Question about Ricoh Aficio 2022 Black and White Copier
Error code sc546 - Ricoh Aficio 2022 Black and White Copier
  • 263 Answers
This code is related to a unstable fusing temperature.
This could have 2 couses: Defective thermistor or crusted toner on the fuser roller (or both)
You can try doing the follow procedure but i advise you to call technical support to solve the problem once and for all.
Press yellow key
On the key pad press 1-0-7
Old down the red key at least 3 sec.
Enter the service mode. For that on the touch screen press "copy SP".
Exit all the way out.
Turn the machine off/on.
If you have any doubt reply to me.
See you!
Posted on Mar 21, 2011
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
What is the code SC546 mean?
search error code . Brother MFC-8860DN Printer
Jul 10, 2014 | Brother MFC-8860DN Printer
Error code sc546
546 is an unstable fusing temperature:
-Fusing thermistor defective
-Power supply board defective
-Defective connection of fusing unit
Feb 27, 2014 | Ricoh Aficio 1035 Copier
Error code sc546
sc546 is a fuser ready temp problem.
it requires a reset procedure: enter SP mode.touch Copy SP..touch SP DIRECT then press 7807# on the keypad then execute...turn power off and then back on
Jan 29, 2014 | Ricoh Aficio 1027 All-In-One Laser Printer
How do I clear error sc546 on a Ricoh Aficio 2035
replace thermostat in heating section or u yuor tirmistor is directly touching the heat roller
Feb 13, 2012 | Ricoh Aficio 2022 Black and White Copier
Error code sc546
this problem in fuser unit you need to rest the error code
Aug 12, 2010 | Savin Office Equipment & Supplies
I have Gestetner DSM622 SP, Iam getting Errer code SC546, can someone explain me thanks
sc546 is a fuser temperature detect error. One or both of the thermistors most likely need to be cleaned or replaced, but you will have to go into service mode to reset the code once you do that. You should contact your local service technician or Gestetner dealer, as they can easily fix that problem.
May 13, 2010 | Gestetner DSm622sp Digital Imaging System
RICOH 2045E COPIER WHAT DOES ERROR CODE SD546 MEAN?
Hello!
Follow the next steps carefully and the error code SC546 will disappear.
Press the following keys by this order:
1. press the (yellow key) [Clear]
2. press then the numbers on the numbers key by order (1)-(0)-(7)
3. press the red key (cancel) [C] and hold it pressed for about 5 seconds.
4. on the screen will appear another menu different from the one
you are
familiarized it will write up in the left corner [service menu],
(if the service menu do not appear repeat the procedure again).
After this menu will appear turn off the machine from the red switch which is located somewhere in the middle of the machine and just by the left corner (the turn off switch-plug) wait for 10 seconds and turn back on the machine by the same switch-plug.
After this the error code SC546 should be disappear.
Please Answer does this was helpful for i to know does the problem has disappear or i should post some other information.
Regards
Jan 12, 2010 | Ricoh Aficio 450 Copier
Ricoh Aficio 2022 Black and White Copier Logo
691 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
