Question about Durabrand DVD-1002 DVD Player
Shows unkown disc when i put in a burned dvd-r but it will play a store boughten disc what disc format is compadible with yhis unit
  • Durabrand Master
  • 508 Answers
This model DVD player can play the following disc formats:
DVD-Video (Region 1 or relevant region coded store-bought movies)
DVD-R (must be finalised on appropriate recording equipment for compatible playback)
CD-R (for jpeg/mp3 media files)
CD-RW (for audio such as mp3)
music CD (such as store-bought albums)
This player will NOT accept DVD-RW/+RW discs, or Blu-Ray.
I hope this helps you a tiny bit.
Posted on Mar 21, 2011
PROSCAN TV DVD COMBO WON'T PLAY BURNED DISC STATES "UNKNOWN DISC"
Yes, review the manual and find out what formats the unit will read. you then tailor your cd/dvd burning sw to that format. Also make sure the unit can understand and playback mpeg files.
Oct 26, 2015 | Proscan Televison & Video
When I burn a DVD (R- or R+) on a Sony RDR-GX300 it burns the DVD which plays on that unit only. If I try to play the DVD burned on Sony RDR-GX300 on any other brand or any other Sony DVD player or even on...
On That Type Of DVD Recorder,( RW,R-R+). You Will Have To Finalize The Disk. Finalizing is Necessary When Playing On Any Equipment Other Than This Recorder.Even IF Your Other DVD Equipment IS ( VR ) Format Compatible You Still Need To Finalize The Disk. After Finalizing,You Cannot Edit or Record on The Disk,Make Sure It's In Video Mode.
Aug 11, 2011 | Sony RDR-GX300 DVD Recorder
I downloaded a movie on my computer. I burnt the disc and when I put it in the dvd player it says cannot play disc. I have a sony DVD Player. Any thoughts?
The exact model of DVD player matters. Not all models can play a Computer burned disc.
There are several types of DVD
A factory type DVD in DVD format
A burned movie in MPEG format
a burned disc in DivX format.
Etc.
Try burning the disc with a DVD Creator program, not just 'Burn to DVD'. It's not the same thing.
Mar 19, 2010 | JVC XV-N320 DVD Player
When I place a DVD disc in it shows (no disc or unkown disc). It will play the DVDs that I have recorded on it but not those I purchased. Ray
this item will not play store bought disks it is for recording and burning blank disks you need a normal dvd player
Jul 04, 2009 | iLO DVD Recorder DVDR05
DVD player will not play disc.
If you are loading a store bought DVD and that it what it say's. The transport needs to be replaced. roughly 150-200. If you are loading "burned" DVD's the format may be wrong and the unit cannot read it. Best suggestion I can give you is to first buy a "Laser Lens Cleaner" on that uses fluid. Any electronics store sells them for 15-20. Run it thru the unit a couple of times then try a clean, store bought DVD. If it plays, problem solved. With your DVD's, if you have any liquid car polish like mother's or meguiars, put a couple drops on the disc and spread around with your finger, let it set a couple then buff off with a microfiber towel. This works wonders for old scratched cd's and dvd's and helps protect new ones from getting scratched. As for the Lens cleaner, run it thru every product you have that uses discs 3 or 4 times a year, it's the best preventative maintance and only maintanance you can do on a CD player DVD or PC. Hope this helps
Jun 24, 2009 | Delphi 10.2" FLIP DOWN MNTR/DVD...
Recorded DVD will not play in another player
try playing on computer. if ok copy on hard drive and burn it. if it wont work on your computer. there was an error in the making of the disk..
Apr 15, 2009 | Televison & Video
I have a Sony CRX320E CD/DVD unable to write a DVD
CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
Jan 16, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
I burnt a video to a DVD+R DL but not playing on my DVD player?
You don't need to format the disc, as it does this during the burn process. What you may find is that your NEC dvd player does not play DVD+R. If you can, re-burn the video on a DVD-R 8.5GB.
You can also compress the video to fit on 4.7GB dvd. Download a program called DVD Shrink 3.2. Put the disc you burnt in the drive, and run DVD Shrink. This will analize the film, and all you need to do is click on Re-Author and lower the compression. It even has a line to show how big the video will be on the disc. On a 4.7GB dvd, you don't want this any higher than 4,430MB.
Hope those work
Tim
Dec 08, 2008 | Pioneer (DVR-K16) DVD RW Dual Layer Burner
Cant play dvds
Check all the connectors of the board . The problem may be from SMPS section there may be faulty condensers which does not function properly. Try to replace the condensers and replace the paper connectors then the problem will not occur
Dec 05, 2017 | Toshiba DR4 DVD Recorder
TV says WRONG DISC TYPE
is the dvd a store bought disc or a burnt dvd? If the disc is a store bought disc I unfortunately can't help you. But if the dvd you are trying to play is burned from dvd burner you are most likely using the wrong type of burnable dvd. There are two types of dvd's you can burn, DVD-R and DVD+R. You need to make sure which one you dvd player can play, some play one or the other, some play both. I have also heard of some older ones that can't play any type of burned disc. Hope that helps Peter
Aug 18, 2007 | RCA T09085 9 in. TV/VCR Combo
Durabrand DVD-1002 DVD Player Logo
195 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
