Question about Magic Chef CYE4000AWW Electric Dryer
I push timer to start and nothing - Magic Chef CYE4000AWW Electric Dryer
  • 1 more comment
  • rgipe2 Mar 21, 2011
    thank you for the first idea but i checked the fuse as directed it is good know what?
    thanks for the help i did not know about the small one on the side that was it IT WORKS THANKS AGAIN
    The help with looking for the small fuse on the side of element was right on the money. THANKS FOR THE HELP IT WORKS!
  • Magic Chef Master
  • 2,605 Answers
Welcome to FixYa.
Based on what you're describing " push timer to start and nothing " the hi-limit thermostat is likely tripped/open.
The hi-limit is located under the top of the cabinet in the left rear corner attached to the heating element housing.
The replacement comes in a kit as shown here...part # LA-1053
You may find this link helpful for purchasing & testing the existing thermostats, but the new does come with instructions.
http://www.repairclinic.com/PartDetail/Thermal-Fuse-and-High-Limit-Thermostat/3344#repairHelpVideoTabs
Let me know if you need further assistance or directions and I will help in any manner I can. Good luck.
Thank you for choosing FixYa today.
Regards,
Macmarkus :)
Posted on Mar 21, 2011
  • Mark MacDonald
    Mark MacDonald Mar 21, 2011
    Hello again,
    Thank you for the reply.
    To be clear, did you check both the thermostats located there ( by the element ) ? Only the small one on the side is a fuse type hi-limit (non-reset), but I want to be sure you know that.
    Again, Let me know and I will help in any manner I can from here. It could also be the door switch, but I want to make sure the hi-limit/fuse can be ruled out or we'll go in circles.
    Regards,
    Macmarkus :)
Dryer has power to timer, but won't start...I have an Amana electric dryer that allows me to set the timer and I can hear it running, but when I push in the the timer knob to start the dryer (drum
The fuse is mounted on the heater element. When it blows nothing in the heater or motor circuit works but the power to the timer is not interrupted therefore you can hear. Service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 11, 2013 | Amana Dryers
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
The dryer timer knob won't set, therefore when you push to start, nothing happens
Try to twist the outside ring around the timer knob. The knob could be faulty and freewheeling, so turning the outside ring (I'm assuming you have a mechanical timer, not an electronic one) does the same thing as turning the knob while it is "out". When you've set the timer, then push the knob in to start. Hope this helps - I made some assumptions about your machine that I hope are correct... Good luck.
Nov 28, 2009 | Dryers
Dyer will not start-Start button seems to be the problem
This may be your timer or your start switch may be bad. Hope this helps!
Aug 14, 2009 | KitchenAid KEYS700LQ Electric Dryer
Dryer timer or start will not work
Yes, it does sound like the timer. You could do an ohms test if you have the ability but timers aren't too terribly expensive or hard to replace anyway.
Apr 08, 2009 | Kenmore Dryers
My whirlpool dryer wont start.
check the door switch and also the push to start button. Timers will advance even if the unit is not on
Mar 30, 2009 | Dryers
Batch complete sounds when start button is pushed
door switch or timmer or the knob on the timer may not be turning the timer
Nov 27, 2008 | Maytag PYE2300AY Electric Dryer
Dryer won't start
Check your door switch and wires to see if they are damaged first.You may have a bad Start Switch.If it is a 2 wire switch you can tape them together and then plug in dryer ,if it starts,replace the Start switch. Please Rate this!
Jun 12, 2008 | Kenmore Dryers
Magic Chef CYE4000AWW Electric Dryer Logo
332 people viewed this question
Top Magic Chef Dryers Experts
Tim Whalen
Wayne Fellows
Wayne Fellows
Craig Butler
Craig Butler
Are you a Magic Chef Dryer Expert? Answer questions, earn points and help others
