Question about Toys
Hi i have a power wheels mx3 mini bike my son took off the rear wheel and 6 washers & 3 metal sleeves or spacers fell out no idea how they go back in.model # 73535. Called power wheels they dont have a diagram not shown in the owners manual cant figure out how everything goes back together. thank u
  • 5 Answers
SOURCE: where to find manual or diagrams for Tasco scopes
The manual is here under "Generic Riflescopes". It is a .pdf file.
http://www.tasco.com/support.cfm
The Tasco site for Riflescopes
http://www.tasco.com/section.cfm?s=Riflescopes
Posted on Jul 19, 2008
scrodamoon
  • 659 Answers
SOURCE: hot wheels track
im gonna say that your best bet would be to go to the mattel website and go to the customer relations click here for the complete list of "hot wheels track" will take a bunch of searching here but unless I see all the peices not sure if I can be of much help trying to match them up to certain sets.
Posted on Aug 09, 2008
iqbalq
  • 41 Answers
SOURCE: How do you change from low speed to high speed?
hi
there is a swich in the back of the car (L/low and H/high)
try it on high .
i hope this will work
Posted on Jan 06, 2009
SOURCE: Kettler Air Navigator Tricycle
My husband and I just put this trike together and had a similar problem - the front wheel always turned the pedals and we couldn't figure out how to stop this. The manual for the trike is awful and very hard to understand. After spending a LOT of time analyzing the pictures and doing all sorts of weird things to the pedals, I found a posting on a website that said they'd had the same problem, but had removed and re-attached the front wheel and the problem was suddenly fixed. Sounds too good to be true, right? Well, we noticed that in one of the manual's pictures that the air valve for the front tire was facing the other direction - we'd actually put the tire on backwards. I took the tire off, put it back on facing the other way, and suddenly it all works as it's supposed to.
The thing is, you actually don't have to "do" anything to change from free to fixed and keep the pedals stable. If my daughter pushes the pedals around, they move around, and if she keeps her feet steady on them, the wheel continues to go around while the pedals stay put. It truly is automatic, which the diagram in the manual does a terrible job of conveying.
Hope this helps someone. We like this trike, but the directions are beastly!
Posted on Mar 09, 2009
SOURCE: need to replace wheels on sons power wheels
I just replaced the wheels on the red Fisher Price Kawasaki Brute Force. First use a screw driver to pop off the grey middle nut cover. Then pull of the locking nut with black cap that is under the grey cover you just removed.
Once that is removed the wheel comes right off. There are 4 phillips screws holding the hubs together. Unscrew those and the hubs separate into to pieces (one on each side of the wheel).
Simply place the hubs into the replacement wheels and screw back together. Slide the new wheel on (make sure the washer is still on the rear side of axel).
My replacement wheels actually came with the black replacement locking nuts taped to them. Hammer the replacement locking back on the alex, pop the grey hub cover back on and you are done.
If you are missing the locking nuts, take one of the originals you removed with you to the hardware store and you should have no problem getting them. - MTRAGE
Posted on May 24, 2009
How to remove 2008 rear wheel fatboy
To remove a 2008 Softail rear wheel FIRST block motorcycle underneath the frame so that theweight of the motorcycle is off of the rear wheel, remove saddlebags if equipped, remove the belt guard and the debris deflector from the rear fork, inspect the wheel bearing end play and service the bearings if and as necessary, label the wheel spacers for left or right locationand orientation i.e. fork side or wheel side, remove the rear brake caliper from the caliper mount and support it using an elastic cord or such,For the FXCW/C modelsthe nut retainer will remain in the axle nut and does not need to be removed and if it is removed it must be replaced. For all but FXCW/C remove e-clip, remove the rear axle nut, and for FXCW/C remove the rear axle nut, loosen both axle adjuster screws an equal number of turns to remove tension from drive belt, with a suitable drift or other tool tap the axle towards the right side and remove it, remove the spacers and the caliper mounting bracket, move the wheel forward and slip the belt off of the sprocket, raise the motorcycle to allow enough clearance for removal of the rear wheel and pull the wheel with the belt sprocket from the rear fork.
