Question about NetGear WNR2000 Wireless Router
Port forward emule - NetGear WNR2000 Wireless Router
  • 27 Answers
This should help. Its the exact instructions you need to forward ports with emule and your Netgear WNR2000:
http://portforward.com/english/routers/port_forwarding/Netgear/WNR2000/eMule.htm
Posted on Mar 21, 2011
Any one know how can I configure forwarding so my emule will work
Port forwarding is very easy task with Router Commander program. Install it and this program will forward ports automatically. Router Commander speeds up slow Internet via router and prevents router from dropping connections also.
Oct 05, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Port forwarding of Router D-Link DI-634M
Yes this router has a port forwarding capability, to know about that and how it is done from this router check this link.
http://portforward.com/english/routers/port_forwarding/Dlink/DI-634M/DI-634Mindex.htm
Feb 23, 2010 | D-Link DI-634M Wireless Router (DI634M)
How do u change your nat settings to open
you can't just say nat is now OPEN :)
let's say you have a pc with IP of 192.168.1.33
you are running a emule (hehe) on that PC
you want to use port 12345 for your emule
this is what you need to do:
1. go to webinterface of your router (usually http://192.168.1.1)
2. go to menu network/nat/port forwarding
3.go to service->user define
4. in new window click "active", name it emule, start port 12345, end port 12345, server ip 192.168.1.33
5. click ok, apply, whatever and go to menu security/firewall/rules
6. choose packet direction wan to wan/router
7. click on ADD
8. change following fields: destination address - change to single address and change 0.0.0.0 to 192.168.1.33 and click on add, then close to it says ANY, mark it and click on remove
9. on same page under services click on edit customized services
10. choose number 1 or 5 or whatever :)
11. service name: emule rule, service type TCP/UDP, type single, port 12345
12. click on apply
13. go to menu maintenance/tools/restart
14. just in case restart the box and your zyxel is now accepting incoming connections on port 12345 and forwarding them to 192.168.1.33 (your pc) ...
i hope i helped
cheers
-tomba
Jul 28, 2009 | Zyxel P660HW-D1 Router
I have a Zyxel P-660r-d1 modem and I connect to it with my ps3. But I currently have a NAT type 3, and I have some problems connecting with friends online. How do I change it to NAT type 2?
i will repost my guide for opening nat and firewall on a zyxel ...
it will help for sure ...
7. click on ADD
8.change following fields: destination address - change to single addressand change 0.0.0.0 to 192.168.1.33 and click on add, then close to itsays ANY, mark it and click on remove
12. click on apply
14.just in case restart the box and your zyxel is now accepting incomingconnections on port 12345 and forwarding them to 192.168.1.33 (your pc)...
i hope i helped
cheers
-tomba
Jul 01, 2009 | Zyxel Prestige 660R Router (P660R)
How to forward port to get high ID in emule
Here is how to set up port forwarding for emule: http://portforward.com/english/routers/port_forwarding/Linksys/WRT160N/eMule.htm If you use emule Plus see here: http://portforward.com/english/routers/port_forwarding/Linksys/WRT160N/eMule_Plus.htm
Jun 07, 2009 | Linksys WRT160N Wireless Router
Saving port forwarding configuration
To make the change permanent, click Tools and select System commands,
on the system commands click save all.
Aug 26, 2008 | Cnet Wireless-G CAR-854 Router (CAR854)
Cant get decent speeds from u torrent
I recommend checking out http://portforward.com/english/routers/port_forwarding/Belkin/F5D7230-4/eMule.htm
This is a great tutorial on configuring port forwarding on your particular router. This example is for emule but it will be very similar to uTorrent. You will want to determine what port uTorrent is configured to send data on and use that accordingly.
Jacob
Mar 18, 2008 | Belkin (F5D7230-4) Router (587009)
Emule lowid
I am sorry, but I would not listen to advice that you need to disable your Firewall for it to work!?!
Obviously as the response shows, even with the Firewall disabled it did not work [and would be vulnerable to attack]
There are two possibilities off hand:
  1. You have not taken into account forwarding ports in your Router as well as Software Firewall [if applies to you]
  2. Your ISP may be aware of using the ed2k protocol and try to stop you from using eMule
Remember to use the OBFUSCATION option.
This option in eMule allows you to connect to a server in a way
that masks or 'hides' the ed2k (eMule) protocol
Go To Options > Security
Here you'll tick the "Enable Protocol Obfuscation" box
Remember to only tick the first box under "Protocol Obfuscation"
You should be able to see your 'hidden' status on the right side
of the server window in eMule
If your ISP was in fact interfering, this should help you gain back your ability to use eMule without restriction
Oct 06, 2007 | D-Link DI-707P Router (DSDLDI707P)
How to port forward using Dlink DI-524 for Emule?
DMZ is a feature that is included on some routers but is not in Internet sharing software. A DMZ allows a single computer on your LAN to expose ALL of its ports to the Internet. When doing this, the exposed computer is no longer ?behind? the firewall. Port Forwarding vs DMZ A DMZ is far easier to set up than port forwarding but exposes your entire computer to the Internet. Sometimes TCP/IP applications require very specialized IP configurations that are difficult to set up or are not supported by your router. In this case, placing your computer in the DMZ is the only way to get the application working. Placing a computer in the DMZ should be considered ?temporary? because your firewall is no longer able to provide any security to it.
Oct 03, 2007 | D-Link AirPlus DI-524 Wireless Router
Low ID on eMule
One more thing re low id on emule - try to choose ports between 10000 and 60000 - many isps block the standard ports that emule users choose, and you will see people saying to choose one over 5000, but I'd chosen ports between 5000 and 10000, and still had no luck until I went over10000.
Most isps don't monitor ports over 10000, so if you still have low id problems even after port forwarding and setting up your firewall, this may be the answer to your problem! (I got this info off portforward.com, and it worked for me)
Feb 16, 2006 | D-Link DI-707P Router (DSDLDI707P)
NetGear WNR2000 Wireless Router Logo
198 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
