Question about Whirlpool Dishwashers
There is a puddle of water forming to the left front of my dishwasher. I checked the overfill valve; not it. The puddle forms after the last cycle (steam). What can I check out? Clisten Wells Indianapolis
  • ckwells1969 Mar 24, 2011
    The model number is DUL200PKB1.
    The serial number is FP1611812.
    Thank you for your response. Will await your further reply.
    The leak is coming from the right bottom edge of the dishwasher door. Happens during the 2nd rinse cycle. Other than the door seal itself, the only thing I see when I open the door is a plastic shim-like piece on the bottom right side of the door opening. I have not taken the door apart yet; wife doing the dishes!...so I have not ordered the part yet from Sears because I am still not sure where the leak is coming from on the inside. As soon as the cycle ends, I will break into the door and see what I find and let you know. We are set to go on a trip early Fri morning, so unless I can get it fixed this evening, it will be middle of next week before you hear from me again.
    Thanks for help so far. I have some things to do.
    Clisten Wells
    Indianapolis
    Guru:
  • 262 Answers
If it is the last cycle it is surely the vent....
Using a mirror you will be able to look up into the inner door somewhat and see that the leak is about 6 inches in from the side.
Please post your entire model number and I will be able to show you where this is coming from and how to repair it.
Link for all appliance model numbers.
Please post your entire model number.
After you have clicked on the link below....
Just to the right of the "search" tab click on "help me find my model number"
Just click on the model of your choice In either video or image presentation
Then please repost the information.
Click on the link http://www.repairclinic.com/Appliance-Parts
Thanks....
Keith
Posted on Mar 21, 2011
  • Keith Drake
    Keith Drake Mar 24, 2011
    Here is a parts diagram link for your unit and the area we will be working on.part number 19....vent with seal.
    Click on the link http://www.searspartsdirect.com/partsdir...
    You will need to take apart the door to access this part.the video link below will show you how to do this. The first 31 seconds of the video.
    Click on the link http://www.youtube.com/watch?v=cqt7BNVqk...
    To ensure this is the part that is bad the insulation around the part should be wet/damp.
    But if it only leaks during the last cycle as stated then this will be the issue. Check any other parts that may be connected to it and ensure they all are fitting properly. You can also run the dishwasher without the front panel on and watch for the leak.
    If you require further assistance please post.
  • Keith Drake
    Keith Drake Mar 25, 2011
    Hi Clisten
    If the leak is not happening during the last cycle then it probably is not the vent that is leaking.
    But when the door seal leaks it usually happens when it goes into the wash cycle, when wayer is being thrown up against the door. If you to decide it is the door seal replace the two deflectors on each side also.
    Part number 12 on the parts drawing link posted below.
Dishwasher Leaking Water Front left side (when facing)
Had a similar situation with my dishwasher. Turned out there was some hard water build up on the rubber gasket. I would start there first. I would not use any harsh chemicals on it, (it may jeopardize the gasket) it usually flakes off. Hope this helps.
Nov 20, 2013 | Maytag Dishwashers
Dishwasher control light blinking
1 Press down the overfill protection float on the floor of the dishwasher's tub in the right, front corner near the door. If it cannot move up and down freely, the "clean" light will flash.
2 Make sure the dishwasher's water supply is turned on.
3 Look for suds on the inside of the dishwasher and wipe them off with a wet cloth. If the washer's sensor detects suds or foam, it may not run. Use the correct amount of dishwasher soap, not hand soap or detergent for washing dishes in the sink, to ensure suds and foam do not form. Also, make sure the cap on the rinse aid dispenser is secure--this will keep suds and foam from forming as well.
4 Close the dishwasher door. Push the "normal wash" button, then push the "heated dry" button. Push the "normal wash" button again, and push the "heated dry" button again.
5 Watch for all of the lights on your Kenmore dishwasher's panel to turn on and then turn off. The washer may start a new wash cycle at this point; if you do not want it to do so, press the "cancel" button. Otherwise, allow the dishwasher to run through this cycle.
Nov 25, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Today, dishwasher started overfilling, and spilling water onto the floor. We turned off the water supply and let the dishwasher finish its cycle, turned on the water, started another cycle and it began to...
Hi
Thanks for using FixYa. If the dishwasher is overfilling it’s caused because of water-inlet valve going bad. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. If the water-inlet valve is defective, you need to completely replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 26, 2010 | Whirlpool 24 in. DU920PW Built-In...
When left the dish washer slowly fills with water causing flooding
Hi.
If the dishwasher fills when being left off, the tech must check for voltage at the inlet valve, then eventually replace the inlet valve.
If the dishwasher overfills during cycle, then test and eventually replace the water level device, usually a float sensor and switch.
Dec 02, 2009 | Bosch Dishwashers
ASKO 1385 not filling after overfill protection was turned on
If when turned on the dishwasher sounds like it is running the drain pump, and does this in any cycle setting, it is possible that the drain pan below the unit has filled with water. Check this post for more details.
Jun 27, 2009 | Asko 1385 Dishwasher
Icemaker leaking causing icicles
Is it overfilling with water? If so, it may be an problem with the fill valve leaking slightly. I say slightly because if it were a large leak, the freezer would have frozen puddles in it. Also check the water chute to be sure the water is all going into the freeze tray. Sometimes they can work loose.
If the seam is leaking, there could be a crack in the housing - not sure that's repairable - sometimes epoxy will work (5 minute, 2 part) but it can be difficult for glue to hold on the type of plastic used in an ise maker housing.
Mar 27, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Puddle on the floor, 36" diag. SW of Dishwasher door after cycle
TO MUCH SOAP RUN A FEW TIMES WITH OUT ANY AND STOP USE THE PACK OF SOAP
Dec 03, 2008 | Whirlpool 24 in. DU1055XTPS Stainless...
Dishlex Global 300 Dishwasher
Thomo, make sure the sprayer holes in the spray arms are clean. Grains of rice seem to be a dishwashers biggest enemy as they don't desolve and eventually end up lodged in the spray holes. The holes at the end of the spray arms are the ones responsible for the washing out of the soap powder from the dispenser, if they are blocked this does not happen.
Hope this helps
Cheers
May 29, 2008 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Leaking dishwasher
Are you washing cereal bowls or mixing bowls on the bottom rack? If so, are you placing them in front? Sudden leaks that form huge puddles can often be attributed to improper loading of the dishwasher. Most dishwashers don't have a seal across the tub front. The door closes over it and does a pretty good job of deflecting water back inside the wash cavity. However, if you place bowls in the front on the bottom rack rack they can divert the water right over the tub lip and onto the floor. This is usually the culprit that causes most leaks in dishwashers. Now, if you don't think you have a loading problem, remove the kick panel on the bottom of the dishwasher and check the drain line and pump housing for leaks. Check the door gasket for tears or cracks. Lastly, feel inside the bottom of the door with your hand. You should be able to feel the door insulation. If it is wet, then the problem could be a leak around your soap or rinse-aid dispenser. Depending on the model, some dispensers are mounted to the door with a gasket behind it. Sometimes this gasket can form leaks. I hope this helps.
Jun 05, 2007 | Maytag 24 in. MDB3700 Built-in Dishwasher
Dishwashers Logo
43 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
