Question about Weiser Lock POWERBOLT ELEC DEADBOLT
The lock opens correctly but will not lock. It looks like when it trys to lock, the motor pulls the deadbolt in the same direction as when it is opening.
  • 963 Answers
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
Programming/troubleshooting instructions:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Posted on May 09, 2011
New deadbolt notworking?
You have the lever that goes from the key cylinder part of the lock through the striker portion of the locking assembly turned part way, either in the wrong direction or not turned enough in the right direction so if you take the inside portion of the lock off and pull the outside portion out of the door and rotate the lever to its proper position and then put if all back together in the correct sequence it should work properly.
Sep 19, 2014 | Schlage Aged Bronze Grip Handle Entry Set...
I have difficulty locking the deadbolt with the key
If the lock works easily with the door open, the strike plate is not lined up correctly. If it is hard to turn with the door open, loosen all the mounting screws and be sure the inside and outside parts are lined up correctly. Also the latch is marked for correct installation. If upside down, it won't work correctly. All three parts need to line up so check for smooth operation before tightening the screws.
Jun 10, 2014 | Kwikset Locks & Locksmithing
The Schlage dead bolt is locked in and will not open with the outside key. I have no directions on how to remove the bolt flange from the inside. The small hole does not look like an allen wrench set...
Remove the entire knob assembly from the inside and pull it srtaight out. The metal linkage going from the lock to the knob/deadbolt is likely broken.
Jun 26, 2011 | Garden
Weiser keypad deadbolt lock deadbolt does not move when motor runs
Hi... You have too be sure that the deadbolt is free when it go inside the deadbolt hole... however this system is very low power and the (over torque clutch) will sleep if the deadbolt it's not completely free.
Also if you try to open the door before you unlock it, you may block the the deadbolt inside the deadbolt hole. Take care too unlock the door before open-it...
Dec 30, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
Bolt doesn't open all the way
You should replace your batteries as the motor that moved the deadbolt does not have enough power to move it with weak batteries. If that fails make sure the deadbolt moves freely when the lock is removed as the mis-aligned mounting will cause excessive force be exerted to move the deadbolt. See http://www.weiserlock.com/Support/Faq/50160000000HhbGAAS.aspx
Dec 13, 2010 | Weiser Lock ED1460X3VKD Powerbolt 1000...
The combination won't open the lock ...it takes 4 or 5 times to open the dead bolt all the way ...sometimes on the first try but mostly 5-9 tries .
Sep 29, 2010 | Weiser Lock Powerbolt 1000 Lock
Brought new keyless dead bolt. Put it in a door that opens in with hinges on right side. The problem is that the motor wants to turn the dead bolt the opposite direction, unlock extends deadbolt,...
My lock adjusted itself automatically... You have to hold the lock button in (on the exterior side) while you insert the battery pack - the deadbolt will cycle in and out, then beep a couple times. You'll be holding button for maybe 10 seconds.
I have to say while this step is included in the instructions in a big red box, it says nothing about why or what its doing, so I imagine many people miss this...
Aug 25, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
Dead bolt trys to turn in the same direction
Hi.
I think it can be possible that the bolt assembly is installed upside down.
Remove the unit, and refit with the bolt and faceplate the other way up.
Test WITH THE DOOR OPEN. to ensure correct function.
I am not familiar with this lock - but other weiser locksets can suffer the same problem if a deadbolt is installed inverted.
Aug 28, 2009 | Weiser Lock Powerbolt 1000 Lock
Door opens half way then closes quickly with electric operation sprayed wd40 on rollers but still not working properly
Sounds like the 9 volt battery is very low, please put in a new, fresh 9 volt battery and see if that helps, as you've already addressed any issues with sticking, etc. When the battery(ies) are low, some electronic locks don't have enough power to fully pull in the dead bolt and the internal spring can overpower the small motor and cause the lock to re-engage quickly.
If you're getting a flashing red light when you enter in your key code, followed by flashing green light, your battery is low, if you're getting a flashing red light, the batteri is critically low.
If you have recently installed this lockset, it is possible that the alignment is off and is causing the deadbolt to drag and is preventing free movement. You'll need to adjust the lockset to allow the deadbolt to move freely by turning the hand knob with the door shut all the way.
If that doesn't help, please contact Schlage directly by calling them at the numbers provided:
United States Customer Support
Warranty Information: 1.888.805.9837 All Other Inquiries: 1.800.847.1864 Canada Customer Support
Within Canada & US: 1.800.900.4734
Hope you find this helpful, best regards!
Aug 15, 2009 | Schlage Camelot Deadbolt Keypad, Satin...
My key is stuck in my Kwikset deadbolt door lock
spray a little bit of oil where you insert the key turn it a couple of time to make sure it is lubricated then turn to correct location to pull out key hold cylinder in with finger key should pull out
Mar 26, 2009 | Kwikset Locks & Locksmithing
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
131 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
