Question about Sharp R-316FS Microwave Oven
Hello My name is Mohamed. I have a sharp microwave oven model R-316FSU, I am having trouble opening the door. The latch seems to stick. How can I fix it?
    Brigadier General:
  • 8,909 Answers
Door catches.
One of the latches may be damaged or misaligned and is not lifting the other latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When the door levers are in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Posted on Mar 21, 2011
Microwave door latch stuck
First of all, Do you have it on a level surface?
Jun 30, 2017 | Sharp Microwave Ovens
I opened the door on my sharp microwave and now it wont latch. it sounded like something snapped off where the door latches to the microwave, not the door itself . Even if the door is held shut the light...
It may be the latch head spring or the door open lever or button.
DOOR SPRING LATCH HEAD HOOK
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
you have to separate the door panels (as shown in the attached photo) and then you'll see how it goes together.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
DOOR OPENING BUTTON LEVER
What usually breaks is the door open lever, but it may also be that the rear side of the door open button has worn down too far to work.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can usually find exploded views and part numbers for Sharp models by entering your model number at the Sears parts site.
If not, let me know. We have many Sharp manuals and if we have yours, we can link you to it at no charge.
The best place to order Sharp parts is
Encompass (formerly Tritronics).
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Oct 10, 2009 | Sharp R-1480 Microwave Oven
Sharp Microwave model R-1850A door won't open
buy a boddle of WD-40 and try spray some in the raded spots.Im not a big specialist in microwaves.hope it helps
May 10, 2009 | Sharp R-930AK Convection/Microwave Oven
Door won't latch/microwave won't turn on
The door does come apart. Open the door and where the hinges are, there are openings where the hinges enter the door, this plastic piece (goes all the way around the door) With a small flat blade screws driver VERY carefully pry it (plastic) off, once off, check the latch end for the spring, typical failure for a Sharp is the little tab that the spring hooks to on the door, the only way to repair this so it will last is to replace the door frame. they are not too expensive, about $50 or so Part# FCOVB166KIT
is the door frame assy
Jan 07, 2009 | Sharp R-1405 / R-140 Microwave Oven
Microwave door does not latch; oven does not work
We have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Dec 22, 2008 | Sharp R-1405 / R-140 Microwave Oven
Front door closes on a model R-1610-11-12 but light does not go out and microwave cannot be started up. Door does not seem to latch in place. In lower door latch inside the microwave I can see a plastic...
hi check that the door catch is locking into place maybethe locking mec is not engaging or triping the micro switch ,if it does n't trip the switch it won't turn light off and unit won't work
cheers grant
Oct 22, 2008 | Sharp Microwave Ovens
Hi ,there are two posibility to repair . 1. by ordering parts to the web site of sharp .
2. You may check from shop same type of part bring sample or in the appliances center near you.
Jan 14, 2008 | Sharp R-1850A Convection/Microwave Oven
Sharp microwave R1940
The latch head (the assembly with the hook-like parts sticking out) also has a spring which secures it to the inner door panel. The inner door panel or latch head has a broken spring mount. To repair this, the door panels will have to be separated. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find a helpful exploded view diagram of this model at http://www3.sears.com You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Apr 13, 2007 | Sharp R-1490 Microwave Oven
Sharp R-316FS Microwave Oven Logo
114 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
