Question about Maytag HYE3658AY Electric Dryer
Maytag HYE3658AYW electric dryer -- drum turns but it will not heat.
  • 833 Answers
SOURCE: Dryer drum wont turn
These units use two circuits to operate. It is entirely possible that the circuit breaker for one is open. The breakers are linked units...generally 30-40 amperes. Turn both off and then on.
Posted on Dec 21, 2007
Loringh
  • 185 Answers
SOURCE: The Maytag Dryer MED5570TQ0
Hi lesterjabbow;
A lot of these dryers have a long fiber belt that runs from a pulley on the motor thru a tension idler pulley and goes all around the drum. I suspect this belt is either broken or has come off the drive pulley on the motor. You can remove the back of the dryer easily with a 1/4 or 5/16 nut driver and immediately see if the drive belt is good. Any Maytag dealer will have a replacement part and it is easy to install
Hope this helps Good Luck Loringh PS Please leave a ranking if appropriate Thanks
Posted on Nov 22, 2008
RescueTech
  • 145 Answers
SOURCE: Electric maytag stack dryer not heating...
That dryer is made by Speed Queen. A common failure part is the thermal overload, mounted on the heater box. Items 4 and 6 in the picture Iposted are possiblities.
Posted on Dec 14, 2008
lenwest
  • 150 Answers
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Posted on Jan 30, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Electric Maytag Dryer Performa: Front loading
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley or a faulty motor.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 05, 2010
My dryer does not have any heat.
Is this electric or gas or what?
Sep 07, 2016 | Maytag Dryers
Dryer won't start the drum light doesn't come on either
did you check the breaker being tripped. do you know you have power to the unit?
Sep 15, 2015 | Maytag Dryers
Drum still turns but no heat where do i find the heater
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 12, 2010 | Maytag PYE2300AY Electric Dryer
Maytag dryer wont spin It makes heat,but the dryer wont spin
Sounds like the drum belt is broken or off the pulley of the motor
Sep 25, 2009 | Maytag Dryers
I have an Maytag model # MAEDZ600TW2 Epic Z Electric dryer , the drum turns but no heat , circut breakers were checked , lint screen is clean , btw , date of purchase was 3/23/09
There are 2 common reasons your dryer will not heat.
1. Your limit switch is out on the dryer not allowing the heating element to switch on.
2. Your heating element is out.
before you try to fix this yourself it should be covered by warranty.
Apr 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Dec 14, 2008 | Maytag SDE2606 Electric Dryer
MAYTAG ELECTRIC DRYER DOESNT HEAT. CAN YOU HELP ME?
Without seeing it, and very little info to go on, let me ask this, does the drum turn?
If there is no heat, go outside and check the exhaust, do you feel air blowing out?
If you do, then the heating element may be bad or the switch that sends power to the element may be bad. If no air blowing out, then I do not know any further. At any rate, a service man must come.
Nov 16, 2008 | Maytag PYE2300AY Electric Dryer
Dec 20, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag HYE3658AY Electric Dryer Logo
146 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
