Question about Casio Algebra FX 2.0 Calculator
I have casio fx 2.0 plus and survey programe pdf files
  • Muhammad Rafiq
    Muhammad Rafiq Sep 10, 2017
    How can I download vertical and horizontal program to algebra fx 2.0 plus
  • 8016 Answers
SOURCE: How do I graph an equation such as y= 5x + 2?
Turn calculator ON. If you do not see several icons press [MENu].
Use arrow to select the [GRAPH] application and press [EXE].
In the entry screen, the line with Y1= is highlighted. If it is not, use arrow to highlight it.
Press the right arrow, the highlighting disappears leaving you with Y1= and the blinking cursor.
At the position of the cursor enter 5 [X, theta,T] key under the [ALPHA]. On the screen appears 5X, complete you equation +2.
Press [EXE] to store function.
If you want to draw other functions, it is time to do so on that screen.
When done press [F6:Draw}.
If the screen does not show a lot of the function, you can use the arrow keys to pan the graph.
You can also press [SHIFT][V-Window] to set the window limits.
Hope it helps.
Posted on Oct 11, 2009
Testimonial: "Thank you so much!!!"
SOURCE: Inputing factors on a casio fx-115es calculator
Unless I am failing to understand your problem, just combine like terms to get:
9x^2+2x+4 and then enter those coefficients into the quadratic solver.
That will get you the two answers -- both of them will be complex.
If you wanted to turn those two answers into factors (complex) of the original equation simply
change the signs on each and put an x in front.
Of course, the quadratic formula would also work.
CG
Posted on Apr 28, 2009
  • 1126 Answers
SOURCE: I need to know how to set the Casio fx-9750ga plus
Page 14 in Chapter 1 listed here.
http://support.casio.com/pdf/004/fx_plus_chapter01.pdf
Posted on Sep 24, 2009
  • 8016 Answers
SOURCE: How can I solve a matrix on my Casio fx-9750GA
If you have mastered matrix manipulations on the TI calculators, it should be a breeze to learn the same on the Casios.
A. Define the matrix (Create it)
  1. Turn calculator ON.
  2. Press Menu,select the MAT icon and press [EXE]
  3. You see a list of possible matrix labels (A, B, C,D,E,F)
  4. All that have not been created have a "none" to their right
  5. Highlight a matrix name and press the right arrow. Where there was "none" , you have a template 0x0.
  6. That is where you specify the dimensions (mxn). exemple. 2x2
  7. Enter the first dimension and press [EXE]
  8. Enter the 2nd dimension and press [EXE]
  9. A matrix template opens where you enter the coefficients left to right and up down.
  10. After each coefficient press [EXE]. Cursor moves to the next coefficient, etc.
At the bottom of the screen you have 3 menus for Row and column manipulations. But those will have to wait for now.
Press [SHIFT][QUIT] to return to the list of matrices to create new ones
Operations on matrices
Once you have one matrix, you can do operations on it: Calculate the determinant (if matrix is square), calculate its inverse, transpose, augment it, fill it, etc..
  1. These operations are accessed as follows.
  2. Quit the matrix editor by pressing [Menu] and selecting the [Run] application.
  3. Press [OPTN][F2:MAT]
  4. You have the menus Mat,M(atrix)->L(ist), Det(erminant), Trn (transpose), Aug(ment) ->, Iden(tity),Dim(ension) Fill
Exemple : calculate the determinant of a matrix A (already defined).
  1. You press the [OPTN][F2:MAT] key sequence (just above)
  2. Press [F3:Det]; the command det is displayed on screen.
  3. Press [F1:Mat] the identifier Mat is displayed.
  4. Press [ALPHA] A; screen display det Mat A.
  5. Press [EXE] to get the value of the determinant.
Square of Matrix A
[OPTN][F2:MAT] (MAT) [Alpha] A ^2 [EXE]
Product of two compatible matrices MatAXMatB
[OPTN][F2:MAT] (MAT) [Alpha] A [* ) (MAT) [ALPHA] B [EXE]
Hope it helps.
Thank you for using FixYa.
Posted on Nov 23, 2009
  • 8016 Answers
SOURCE: how to use casio fx-9750G PLUS to find inverse????
To calculate the reciprocal of a numerical value you can use
  1. 1 / numerical value or
  2. use the key sequence [SHIFT] [ ) ] (X to -1), if the number is already displayed (stored in answer Ans memory)
Example: calculate the reciprocal of 13. Must be in Run Mode
1 [/] 13 [EXE] result is 0.07692307692 or
13 [EXE] to have 13 in Ans memory (displayed) and [SHIFT][ ) ] [X to -1] [EXE].
For such a simple number as 13, calculating its reciprocal the second way seems ridiculous, but if the number is already displayed the second method is the only efficient one if you do not want to copy the result on a piece of paper and retype so as to calculate its reciprocal.
Posted on Jan 21, 2010
I've got a casio fx 991plus calculator and I want to know how to use feet and inches in the calculation displays, like how is used meters and centimetres in the display
PDF]fx-570MS/991MS Additional Functions - Support - Casio
support.casio.com/pdf/004/fx570MS_991MS_E.pdf
Casiodisplay format (Disp) settings while the calculator is in the BASE ... Be sure to checkthe current calculation mode (SD, REG,. COMP ... Use [ and ] to display the expression 4 + 4. Press A ... want to perform scientific function calculations. COMP .
The Casio fx-991es, fx-570es and - Numericana
www.numericana.com/answer/casio.htm
The Casio fx-991ex succeeds the fx-991es (functionally identical to the ... Both are nonprogrammable nongraphing scientific calculators, with natural ... Side-by-side comparison of the fx-991EX and fx-991ES PLUS. ... Displays QR codes for smartphone use .... Work out a formula for many values of the input variables.
CASIO fx-991MS Calculator Tutorial: Lesson 5- Dealing with ...
Dec 03, 2015 | Casio Office Equipment & Supplies
How to protect existing program on the casio fx 7400g plus
Follow the programming instructions in chapter 8 of the user manual. If you need a copy, download from here: http://support.casio.com/manualfile.php?rgn=5&cid=004002008
Mar 17, 2015 | Casio FX-7400G Plus Calculator
Program - block up's
Here is a link to planet.Casio a French site that has some games for the FX-7400. Explore.
http://www.planet-casio.com/Fr/programmes/voir_un_programme_casio.php?typ=a6&calc=2
Oct 23, 2013 | Casio FX-7400G Plus Calculator
User's manual for fx-300w
You can have the manual from (http://support.casio.com/pdf/004/fx85W_85WA_E.pdf).
Nov 21, 2008 | Casio FX-300W Plus Calculator
Standard deviation
standard deviation
calculate mean of a data set:
1. Turn calc. on or press MODE SeTUP
2.Press 3 for STAT
3. Press 1 for VAR
4.Enter values for X column
5. WHen done entering press SHIFT 1
6.Press 5
7.Press 2 to calculate the mean
8.Press =
Oct 05, 2008 | Casio FX-115ES Scientific Calculator
Directions to use Casio FX-115W
This is described in the manual (link below) on page E-52 http://ftp.casio.co.jp/pub/world_manual/edu/en/fx-115ES_991ES_Eng.pdf Also see example #083 in the appendix : http://ftp.casio.co.jp/pub/world_manual/edu/en/fx-115ES_570ES.etc_Appendix.pdf
Jul 23, 2007 | Casio FX-115W Plus Calculator
Casio Algebra FX 2.0 Calculator Logo
217 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
