Question about Behringer Pmp3000 16 Channel Audio Mixer
I have a Behringer pmp3000 and the right channel has quit working. I can get sound out of the right side my using the surround feature, but evidently the right amp is not sending a signal. Any ideas?
  • Behringer Master
  • 5,603 Answers
Yep! The power amp for that side has failed. There is a weakness of insulation in the multilayer board of some of these that causes the problem. If you haven't seen smoke, that is good. Depending on the revision level of the amp module, there will be two or three blown transistors and a Zener diode blown and possible arcing within layers of the board. The repair of the module takes great care and skill due to the arc damage which is internal on the multilayer board. The amp module is a HCA2400 and are rare costing about $160 and probably are out of stock at FullCompass.com which is the Behringer parts distributor... I have waited 3 months for simple parts... I had one HCA2400 shipped to me but they had wrapped it so tight in bubble wrap that capacitors were peeled off the board and it had to be returned. They didn't know when they would get more... If you have seen smoke, then two other small transistors and a metering resistor have blown. Worst case is when the power supply gets wiped out as well... that ups the parts ante to about $50 as two expensive IGBT's also fail and a half dozen other parts as well.
I have repaired three of the HCA2400 modules and it takes many hours with dental drill to carve out the burned cancer and then re-insulate and put jumpers where the circuit traces used to be. It is NOT DIY for sure. Replacing the transistors requires a desoldering station. I have one unit that a hacker tried using solder wick and destroyed the board.
Posted on Mar 21, 2011
I want to download a Warrior Definitive audio mixer Manual
Visit this page:
http://www.behringer.com/EN/Products/PMP3000.aspx
Or google for:
Behringer Pmp3000 filetype:pdf
Cheers!
Apr 29, 2014 | Behringer Pmp3000 16 Channel Audio Mixer
My behringer pmp3000 doesn't seem to have much power to use my two peavey 12" speakers and use a mic. I have to push the gain and faders up more than I think I should have to, to get a decent level of...
Where do you have the gain control set on the Mic channel ?
If you have no issues with either the speakers or the Mic, and the gain control for the channel you have the Mic plugged into is set at a somewhat "normal" position, you might have a problem with the mixer itself.
Oct 28, 2013 | Behringer Pmp3000 16 Channel Audio Mixer
Hi Folks, I have the Behringer PMP3000 Europower Desk. now also have a studiomaster VPX15 Sub (Active 600W). Does anyone know what the crossover arrangements are on the PMP for the Mono out, and what...
There is no crossover arrangement. On the PMP5000 they have a tunable filter INTENDED to do low pass for a subwoofer. When selecting this mode for a subwoofer The frequency of the low pass filter can be set between 30 and 200 Hz. This feature is NOT available on the PMP3000.
There is nothing related to a crossover in these amps other than what is mentioned above.
The MONO out is merely an analog summation of both the L and R channels.
Mar 06, 2011 | Behringer Pmp3000 16 Channel Audio Mixer
When I plug in my XLR microphone to my Behringer PMP3000 it only works on the Main/Mon function not the Main L/R function, and when it is working it only amplifies through one speaker. WHY???
Check if the PAN control for that channel is set at 12 o'clock position.
You can "pan" the mic to either L or R speaker or anything between.
On the Main/Mon setting, the level sent to the Mon side is controlled ONLY by the Mon level pot for that channel.
Oct 04, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
My behringer pmp 3000 has litle power i thing is 3000 or how much power it haveit? I put 2 speaker only ,,,, thankyou
The unit should drive 400 Watts RMS into a 4 ohm load per side.
The amount of sound power you get will VASTLY depend on speaker efficiency. You would likely use at least 15 inch speakers with the unit.
Aug 08, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I need an owner manualfor a Behringer pmp 3000 16 channel mixer
You can download the manual by clicking this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Jan 15, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Down on one channel
Check your pan pots are centered.
Jun 08, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
I have a behringer pmp3000 how do i select the setting to allow me to have mains on one side of the out and monitor on the other? I know the selector switch must be in a certain position, but which one,...
You want the mon1/mono setting. The center position of the slide switch to use each half of the power amp seperately. Then fiddle with the controls BOTH in the strips and the faders to get desired result.
May 15, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
Behringer Pmp3000 16 Channel Audio Mixer Logo
154 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
