Question about GE Advantium 120 Convection/Microwave Oven
How to change bulb in five star convection oven? Bulb covered. How to remove cover?
    Brigadier General:
  • 8,909 Answers
Remove the outer cover by unscrewing the fixing screws. The lamp will then be visible for replacement.
Posted on Mar 21, 2011
KitchenAid KCMC155J 1000 Watts Convection / Microwave Oven - how to change the light bulbs - can this be done without having to call a tech?
Look for a small cover on the outside of the cabinet in the place where the bulb is. They are usually secured with a single *****. It is the only part of a microwave oven that is consumer serviceable! Remove the cover and unscrew the bulb, replace and refix the cover.
your manual is here but doesn't mention the bulb
http://www.manualslib.com/manual/88077/Kitchenaid-Kcmc155j.html#manual
KitchenAid KCMC155J Use Care Manual
Mar 11, 2013 | KitchenAid KCMC155J Convection/Microwave...
How do i get into globe compartment to change globe on a convection microwave
The cover has to come off the microwave to access the bulb. There are several screws around the back and sides. Remove these and the cover should lift off, revealing the bulb. For your own safety, make sure that the microwave has been unplugged from the outlet for several hours before attempting this repair.
Feb 25, 2011 | Smeg FME24X Microwave Oven
Can't get in to change the bulb
You normally have to remove the outside cover to access the bulb. once you have the cover off you will see the bulb to be able to change it.
Make sure that the oven has been unplugged for a few hours before opening the covers.
Feb 06, 2011 | Zanussi ZMC30STQX Convection Microwave...
I can not find a model number on my microwave but I know it is 800 watts/convection. Can you please tell me how to change the light bulb - I have removed the glass covering but cannot see how to access...
I would browse the manufacturers web site until you find your mode.
The bulbs are normally accessed from either an inspection cover in close proximity to the lamp or by removing the outer cover.
Hope that helps
Dec 23, 2010 | Neff H7871 Convection/Microwave Oven
I have a Kitchenaid combo unit of Oven & Microwave. Model YKEMC308KM01, Serial # XP4603281.Can someone help me as to how to change the light bulb of the microwave. I simply dont see any openings on the...
That's covered on page 21 of your owner's manual.
If for some reason you don't have yours, you can download it free here.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven.
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
You can find handy exploded views and order parts by model number here.
Dec 18, 2010 | KitchenAid KBMC140HSS Convection/Microwave...
How do i remove the cover to change the light bulb inside?
The bulb is positioned at the top of the oven, accessible only from the outside. You'll need to pull off the top and bottom trim strips, remove the bottom trim strip locators, remove 2 fixing screws from the left edge of the oven (with door open), and the 2 fixing screws from behind the top trim strip. The oven should then just slide out. You only need to pull it out 6 inches or so to gain access to the bulb cover. You'll need a T20 driver to remove the cover, then the bulb unscrews as it has an SES fitting. Bob
Nov 20, 2010 | Neff H7871 Convection/Microwave Oven
Light bulb in oven went out
Remove the top grill by removing two screws in the top. Pull the top of the grill out towards you as the bottom has pegs on it. About 6 inches from the left is metal cover that you just squeeze with your finger tips to remove. This exposes the bulb.
Mar 28, 2009 | GE Advantium 120 Convection/Microwave Oven
Lamp bulb is out
You must remove the outside cover of the microwave to change the bulb.
The light cover inside the microwave should not be removed. It is held in place with contact cement.
For disassembly help see:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
The bulb should be available at most grocery stores, home centers, hardware stores, and places like Wal-Mart.
Sep 24, 2008 | GE JE1590 Convection / Microwave Oven
Delonghi
Changing bulb in DeLonghi ED 8525S-SBD
This is merely an account of how I fixed mine - do this at your own risk. The oven is full of high-voltage items which include large capacitors which are not discharged when you unplug it from the mains. You can still get a life-threatening shock from the charge which is stored in these components.
Therefore do not touch ANYTHING electrical except the bulb connectors.
1. Unplug the oven and place on a suitable surface 2. Remove the cover. This is held by five screws at the back of the of the machine. Three are along the top and are philips type and the other two are on the bottom left and bottom right corners and are star-grip. The cover must slide backwards first before coming off. 3. Find the bulb holder. It is located on the right of the oven as you look at it from the front. Turn the oven so that its right side faces you. The bulb holder is an oval black part with two electrical connections coming off it. It is about 6-7 cm long and 3 cm wide. It is mid way in the oven (from top to bottom) and a little towards the front. It is held to the oven frame with two bent metal prongs 4. Remove the electrical connectors by sliding them backwards. 5. Bend back the prongs and lift out the bulb holder. 6. The bulb in a 20W 240V oven lamp with a standard oven lamp screw-on fitting. 7. Replace the bulb. 8. Put the bulb holder back in place, bend the prongs back to secure it, re-connect the electricals. 9. Replace the cover and screws.
Jan 15, 2008 | Microwave Ovens
GE Advantium 120 Convection/Microwave Oven Logo
90 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
