questions, I'll definitely use your site.
Mar 07, 2008 | Hitachi 60SBX78B 60" Rear Projection...
TV screen jumps and rolls, sometimes won't stay on
Try Re-soldering the vertical yoke connection and the vertical output IC. Thats a common problem in that model.
Feb 26, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Toshiba 36zp38b picture problems
With it only being about 3 years old, I would suspect bad solder connections rather than defective components like Capacitors. You may get the symptoms to come and go by slapping the side of the set or jaring it slightly which would prove the bad connection thesis. It is not a permanent cure however and you can make it worse if you keep doing that. A solder repair shouldn't run over $225 in my opinion.
Mar 11, 2007 | Toshiba 36AF61 36" TV
Nintendo Wii Console Logo
211 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
