Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Ld code, handy husband took complete washer apart, and found nothing weird. It will drain into a large trash can, but will not drain up the wall like it has for three years, is it the drain pump?
    Sergeant:
    Novelist:
  • 196 Answers
It is possible that 1 of the blades on the impellor of the pump has broken off which would mean that the height it can pump will be reduced.
Posted on Mar 21, 2011
The screen on my washer is saying the code LD i dont have a manual and it wont drain completly. I took my clothes out and they were completly soaked with water. HELP! :D
The LD fault code indicates that the washer took longer than 5 minutes to pump out the water and reset the water level pressure switch. You should be able to press STOP/CANCEL to clear the display.
Check you drain hose for kinks or clogs. You could have a clog or failure in the drain pump that is causing this problem
Jan 12, 2011 | Kenmore 22062 Top Load Washer
Ce code and leaking water after repair of the ld code. Ld code was present and the washer was full of water. Took washer out and turned over removed the drain motor and took it apart and cleaned out all...
CE Communications ErrorIf there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Oasis is beeping with an error code of Ld
LD code is long drain,one of two things the drain pump is frozen and need to be replaced or there is somthing in the pump.Pull the washer away from the wall a bit and get a bunch of towels.Lean the washer back against the wall towards the middle in the back you will see the pump take it apart and find the clog.
Apr 10, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
CE code and leaking water after repair of the LD code. LD code was present and the washer was full of water. took washer out and turned over, removed the drain motor and took it apart and cleaned out all...
Mar 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
My washer stopped and flashed Ld. I took out the
Hi
Thanks for using FixYa. Error code LD means Long Drain. It flashes when washer takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. Press STOP/CANCEL to clear the display. Common causes for this are kinked drain hose or clothing, like panties or socks, caught in the pump suction hose.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 12, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis Ld code
LD code is long drain one of 2 things the drain pump is frozen and need to be replaced or there is somthing in the pump. Pull the washer a way from the wall a bit and get a bunch of towels. Lean the washer back against the wall towards the middle in the back you will see the pump take it apart and find the clog.
it can be assessed through the bottom.
May 06, 2009 | Kenmore Oasis 27042 Top Load Washer
Oasis washer has Ld CODE runs will not drain.
May 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Calypso washer Ld code?
I just had the same problem. I borrowed my neighbors wet vac. The hose of the wet vac fit right over the end of the drain hose and I sucked out all the remaining water. My hope was that if the hose was clogged that it would clear it out. It seems that it worked. I put the drain hose back in the drain and turned on the extended spin cycle. It was working, so I put the water logged clothes back in the washer on the extended spin cycle and it took the water out. I am now in the process of washing another load to see if it really fixed the problem. I hope this helps.
Jan 18, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite LD Error
LD means long drain. First check to make sure that there is nothing stuck inside your drain hose. The next thing to check is your pump. lean the washer back and locate the pump. Next take it loose and clean out any debrit inside it. That should take care of it. If not check your lid switch.
Nov 17, 2008 | Washing Machines
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
