Question about Surpax Technology Emoji Plus - Best Emoticon Keyboard
I have a 3G Iphone and Emoticon+ I put Pictures on some of my Contacts. When I synch with ITunes the pictures go away and are replced with a ? how to I fix this problem?
How to transfer contacts from iphone to pc?
I had a nokia E71 and downloaded software from the NOKIA WEBSITE. you can use it to transfer your nokia contacts into windows contacts.
Then you have to download Itunes from APPLE and use CLOUD SYNCH to send your windows contacts (which would have your nokia contacts intergrated) to your iphone. I used the charger and plugged into the USB of the computer for both. its alot of work but possible - and faster than manual re-enter.
note: some contacts on my nokia for example if a phone number description was changed from "work" or "home" to lets say "work cell" windows contacts did not understand custom categories and some numbers did not transfer correctly, eg, "work cell" became "fax" or nothing at all. There was some editing within windows contacts to correct the issue so that Itunes would interpret the contacts correctly.
In short:
-Nokia software
synch contacts to windows contacts
-windows contacts
check everything looks good
-itunes & cloud synch software
import windows contacts and synch phone.
(Cloud synch may be a separate download)
as far is I know there is not an easier way.
Dec 14, 2012 | Apple iPhone Smartphone
How can I restore iphone 3g?
If you can not contact the itunes server try to restart your computer. Have you tried to jailbreak your device?
Jun 15, 2012 | Apple iPhone 3G
I was upgrading my i phone 3G with the new version of I tune and left it overnight to download, in the morning I see the icon of the connect symbol on my iphone screen and nothing else could be done. I...
Thank you for your inquiry regarding your iPhone 3G Farid.
The issue with your iPhone 3G going to the iTunes with USB screen mode, is an indication that the upgrade you attempted to perform somehow removed the previous iOS (iPhone Operating System) you were using prior to the upgrade you were attempting achieve.
As a result, you are correct. Because you are connecting your iPhone 3G to another computer, you would not be able to sync with the other computer's iTunes library, without risk of losing all of your media on the iPhone 3G.
To resolve this issue, you would need to attempt to perform a restore back to the factory settings on the computer that contains the iTunes library you have original synced your iPhone 3G with.
This process will wipe the data from your iPhone 3G, yes, but if you have previously synced your iPhone 3G with that iTunes library on the computer in the past, that means the iTunes library will have some previous back ups from those past syncs you have performed with your iTunes library.
If that is the case, then when you perform the factory restore Farid, you will then need to follow up and perform a restore from your most current back up process in iTunes, so you can restore your iPhone 3G back to its most current settings and data, contacts, and pictures.
For a support page reference on how to perform a factory restore and a restore from a previous back up her is a link I would like to provide you for review:
http://support.apple.com/kb/ht1414
You can also use a software solution if you do want to safely transfer your data from your iPhone 3G to another computer with another iTunes library on another computer if you so choose.
One of the better software titles I recommend is called: Media Widget iPod Transfer Software
This is a great software solution for any iPhone, iPod Touch or iPad product.
Let me know if this helps. If you have more questions regarding this issue or what I have provided,, please free to reply back to this post.
Best Regards,
Terry ("Mactechtrainer")
Oct 26, 2011 | Apple iPhone 3G
I have an iphone and dropped it on our garage floor. SInce then, I haven't been able to get the brightness back. I can only see it with a flashlight. I took it to the local AT & T store and they...
what they want you to do is to restore your iphone to factory settings in itunes
connect the phone then let it sync so it backups everything. then click on the iphone named on the left now click on restore and follow the on screen instructions
Apr 10, 2011 | Apple iPhone 3G
IPhone Smartphone: I have an Iphone 3G and Itunes 9.1 and MS Oulook 2...
make sure dates and timezones are correct and synched on both computer and iphone.
May 17, 2010 | Apple iPhone Smartphone
I try to turn on my iphone and all it does if show the picture to plug in to itunes.
that means you need to synch it with itunes for activation
Mar 12, 2010 | Apple iPhone 3G
Where on my PC do I put iPhone ringtones?
First make sure they are M4r files and not standard mp3.
Secondly you can put them anywhere. You just have to go in to iTunes, go to the Ringtones tab on your iPhone and then add the folder to be synced.
Aug 27, 2009 | Apple iPhone 3G
ITunes doesn't recognize iPhone SIM card
u pls jailbroke the iphone with redsn0w , then it will be
Aug 26, 2009 | Apple iPhone 3G Black Smartphone
How to transfer Contacts in iPhone to Outlook
Once your iPhone is connected to your PC and iTunes is loaded you can right click on your iPhone and select exactly what you want to have sync'd.
1. Under the Info tab you will find Contacts. 2. Tick the "Sync contacts with :" and select Outlook from the list. 3. Click "All contacts"
If you wish to put all of your iPhone created contacts into a different group in Outlook you can select the group there also and tick the relevant box.
iTunes always displays a warning about over writing data but that is not relevant to Contacts. Data is always merged.
I hope this solves your problem.
Chris
Apr 08, 2009 | Apple iPhone Smartphone
Sync Outlook Contacts & iPhone
When you create a new Contacts Folder you have to make sure that you create as a subfolder of the main contacts folder (in the create window you are shown the file tree).
I had the folders moved in different groups as well but I am not sure that it made a difference.
Please note that you have to leave outlook and itunes on for a few minutes before they synch and iTunes see the new folders.
Oscar
Sep 07, 2008 | Apple iPhone Smartphone
Surpax Technology Emoji Plus - Best Emoticon Keyboard Logo
107 people viewed this question
Top Surpax Technology Apps Experts
Marvin
Marvin
Bill Boyd
ray gallant
Are you a Surpax Technology App Expert? Answer questions, earn points and help others
