Question about White Sewing 2999 Mechanical Sewing Machine
How to put bobbin back for white 2999 model - White Sewing 2999 Mechanical Sewing Machine
3 Suggested Answers
SpotBert
  • 231 Answers
SOURCE: white sewing machine model 2999
Winter 2002 was when it was first released. Retail of $499.00.
Contact White Sewing Directly for parts =>
http://www.whitesewing.com/customer.asp
Posted on Jan 04, 2009
bargainbox
  • 1388 Answers
SOURCE: The needle on our White model 2999 will not pick
Bobbins don't spin, the hook beneath is the moving force.
Check the timing of the needle to the hook. Here is a guide to generic principles of Timing
http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
Posted on Sep 04, 2009
Needle thread timing
Bobbin is not moving, sounds like a broken gear, not a timing problem. Bring it in for service.
Apr 03, 2014 | White Sewing 2999 Mechanical Sewing...
The machine wont sew - the needle will go down but wont come up again
I think your machine was stick. So you check the timing and change the correct size bobbin case.
Feb 19, 2014 | White Sewing 2999 Mechanical Sewing...
When i try to stitch it won't let me and instead says "wind disable", how do i fix it?
Wind disable means you're in the bobbin winding mode. The chrome shaft on the right end of the top of the machine is pushed to the right. Push the (bobbin winder) shaft to the left side of the slot and you should be able to sew again.
Jan 19, 2011 | White Sewing 2999 Mechanical Sewing...
Misplaced manual_how to drop feed dogs on White 2999?
I cant find the usermanual onsite from the white website however, they do have a customer service dept - its possible they will send you are replacement manual http://www.whitesewing.com/customer.asp
Mar 13, 2010 | White Sewing 2999 Mechanical Sewing...
The needle on our White model 2999 will not pick up bottom thread - the bobbin may not be spinning
Sep 04, 2009 | Sewing Machines
The bottom stitch jamming up
seems like the same problem I haad so I tried changing the needle looking for burrs or bent needle. maybe a piece of broken needle in the bobbin holder. or maybe the fabric requires a certain needle or the needle size is too big for the fabric you are using. or the machine needs cleaning I have started using canned air for this. and then if this fails then you should note the tension position and then try adjusting it one point at a time. always puting it back to where it was to start with good luck
Feb 24, 2009 | White Sewing 2999 Mechanical Sewing...
White 2999
It looks like you have no tension on the bottom thread. Make sure the bobbin thread is in the tension spring, and that there is no lint under the bobbin tension spring. You may just need to increase the bobbin tension, it is one of the two small screws on the tension spring itself (not the one on the end, the one in the middle).
Try an online repair tips site to see what this all means if you need to.
Jan 31, 2009 | White Sewing 2999 Mechanical Sewing...
White sewing machine model 2999
Jan 04, 2009 | White Sewing 2999 Mechanical Sewing...
Bobbin filling
The handwheel may have a pull out/push in action to disengage/engage the clutch, or it may automatically disengage when the bobbin winder is moved to the right for winding........hold a short tail of thread to get it started and you should be away.
Move the winder to the left for sewing, or push handwheel in, according to the mechanism.
May 31, 2008 | White Sewing 2999 Mechanical Sewing...
White Sewing 2999 Mechanical Sewing Machine Logo
90 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
