Question about Hotpoint Ultima WF860 Front Load Washer
My washer is flashing F-12 what does this mean?
    Brigadier General:
  • 6,277 Answers
'F12' for Hotpoint (and other names made by Indesit!) decodes as 'communications error' which sounds major BUT is not uncommon in these machines and is often caused by poor contact between plugs/ cables and the control PCB, just needing re-seating- by an engineer ;-0(
John C
Posted on Mar 21, 2011
I have a 1995 Isuzu Trooper and am getting the diagnostic code Flash... Flash,Flash. I believe thet means 12. Does that mean solenoid circuit failure? And if so, what do I need to do to fix my rig?
When you flash codes on a 95 trooper..it should flash code 12 pause and flash code 12 two more times...if no other codes flash it means there are no codes stored...code 12 is basically, enter codes, beginning of codes and end of codes.
I just double checked cos 95 models were I thought allrunning the obd 2systems..but production dates after the 8th month are considered next year models..so maybe yours is a late year production. I am going to send a picture and pre odb2 code 12 is a code..hope this helps!
Sep 18, 2015 | 1995 Isuzu Trooper
Pau 12 flashing frigidaire
Hey friend, thanks for your inquiry!
I see off your post your Frigidaire washer is showing a "PAU 12" code. Typically "PAU" stands for pause which means the cycle has been interrupted. I would open and close the door to assure that there is a proper connection between the door strike and door latch. If you check that and still receive the "PAU" I would recommend a reset, which can be done by flipping the household circuit breaker off for roughly ten minutes. Hopefully this is helpful. -Matt
Aug 07, 2014 | Frigidaire Washing Machines
Can I reset my motor on a 6 flash code?
Let us just see what 6 flashes mean:
Aha 6 flashes: locked motor check for objects between tubs
Once yall remove the objects yall might have to reset the motor inverter to do so:
Shut off the control. Unplug the machine for one minute. Plug back in and raise and lower the lid six times within 12 seconds. You might have to repeat this more than once.
How it works
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 13, 2011 | GE WJSR4160DWW Top Load Washer
Engine code
12 and 55. The 55 means end of code session, the 12 means no distributor reference. Both of these codes are normal with the engine not running, so do not go out and purchase a dstributor. Is there another problem with the vehicle, or did you just want to know the codes? Comment back to continue,thanks.
May 26, 2010 | 1995 Jeep Grand Cherokee
F-12 keeps flashing in the display screen, what does it mean?
if your machine is not taking in water and flashing this fault check your taps
Mar 29, 2010 | Hotpoint Ultima WF840 Front Load Washer /...
MODEL #WHDRR418G1WW GE WASHER,THE LIGHT (RED0 ON
unplug unit for 1 minute plug back in and open and close lid 6 times within 12 seconds this will reset the motor.
Feb 26, 2010 | GE Washing Machines
Hotpoint Ultima WF860 Front Load Washer Logo
237 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
