Question about Hunter 30124 Air Conditioner
How do i replace Hunter Fan 44428 Thermostat batteries ? I dont have the keys to the thermostat and manual does not steps.
Richie_asg1
  • 1036 Answers
SOURCE: hunter thermostat problem
I can't see a thermostat for the reference given (30124). According to my listings that's an air conditioner.
I do have the manuals for Hunter - Just click HERE for a list to the PDF documents you can download and print off.
Thanks for using Fixya, If it has solved your problem, please rate as such. thank you.
Posted on Jul 01, 2008
SOURCE: How do I find an instruction manual for a Hunter 44110 thermostat?
http://www.hunterfan.com/uploadedFiles/Support/Owner_Manuals/42707a.pdf
Posted on Jun 17, 2009
  • 15 Answers
SOURCE: how do I change batteries in a Hunter airconditioner thermostat
You should be able to just pull off the front cover. Look around the wall and there should be guides telling you too either pull the bottom out first or somehting like that. The batteries should be just behind the front cover.
Posted on Dec 12, 2009
  • 5417 Answers
SOURCE: I bought a house with
To change the time, press Hour once. Then press and hold Hour to until it reaches the correct one (pay attention to the AM/PM notation). Do the same with the Min and Day buttons. Press Return when done. (The thermostat will leave return to the normal mode after 10 seconds without a button press.)
Now to set the program, set the switch to heat or cool depending on which you want to program first. Press Prog (this will program M-F settings) then press and hold Hour until the time you want Prog 1 to start. Press the Up or Down arrows to get to the temperature you want to reach and stay for this period. Press Prog again and use the Hour/Min/Up/Down keys to set the time and temperature for next period. Repeat for program 3 and 4 for weekdays. Press Prog again to do the same thing for the 4 possible weekend program segments. Any time left at 0:00 results in a program being skipped.
Press Prog to set the Program. These settings will not take effect until the next time change in the program. You can review the settings by pressing Prog and scrolling through the settings.
Change the switch to the other setting and repeat the programming if your system has both AC and heat.
If you want to press the AutoProg button the thermostat will use preset times and temperatures. For Heating that is 5 am 68, 7 am 60, 3 pm 68, 10 pm 62. For cooling it is 5 am 78, 7 am 85, 3 pm 78, 10 pm 82.
For more information, you can get the manual from Hunter: http://www.hunterfan.com/Support/Manuals-and-Parts-Guides/ , just enter the model number in the Search line.
I hope this helps.
Posted on Aug 17, 2010
  • 185 Answers
SOURCE: How do I remove cover to replace batteries for
Shut the power off at the furnace...
Take both of your hands and start at the bottom and slowly start apply pressure at the bottom of the stat and it should pop off...leaving the subbase attached to the wall. Takes 3 AA batterys
Here is the Manual for this stat.
http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/44428.pdf
Posted on Jan 02, 2011
Furnace won't come on
10-17-12
Change battery on thermostat.
Usually located back of thermostat.
Oct 16, 2012 | Hunter Fan Company 5/1/1 Programmable...
I am replacing a White-Rodgers thermostat with a Hunter 44155C and dont know where to connect the wires. I have white, red, green, blue, and yellow wires and none are labeled as to what they are.
The Yellow wire is for cooling, the white is for heating, the red is for power, the green is for blower fan, the blue is your common wire, all you should have to do is color code the wires to the thermostat. The thermostat should have the colors labeled R,W1,G,Y,B or C for common if it's wired correctly at the Air Handler or evaporator. The blue wire should go to B, or C.
May 28, 2011 | Hunter Fan Company 5/1/1 Programmable...
How do I remove cover to replace batteries for Hunter 44428 thermostat?
Jan 02, 2011 | Heating & Cooling
Hunter 44260 Thermostat Problem
make sure you have the jumper in place
if you dont have a secondary heat source red should be on r with a jumper to rh
Oct 17, 2009 | Hunter Fan Company 5/1/1 Programmable...
Hi I am replacing a trane thermostat it has 8
call hunter fan co. you will have to jump out some term.
Jul 01, 2009 | Hunter Fan Company 5/1/1 Programmable...
Thermostat won't stay on, even with new batteries on hunter therm
replace the thermoste with a new one its easy to do
1.turn of breaker to doorbell air handler and compresser (outsideunit)
2 take of thermostat lble wires as to wich leters they conect to
3 put on new thermostat enshuring whires are conected to corect letter
4 turn on beakers and enjoy!!
Jan 21, 2009 | Hunter Fan Company 5/1/1 Programmable...
Thermostat
By resetting I found out that there was low battery, but now I can't get the face of the thermostat off to put in a new battery. Manual got displaced.
Jul 19, 2008 | Hunter Fan Company 5/1/1 Programmable...
Hunter programable thermostat
google search hunter thermostat and the model number and manual and it should come up, I found mine with "hunter thermostat 44200 manual"
Nov 25, 2007 | Hunter Fan Company 5/1/1 Programmable...
Programmable Hunter Thermostat
hi
this site as the owners manual you can download in pdf . if this helps you out .
Programmable thermostats at discount prices at hunter-thermostats.com.
riz.
Nov 14, 2007 | Hunter Fan Company 5/1/1 Programmable...
Hunter 30124 Air Conditioner Logo
214 people viewed this question
Top Hunter Heating & Cooling Experts
1STHVACMAN
Jay Finke
Jay Finke
Are you a Hunter Heating and Cooling Expert? Answer questions, earn points and help others
