Hi my themaltake tower wont stop beeping and wont boot up and dont know what to do
  • 77 Answers
It's a POST beep and it means that one of your computer components is not working properly.
According to this, one continuous beep means: Power supply, system board, or keyboard problem.
Posted on Mar 21, 2011
  • 36 Answers
Hello there, What kind of beeps are they? If it is a long beep followed by a moment of silence, then another long beep, It is a RAM problem. You will need to replace the RAM that has gone bad.
If your computer has more than one RAM module installed (you can check by opening it up), then you could try pulling the RAM out carefully and using one at a time, to locate the Faulty RAM stick.
RAM will look like this:
Only do this if you hear the beeps i described above, if you don't, then it is some other problem.
The tower turns on but does not boot the monitor
There could be a problem with the connection to your monitor.
Dec 21, 2013 | Gateway ATXSTF MNT Pro S P4 1500 Tower...
Gateway wont startup. One beep followed by two short
I would suspect the power supply or a power connection. The only other issue might be a motherboard, which is a bit more involved. Try another power supply if you have one around.
Nov 12, 2013 | Gateway GT5678 Desktop PC
My desk top pc wont boot up im getting the first screen and the bleeps but then nothing what can i do
If you are receiving continuous beeps, it means that computer is not recognising the RAM (memory). In this you have to open the Tower and follow the below steps:
1. Turn OFF the computer
2. Open the flap of the Tower (Remove the screws from the back of Tower)
3. Now, On the Motherboard you will be able to see the RAM see the picture nanjia.jpeg
4. There should be two pins to unlock and remove it
5. Once removed, clean the terminal and replug it.
6. Turn ON the computer, it should take care of the issue
Thanks and regards,
Nov 22, 2010 | Acer Aspire M5100 AM5100-U5313A AMD...
5 beeps are coming and after some time five beeps are repeating.system not booting
Hi ,
When you hear 5 beeps while booting or turning the computer off it is related to the operation of critical motherboard components - such as the CPU.Please try these steps to try fixing this problem .
Open up the computer tower and then once the side panel is out a test on the motherboard needs to be done and to do that look for the memory cards(Ram ) which would be green in colour,4 inches long and would be inserted in a slot that has clips in either ends that holds the card in the slot firmly.There can be one or more than one so remove the memory cards and then turn the computer on by just connecting the power cable,you should hear long beeping noise if you dont hear any then the motherboard needs to be replaced or needs to be serviced.
allthe best
May 20, 2010 | HP Workstation xw4200 PC Desktop
My computer tower wont stop beeping
Re-seat the memory.. more than likely they have unseated themselves during the dust cleaning. Beeping is usually caused by memory.. Beeps are usually a series like Morris code long..short beeps.. if re-seating the memory doesn't work, try swapping and removing different sticks and differnet locations on the motherboard, most motherboards have 2-4 memory banks or known as dimm slots.
Jan 16, 2010 | Ultra Products Ultra M923 Full Tower ATX...
3 beeps on boot no screen and boot stops
sounds like the motherboard trying to give you an error code. search beep codes for the type of motherboard you have and then you will get a possible cause of the interruption.
my friend once gave me an old ibm that had a beeping sound preventing it from booting. i googled ibm beep codes and learned that it was a video card error. i swapped the video card and problem solved
Jul 23, 2009 | Intel D850MV Motherboard
Computer tower started beeping
If you added more memory this may make your tower beep.
If so I WOULD REMOVE THE ADDED MEMORY AND THEN RESTART
Jan 12, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
It wont stay on
probably bad memory, 256MB DDR (PC 2100)
Jan 21, 2007 | E-Machines T2642 PC Desktop
Computers & Internet Logo
81 people viewed this question
Alun Cox
David Payne
David Payne