To install a 2008 Softail rear wheel FIRST apply a light coat of wheel bearing grease to the axle, to the bearing bores and to the bore of the inner sleeve, roll the wheel into place in the rear fork and slide the drive belt over the drive sprocket, position the left bearing spacer between the wheel and the fork, from the right side carefully insert the axle (with its washer for FXCW/C models) through the right rear fork, the short spacer, the rear caliper mounting bracket, the long spacer and into the bearing bore, continue sliding the axle through the wheel hub sleeve, the left side spacer and the left rear of the fork, install the washer, the axle nut, and the retainer, verify correct axle alignment and the check belt deflection, check the wheel bearing end play after tightening the axle nut to the specified torque because excessive end play can adversely affect stability and handling and insufficient end play can cause bearing seizure, tighten the axle nut to 95-105 ft-lbs (128.8-142.5 Nm), install the belt guard and the debris deflector, install the brake caliper and pads, install the saddlebags, if equipped, pump the brake pedal to move the pistons out until they contact both brake pads, verify the piston location against pads, verify the position of the brake pads against the brake disc, rotate the wheel to check for any interference(s) or misalignment(s) and test the brakes for proper operation.
May 12, 2014 | 2004 Harley Davidson FLHTCUI Electra Glide...
Why are the rear wheels locked up on my toddlers schwinn tricycle?
I took the fenders off to give a little more space for the wheels to move. Don't tighten the nut and washer right up against the black plastic spacer on the rim. Schwinn should be sending out locking spacers or nuts to fix the problem, but I don't see that happening.
Sep 23, 2012 | Pacific Cycle s Schwinn Roadster 12"...
1984 Honda GL 1200 Aspencade Gold Wing rear wheel spacer question
Hi, Phillipketch for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Rear wheel final drive GL1200 Information Questions goldwingdocs com
GL1200 Rear flange or hub sleeve
Honda GL1200D Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda GL1200 1986 Owner Manual
Mar 16, 2011 | 1984 Honda GL 1200 Aspencade Gold Wing
I have a flstc with factory date of 10/91. front hub had no axle sleeve parts book shows 3 sleeves for 91 only may be mis print. should there be a axle sleeve? the rear has one and shows as white or 4.448...
To be honest with you, I don't know. You would have to refer to a service manual specific to your model bike. I do know that it it supposed to have a sleeve in it. The length of the sleeve would be dependent upon the type of front end you have and the machining of the wheel hub itself. You would want the lenght of hub that would wind up with the fewest number of shims in the hub. As I've inferred, the assembly also has a special washer and shims in there as well. You add or subtract shims until you get an endplay of 0.002" to 0.006". Although my service manual doesn't show them, there mey be two short sleeves that go inside the wheel bearing seals on either side of the wheel. I would look in a parts manual for the recommmended parts and start from there. If you can get hold of a 6" caliper, maybe you could measure between the surfaces that the bearing races seat against, subtract for the thickness of the special washer and a few shims to determine what length spacer you need.
Good Luck
Steve
Aug 19, 2010 | Harley Davidson FLSTC - FLSTCI Heritage...
How do you remove the drive shaft on a 1984 honda 700c to change the rear tire
HI AM I CORRECT IN SAYING THIS BIKE HAS A DRUM BRAKE, AND A SIMPLE SPINDLE, SPACER AND NUT FITMENT, IN THE OLD DAYS HONDA USED A SPLINED WHEEL ATACHMENT TO THE SHAFT BELL HOUSING, WITH THE BIKE ON A STABLE FOOTING, REMOVE THE NUT, SPINDLE &, SPACERS, THIS SHOULD THEN GIVE ENOUGH SPACE TO REMOVE THE WHEEL FROM THE SHAFT HOUSING, A SLIGHT WOBBLE WHILE PULLING THE WHEEL OF THE DIFF IS NORMALY ENOUGH TO REMOVE THE WHEEL,MAKING SURE NOT TO PULL TO HARD AS TO AFFECT THE STABILITY OF THE MACHINE ON ITS STAND, USE OF A GOOD LUBRICATION IS RECOMENDED ON REASEMBLY OF THE SHAFT SPLINED GEAR, HOPE THIS HELPS
Aug 03, 2010 | 1984 Honda VF 750 S
What is the sequence of putting spacers on rear
Not much on newer hogs but I'd guess if the spacers aren't the same length when you got the wheel on you'd see that the wheel isn't centered.Try again.Put the end thru the swing arm put on a spacer,push it thru the hub,put on the other spacer,push it thru swing arm put on washers and nut[loosely]and check the alaignment.Like I said I'm not much.
Mar 03, 2010 | 2005 Harley Davidson FXSTB - FXSTBI Night...
Toys Logo
187 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
