My furnace motor is smokin hot and won't turn freely. Do I need a new motor?
    Genius:
  • 1,015 Answers
It is probably time to replace your motor. However first I would clean it as good as I could and if it has oil ports then add a few drops of machine oil. If you can use air compressor to blow out dust,hair,lint,or other crud by blowing through vent holes on motor housing. Check squirrel cage and clean as best you can.Also you can try to spray a small amount of WD-40 around motor shaft where it comes out of the motor.
None of this may help but it don't cost much and it could save you some money. Good luck. Thanks
Posted on Mar 21, 2011
Central a/c fan will not start after flood
replace the fan motor as the bushes are dry and seized up.
Jun 09, 2013 | Heating & Cooling
Furnace won't turn on
What is the make and model# of your Furnace? And is it a pilot light, or a hot surface Igniter?
Dec 29, 2012 | Heating & Cooling
The blower motor on my furnace gets hot, shuts down and smokes
If it was a bad capacitor it would not run, getting hot it is over loading or something causing a high amp draw poor wire connections, or a motor winding shorting out?
Jan 12, 2012 | Goodman Heating & Cooling
Motor sticks will not spin to start furnace
Hello, unfortunatly you will need a new motor. If it can't spin freely than the bearings are shot.
Jan 05, 2012 | Heating & Cooling
Hi would like to know if it is not manufactured anymore went all arounf New York to find it thanks
There are 12 bottles currently in stock on Amazon. here is the link:
http://www.amazon.com/Essie-Smokin-Hot-Nail-Lacquer/dp/B00484YSX4
Sep 12, 2011 | Essie Lacquer Color Smokin' Hot 739...
Washer won't6 empty water after rinse cycle code F 50 appears
F50 means that the motor stalled. An F then 50 flashes when the motor rotor position sensor (RPS) senses no rotation. You will need to verify that the basket can turn freely; If it does not and this machine is new, then make sure bottom shipping pack has been removed or determine what is the cause of friction. If the basket turns freely, you will need to perform test checks with the wiring to the motor and rotor position sensor; and the motor and rotor position sensor themselves. I can help you thru this process, or if you are not comfortable doing it, you can hire a qualified technician.
Hope this helps.
Aug 11, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My furnace blower fan is not working and theres a smell coming out as well. I found the correct motor and capacitor part no.s. How easy are these to change out.
The problem you're facing here could quite possibly be more than just replacing a motor. You could have circuit damage which may be the reason that the furnace quit working. You can try testing the fan that is currently installed. Make sure it is working first before buying new parts. Determine the required voltage for your fan and supply that voltage to it momentarily. Do this while the fan is completely isolated from your furnace (unplug any leads from it to the furnace controllerboard) You may want to get assistance when working with electrical current so you don't accidentally cause harm to yourself and/or your furnace.
Mar 13, 2011 | Heating & Cooling
Furnace stopped blowing cold. 'Stat works, blower works. Went outside, condensing unit fan does not run, motor is excessively hot to the touch. Fan blades spin freely. I pulled the disconnect and...
Hi!!
Replace motor fan and capacitor, it is a very simple task. Turn breaker OFF. Then all you have to do is remove about four screws from the top grill, about four more that fasten the motor fan assembly, unplugg electrical connectors and label them and install the new one and switch fan blades.
No special knowledge is required to perform this job. Cost: about $140 +-.
On the other hand, you call a HVAC technician, they supply the motor and capacitor, otherwise they won't give you warranty. Cost $300+. Look on the Yellow Pages for one in your neighborhood.
Good Luck!! Rate this post!!
Aug 13, 2010 | Carrier 38CKC030 Air Conditioner
Well when i turn on a/c condensingcome on and
is your indoor fan motor noisy? Right after it shuts off feel if it is extremely warm (carefull, may burn you if you leave your hand on too long). If it excessively hot, the motor is tripping on overloads located in the motor itself, probably the bearings are dragging. Check to see if it spins freely when spun by hand. If not replace motor. Make sure power is off while putting your hands in or around the fan
Jun 11, 2009 | Goodman Heating & Cooling
My gas forced air furnace is shutting itself off after 2-3 cycles
there is a thermo-sensor switch next to the circuit board that tells the fan switch to turn on when the plenum is hot enough. this needs to be replaced.
Dec 01, 2008 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
37 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
