Where do i find thr AV setting on my tv set? - Televison & Video
  • Televison & ... Master
  • 5,481 Answers
If you mean changing the input source to AV, it depends on the brand and model. Some units have an Input or Source button on the front panel (or side panel) of the TV and on the original remote. Other models only have this button on the remote.
If you are interested in a replacement remote for a unit that only has the Input button on the remote, try a searching for the model on remotes.com . Alternatively, look for a universal remote that is newer than the TV with an Input or Source button. Then try all the codes for the brand until you find the one that makes all of the features of the remote work.
If you are interested in the signal information (resolution, for example) of the content on the AV source, try the Info button on the remote (if available). To adjust the setting enter the Menu (either from the button on the remote or the TV panel (if available) and look for the Picture submenu.
I hope this helps. If you provide the make and model of the TV, I may be able to provide more information.
Posted on Mar 21, 2011
Jvc hd 52g787 my position adjustment in my menu will not highlight so i can adjust picture over to the left. help please
Hello
Just make the picture status button on the remote control and get the display setting to its factory mode.
The VIDEO STATUS button gives you a choice of three TV picture display settings, including a
display of your own preferences.
Standard - Resets the picture display to the factory settings.
Dynamic - Heightens contrast.
Theater - Gives a rich, film-like look to video. (AV-27D303, AV-27D203 and AV-20D303 only)
Sports - When you watch a sports program. (AV-27330, AV-27320 and AV-27S33 only)
Press the VIDEO STATUS button repetedly to get these choices.
Aug 13, 2011 | JVC AV-27750 27" TV
I can not figure out how to put my Toshiba M454 to Line 1 to play my Gamecube.
  1. Run your AV cords from your Game Cube to your VCR input in the back.
  2. Now run the AV inputs from the VCR (outputs) to your TV (inputs)
  3. Now you press "input" on the remote on your VCR to make the VCR play your input thr Game Cube is hooked up to.
  4. Now you set your TV to what ever input you hooked your AV cable from your VCR to.
  5. Turn the Game Cube on and play.
Regards, Tony
May 04, 2011 | Toshiba M454 VCR
Will not work with any of my television sets. Is there a special cable I need to purchase>
Have you tried changing the av settings on the tv? It wasn't working with my tv because I had plugged the av cords into the side of my tv but didn't change the av setting to read it. The av outlets on the back of the computer were linked to channel 4, but the side ones were linked with av1 or av2.
Apr 06, 2010 | LeapFrog Clickstart My First Computer
High pitch sound after the TV warms up on my JVC 32" TV
    According to the symptom the problem is in memory IC also called EPROM, Replace the EPROM with data and your TV work fine again.
    Thanks.
Jan 09, 2010 | JVC AV-32D305 32" TV
What camera setting is required to show photos on TV. I have the video cable connected.
Set camera in playback mode, connect AV cord in camera and hook it to AV-in of TV and select that AV input with TV remote to view camera picture in TV as its being shown in camera LCD.
Sep 19, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Can I set the default input?
some tv model has a setting that every time you switch on the tv the set will back on the last customer setting, other tv does not support this setting. But if your tv works as i mentioned earlier during the first time you buy it. Meaning the IC memory is malfuntion.
Jun 14, 2009 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
Xbox 360 Console, Faulty, NO DISPLAY!!??
What do you mean, no display? Is is game-related display issues? Have you checked the AV cable connection? Or is it about the settings? Is this the first time that you are going to connect your xbox console?
To determine whether the display issues are specific to a particular game, try playing a different game to see whether the same symptom occurs. Reminder, some Xbox original games that were released for the original Xbox console may show some display issues when you play them on the Xbox 360 console.
Next, make sure that AV cable is connected correctly to the Xbox 360 console and to the TV. To verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, you can disconnect the AV cable and then reconnect the AV cable to both devices. Note: If you are using composite cables, do not try to set any HDTV settings. If you try to set HDTV settings, you may lose the picture.
You might also want to check your TV's settings because some display issues can be caused by how the TV is set up. To make sure that this is not the case, please check your TV's settings.
In your TV's settings, you should check the following:
- Make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
- If your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- If your TV has a type of picture compensation enabled, disable it
- If your TV's settings are correct, you may want to try using a different TV, if you have one available. Try connecting your Xbox 360 console to another TV to see whether the same display issues occur
Next, reset your Xbox 360 console. To reset the display settings to the default settings, follow these steps:
1. Remove any discs from the disc tray.
2. Turn off the console.
3. Turn on the console.
4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time.
Mar 09, 2009 | Microsoft Xbox 360 Elite Console
Setting up Wii with TV
I'm 60 plus years old. Do I connect the AV cables to my TV or to my SAT receiver.
Jun 18, 2008 | Nintendo Wii Console
B/w picture on all av inputs internal tuner from av box colour picture from internal tuner via scarts to video recorder tv on screen menus in colour teletext via internal tuner av box.
sounds like this set is in the UK??? or somewhere out of the states. If it working good on the tuner or telex box , the equipment your plugging into the AV inputs are not compadible to the tv set or there is a setting in the TV menu to change the format to pal
Aug 13, 2006 | LG MZ-42PZ14 42 in. Plasma Television
Jvc av-28gt1sjf
This sounds like a microprocessor controller problem?? Try to reset the tv by unplugging overnight and starting fresh in the am. If it will go in av then your all set BVut if it dosent go into the menu to see if theres any kind of lockout in the set up for the av. If not then youll have to have the set looked at by a pro. Good Luck
Jun 07, 2006 | JVC AV-28GT1B 28" TV
Televison & Video Logo
Top Televison & Video Experts
