Question about Sharp AF-R120FX 12,000 BTU Comfort Touch Air Conditioner
Are you suppose to remove the styrofoam in the air conditioner where the air comes out?
  • Cindy Stuart Jun 30, 2013
    Why doesn't it say to remove the styrofoam in the instruction manual? If you take the styrofoam out, then you can see outside. HELP!!!
    Brigadier General:
  • 4,736 Answers
YES, definitely or the air won't come out.
Posted on Mar 21, 2011
Its suppose to have some styro foam inside? or its suppose to be out?
Most window A/C units have styrofoam lining the air vent. Unless the manual says to remove a piece of foam when unpacking the unit, leave it there.
Jul 30, 2012 | Kenmore Model 253.70181 Window Air...
Just installed air conditioner. The water is building up in the bottom and getting flung around in the back. Is there supposed to be a drain? I have it slanted at least 3/16 inches. HELP!!!!
I don't think 3/16" is enough. 1/2" would be better. That way the water will flow to the "drain hole" near the rear of the drip pan. Also, if you just purchased and installed it, turn the unit OFF and unplug it. Remove the front and check for any Styrofoam material that may have been left inside for shipping purposes.
Hope this helped you, Jean. Thanks for choosing FixYa.
Aug 18, 2011 | Heating & Cooling
Possible remnant foam left in vent from manufacturing process
This needs to be taken out if not it will affect your system. Never cover up the vents on a unit hard on compressor.
Jun 24, 2010 | Heating & Cooling
Need to access inside of Carrier air conditioner.
After removing the cover and filter, you should be able to see the fins for cleaning. If there is styrofoam in front of the coil, it should not be there for proper operation.
Aug 20, 2009 | Carrier 52FE312-3 Air Conditioner
Is there supposed to be Styro Foam inside the ESA3089 AC unit?
I believe that the styrofoam is installed in the unit for shipping purposes. This is to prevent damage to the unit while in transit. Simply remove the foam and everything should work fine.
Hope this helps,
Jeff
Jul 03, 2009 | Haier hwr10xc6 Air Conditioner
Need info on styrofoam shroud behind fan .do i remove it?supposed to be there?
Yes it is supposed to be removed that piece is just for shipping. Good thing you asked. ken
May 01, 2009 | LG Goldstar GWHD5000 wall/window Air...
Styrofoam inside of my Haier HWF05XC7
It should remain there it is the insulation seperating the condensing side from the evaporating side you may nve to reach in and move it around to prevent the destruction of the foam.
Jun 22, 2008 | Haier Mechanical Air Conditioner HWF05XC7
Styrofoam inside
you may open and remove foam not included in unit , be sure return make align everything.
Jan 01, 2008 | Kenmore 335 CADR Air Purifier
Sharp AF-R120FX 12,000 BTU Comfort Touch Air Conditioner Logo
139 people viewed this question
Top Sharp Heating & Cooling Experts
Oloyede Monsuru
AJMAL KHAN
Tim Whalen
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
