Question about Garden
I need to take the PTO off of a STX38 hydro Can you give me a step by step way
  • 1 more comment
  • Patrick Townes Mar 21, 2011
    removing the bolt is where I am having the problem How do I stop the crank from turning and is it loosened clockwise or counter Thanks
    I got it thanks
    Got me going
    Brigadier General:
  • 3,513 Answers
Hi
Unplug the connector wire. Take the tensioner spring loose for the deck belts, then slip the belts off of the pulleys in the front of the mower right below the engine. There is a single 5/8" bolt than comes out vertically on the bottom of the PTO clutch. Take that bolt out and make sure the 2 belts are slipped off of the pulleys and the PTO clutch should drop right down. Make sure and remember how the spacers and the square slip pin goes in the pulley assembly above the PTO clutch. Install back in the reverse way that you removed it. However it also helps give you more room to work if you lower the mower deck all the way "down".
Please get back to us if you have further query else please accept the suggestion.
Posted on Mar 21, 2011
John deere stx 30 pto wont engage
Check your fuse or for a broken wire( or shorted)
Jul 19, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
Why wont john deere stx 30 pto wont engage
Most of these mowers have a safety switch between the PTO switch and clutch. A safety switch or relay is most likely the problem. Hope this will help ya.
How do I remove the bolt holding the electric PTO for the blade engagement on stx38 hydro John Deere
The best way is with an impact wrench, you may try a long rachet or breaker bar and hitting it briskly with a hammer. Do not attempt to "jam" the motor, that usually does not turn out well.
Jul 18, 2014 | Garden
Need to know dose a stx 38 john deer mower have a pto relay or fuse
Yes, it has a relay located under the seat on the right side of the battery
Aug 27, 2013 | John Deere Pto Clutch For Stx38 And Stx46...
I have a john deere stx38 and it has no spark and wont fire but engine turns over
Check the shear pin in the flywheel, replace if bad, should cure your no spark problem
May 28, 2011 | John Deere Pto Clutch For Stx38 And Stx46...
Can i have a belt diagram for a john deere stx38 please , thanks pete
http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt
Click on the above link then do a "model search"
click on which model (either yellow deck or black deck)
alphabetically pick which belt,
a diagram should appear in the right hand corner.
Or you can try the link below.You will need to sign up(free I think)
http://www.pdfph.com/pdf/john-deere-1999-stx38-hydro-deck-belt-diagram/
The link below has a picture of the belts on a yellow deck.
http://www.askmehelpdesk.com/tools-power-equipment/installing-belt-jd-stx38-hydro-385391.html
May 16, 2011 | John Deere Garden
I have a john deere stx38, has no spark. Engine turns over fine but will not fire. JW
Check the HT lead for cuts or breaks and then replace it anyway then check the on/of switch for rest
Jul 09, 2010 | John Deere Pto Clutch For Stx38 And Stx46...
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
