Question about Casio DR-250HD Calculator
MY CALCULATOR HAS AN E ON DISPLAY SCREEN AND NOTHING WILL WORK. HOW CAN I SOLVE MY PROBLEM?
Mem cleared Changed out the batteries and received a messege mem cleared and nothing will work.
Follow this steps to resolve this problem:
1. Press ON to turn calcilator on
2. Press 2nd and then press + key button. TI- 81 displays RESET menu
3. Press 2 to select the RESET, the second item in the RESET menu. The display shows the message Mem cleared. Press CLEAR to clear the screen
If you cannot see anything on the screen, you may need to adjust the graphing TI- 81 calculator contrast:
-To darken the screen, press and release 2nd key, and then press and hold up-arrow key until the display is sufficiently dark
- To lighten the screen, press and release 2nd key, and then press and hold down-arrow key until the display is sufficiently light
Aug 22, 2012 | Texas Instruments TI-81 Calculator
When I turn on my calculator, 1/3 of the screen is blank. When I enter numbers, they show up after the blank side. Basically, the left side of my screen stopped working, and it has nothing to do with...
The problem is in one of driver ic's that controls the LCD display is malfunctioning, the only way to correct the problem is replace the ic, this will require a technician.
Jan 14, 2011 | Texas Instruments TI-83 Plus Calculator
When I press ON, my calculator screen displays a couple random numbers and letters scattered across the screen, including a solid vertical line in the upper right corner. As soon as I push any key, the...
There are three possible solutions here. From what you are describing to me, you say the screen displays a couple of random numbers and letters, including a solid vertical line in the upper right corner, are scattered across the screen? Sounds like you are still in graphing mode. There is nothing wrong with your batteries and changing them won't help because I already know that you didn't change the CR Lithium Battery. This is the "memory card" for the TI-83 Plus. If you don't change that, when you insert new AAA batteries in the calculator, the memory has not been deleted. You probably don't remember, but the calculator remembers the last problem that you did, which was a graphing calculation. Try pressing the "Graph" button and the calculator will go back to function mode. If this doesn't work, try resetting all the memory.
  1. Remove a battery from the battery bay.
  2. Press and hold the CLEAR button while re-installing the battery.
  3. While still pressing the CLEAR key, press and hold down the ON button. If the home screen displays, release the keys.
  4. If the home screen is displayed, press 2nd MEMto display the memory menu.
  5. Select 7:Reset to display the "RAM ARCHIVE ALL" menu.
  6. Press the right arrow twice to display the "ALL" menu.
  7. Select 1:All Memory to display the "RESET MEMORY" menu.
  8. To proceed with the reset, select 2:Reset. The message "MEM cleared" is displayed on the home screen.
If this doesn't work, try changing the CR Lithium Battery. It is located in the battery bay at the top with the cross-head screw in it (It says BACK-UP BATTERY). It tells you what type of battery it takes and how to insert them in. I hope these possible solutions help. If all of them don't, then the only other thing I can think of is that it has some internal part alignment issues or a cold soldering iron blob, on the inside of the calculator. I saw one time on the Internet that cold soldering irons can sometimes make electronics not work properly.
I can't get any keys to work on the calculator
Having received no response in over a month, I assume the reset solved the problem.
Jul 08, 2010 | Texas Instruments TI-83 Plus Calculator
Problem with casio calculator, model 9850g plus
The Solve( command can be accessed in RUN mode by pressing the OPTN button.
In the screen that is then displayed are TABS (at the bottom).
Press [F4:CALC] then [F1:Solve]
The command echoes on the screen, ready to be completed and executed.
Apr 30, 2010 | Casio CFX-9850G Plus Calculator
Graph button won't graph, then it exits and put's a 4 instead ?
It seems that wires got crossed. I suggest you reset all RAM by the follwing steps
[2nd][MEM][7:Reset][1:All Ram][2:Reset][ENTER]
Ram cleared will be displayed on screen. [CLEAR] to go to the home screen.
If that does not solve your problem, reinstall the OS. Post a question on how to install OS, if you want, or read some of the posts on TI83/84/89 about same subject.
If nothing works, I am afraid you will have to repair the calculator.
Hope it helps.
Sep 05, 2009 | Texas Instruments TI-84 Plus Silver...
My Casio fx-85v Super - fx solar power calculator shows a erratic
Yeah I had the same problem, you need to open your calculator and check if all the screen cables is alright, i had just put sellotape on the back of the screen from inside so that the screen hold better, and it works for me if for you not maybe something broken in the schema but try it. The thing I know for sure the problem is in the screen or from where it get the data the schema. Tell me if it's working
Jul 01, 2009 | Casio FX-115ES Scientific Calculator
Screen Displays nothing
If the screen in busted its easier/cheaper/quicker to buy a new calc on ebay for $20.
Feb 12, 2009 | Texas Instruments TI-83 Plus Calculator
Black screen
http://www.xnumber.com/arch3/arch3/000006ef.htm
Oct 03, 2007 | Texas Instruments TI-81 Calculator
Casio DR-250HD Calculator Logo
80 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
