Question about Apple MacBook Mac Notebook
My MacBook Pro will power up but in the center of the sreen it has a box with a circle and a line and the a ? in center of box.The box and circle just flash.
  • 4 Answers
This is a sign that your hard drive may have failed. If you have the original boot CD/DVD for your computer, I would recommend putting that in the computer, power it up and hold down the C key to boot up from that disk, and run the "Disk Utility" program to see if your hard drive has officially failed, or if you just have a corrupted file.
Best recommendation though, would be to make an appointment at your local Apple store, and have a Genius take a look at it. If you are under warranty then you'll be taken care of, but if you haven't been backing up your data you may lose your information.
If you are out of warranty, the cost for a replacement drive is usually less than $250.
Posted on Mar 21, 2011
How to remove a little circle of color in spinning
Ctrl+Click on the icon in the dock and select force quit. Make sure you don't have too many other processes running at the same time.
May 14, 2014 | Apple MacBook Pro Notebook
Colored circle comming up
Resetting the PRAM may do the trick:
You reset the PRAM by rebooting a Mac and then immediately hold down the Command+Option+P+R keys, you will then hear the Mac reboot sound again, signifying your PRAM has been reset. You must hit the key combination before the grey screen appears otherwise it won't work.
you've tried rebooting, you've reset the PRAM, you've done it all, but your Mac is still behaving strangely. What next? In certain circumstances, resetting your Mac's System Management Controller (SMC) can be a solution. This is sometimes necessary to restore normal lower level system functionality to your Mac.
Here's how to reset the SMC on any type of Mac (and any version of OS X) and the type of problems that it may resolve.
When & Why Reset SMC on a Mac? Some Common Hardware Reasons
Typically it's power and hardware related issues that can be helped or resolved by resetting a Mac SMC, particularly if you're having these types of problems:
* Issues with your Mac's cooling fans and fan management: fans run constantly at high speed, fans run high despite low CPU usage and adequate ventilation, fans not working at all, etc
* Power management and battery problems: Mac isn't turning on, sleep isn't working, random shutdowns and reboots, battery isn't charging, Mac won't wake from sleep etc
* Light problems and improper lighting management: battery indicator lights aren't working, display backlighting isn't adjusting to ambient light changes, keyboard backlights not working, etc
* Video and external displays not working: display brightness functionality not working properly, target video mode isn't working properly, external display isn't working, etc
* General performance and functionality problems: abnormally sluggish behavior despite no CPU or disk usage, external ports not working, airport & bluetooth aren't showing up, external devices are not being found, etc
So now that you've concluded you need to reset your SMC (Note that the SMC is on Intel Mac's only), here's how to do it on MacBook's, MacBook Pro's, iMac's, Mac Mini's, and Mac Pro's. Notice that the reset instructions are different for MacBook and MacBook Pro's if you have an internal or detachable battery.
Reset SMC of a MacBook Air, MacBook Pro Retina, or MacBook Pro's with an internal non-removable battery
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
sad mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Feb 28, 2014 | Apple Computers & Internet
Apple MacBook Pro 13
you can easily fix your apple macbook pro issue by dial our toll free number +1(800) 726-0294 our highly qualified technicians easily able to fix all type of issues of any apple product
for more information visit our macbook pro support page-->
1 800 726 0294 MacBook Pro support number Technical Help
Oct 15, 2017 | Apple MacBook Pro 13
My MacBook Pro is stuck on the grey start up screen with the apple logo and a spinning circle. Sometimes it gets to a probationary circle with the spinning circle.
Unfortunately, this sounds like a problem with your hard drive/ logic board. To Fix This You Will Need To Go To The Apple Store And They Will Most Likely Have To Replace Or Repair It. the Process Takes About 2 Days - 1 Week (Just To Set Expectations.) :(
Aug 28, 2012 | Apple MacBook Pro Notebook
MacBook Pro circle with line through it if you hold down option it sees the drive but won't boot
You need to reinstall your OS, If you need help let me know I can walk you through it ...
Aug 29, 2011 | Apple MacBook Pro Laptop Computer with...
Which is the best laptop?
This is very subjective, but either the MacBook or MacBook Pro because the MacBook Air is more expensive than the Macbook because it is thinner, but does not outperform it.
Now between the MacBook and MacBook Pro there are so general guidelines: -If price doesn't matter, the MacBook pro is the best Apple laptop because of its RAM and Aluminum body finish, also its Sandy Bridge processors and its new Thunderbult Port.
If price does matter, than there are some general deciding factors:
  • What do you do? If you work on your MacBook pro using PhotoShop and Movie Editors and a lot of software- the MacBook Pro is what you want. Also if you game, the MacBook pro is awesome.
  • Is it just for fun? If you want this laptop just for recreational use and not for games requiring heavy processing power for graphics, just get the MacBook.
Bottom Line: MacBook Pro is the best Mac laptop
Apr 06, 2011 | Computers & Internet
Frozen up just the circle of death spinning
listen to the hard drive, does it make a repetitive read access sound. if so i would assume your hdd is broken somebody has to open the Laptop and replace the hard drive and re-install your OS. If you want to pay to have somebody do it for you there is a third party Macbook Repair Service. However, if you want to do it yourself, the part is available on ebay. Here's an Macbook Repair guide. Maybe a tech savy friend can do it for you.
Jan 19, 2011 | Apple MacBook Pro Notebook
Gray splotch on lcd screen on a macbook pro 13-inch
That is most likely a defect in the LCD itself... there was a huge issue with this on the older PowerBook series - like shown in this picture, 3 roughly dime-sized circles to the right of the Apple logo. If you need a place to mail it to, iResQ has done wonders for many of my friends - link is for mail-in, but they sell the screen itself as well if you want to try on your own (but take it from me, it's a bit troublesome and easy to mess up cables - I repair these for a living). Hope this helps!
Nov 01, 2009 | Apple MacBook Pro Laptop Computer with...
Macbook Pro Dimmed but see the image clearly
Here is a photo. It is the white circled part.
Jul 10, 2009 | Apple MacBook Mac Notebook
Apple MacBook Mac Notebook Logo
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
