Blomberg 1301 ABB Not spinning the water out after wash. Drum rotates but does not go onto high speed
the dr
  • 447 Answers
SOURCE: grinding noise when drum rotates
may be a foreign object trapped in between the inner and outer tub. Major Disassembly required to split the outer tub. May also be the rear bearing in which case back half will have to be replaced.
Posted on Oct 04, 2007
TAGTEL
  • 16 Answers
SOURCE: blomberg washing machine
If you open the door and spin the drum by hand it should sound perfectly quiet and feel perfectly smooth. If it is not and it sounds "like a jet taking off" as some people describe it - that would probably be your bearings.
If the sound is a loud rattling sound - then something is probably loose ( usually top or bottom weights )
It would help if you could describe the noise as best you can!
Posted on Mar 16, 2008
SOURCE: Siemens Wash & Dry 6140 (Front loader Washer drier)
SUCCESS !!!! - WOT A RESULT.! - SO PLEASED I HAD A GO.
Dry joint found on PCB was BLACK & MELTED, specifically one on the relay terminals was not connecting to the pcb track anymore ;looked like poor original solder joint.
GOT THE OLD SOLDERING IRON OUT, FLUX PEN AND SOLDER AND VOILA!!!
SAVED £280+ (SIEMENS QUOTE: NEW PCB £200 PLUS LABOUR £40/HR)
Posted on Apr 26, 2008
grandadfixer
  • 99 Answers
SOURCE: washing machine wfm 2010 not rotate just fill and drain water
sounds like the carbon brushes in motor,Or motor has had it.
Posted on Oct 11, 2008
aborcass
  • 2651 Answers
SOURCE: Rattling noise during high speed spin
sounds as if you might have a bad rear bearing, real obnoxious almost painful to listen too kinda sounds. big job, but might have some part warrentee depending on age of unit
Posted on Oct 21, 2008
My maytag washer does not spin fast enough to get the water out of the clothes. Please advise
Randall, the high speed spin failure can be caused by a number of issues. I would suggest starting the machine without any clothes in it. Once it has filled, make sure the door lock light is on and that the door is, in fact, locked. If the light is not on, or if the door is not actually locked, either the door lock assembly or the control panel is at fault.
If the light is on and the door is locked, stop the wash cycle and start a drain and spin cycle to see if all of the water is pumped out of the drum. All water should be pumped out within 10-15 seconds. If excess water is in the drum, the high speed spin will not start.
Mar 06, 2015 | Maytag Washing Machines
Spin not working at end of wash cycle
if there is no rotation you need to check the water level inside the drum if the level is high the spin can not start before emptying the drum
Nov 06, 2011 | Zanussi Washing Machines
The water is not spinning out. the water is pouring out onto the floor when the spin cycle starts. not leaking when in wash cycle
You may have a pump that's bad. When it goes into spin cycle it assumes the water will be drained within a period of time before it goes into high speed spin. If it goes into high speed spin and the pump hasn't done it's job then you will get a bad mess, flood, water all over.
Rich
Western Appliance Repair
Appliance Repair Meridian
Oct 09, 2010 | Kenmore 9380x Top Load Stacked Washer /...
LG Tromm WM2277HW during high speed spin makes noise
I had exactly the same symptom...grinding noise only during high speed spin cycle.
I took the top and back panels off to see how the drain hoses etc. connected. Not wanting to take it apart further, I eventually just took the washing machine outside (I knew I was going to be dealing with water!), pulled the debris catcher front side bottom, and let rip with a garden hose inside the drum with the catcher out (leaving an open drain that could flow unimpeded).
Water flowed quickly out of the open drain, and lo and behold, a small drill bit came out with the water flow. This bit, presumably had gotten through the drum grating, and was resting on the bottom of the housing, scraping and grinding when the drum was spinning.
Aug 16, 2009 | LG Washing Machines
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
