HELLO...I HAVE A MICROTEK ARTIXSCAN 1800F SCANNER THAT I PAID OVER $1200. FOR ABOUT 4 YEARS AGO. USED ONLY 16 TIMES OR SO. THE BULB BLEW OUT FOR SOME REASON AND CANNOT BE CHANGED BY HAND, THE COMPANY TELLS ME. I CALLED THEM. THEY WERE RUDE AND TOTALLY NOT HELPFUL. THEY SAID THEY DO NOT REPAIR THEM AND TO BUY A NEW ONE. THEY HAVE NO SUPPORT FOR THEIR PURCHASES, AND CANNOT HELP ME. THEY WERE TOTALLY UNAPOLOGETIC ABOUT IT. I CANNOT FIND ANYONE WHO CAN REPAIR IT. DO YOU KNOW OF ANY SERVICE THAT WLL TACKLE THIS KIND OF REPAIR? CAN YOU ADVISE ME WHAT TO DO? THANK YOU. -BERN
  • 1 more comment
  • PhotoDude Aug 03, 2008
    In answer to your question, yes I did ask them if they had the lamp in stock; they told me that they did not, and that it is not possible for me to change the lamp. It takes special equipment and requires a technician to uninstall the old one and put in a new one. They did not know where to get the lamp, but they were clear that I could not do the repair job myself.
    PhotoDude
  • PhotoDude Aug 04, 2008
    I DID ASK THEM IF THEY HAD THE LAMP IN STOCK AND THEY SAID "NO", AND THAT IT IS NOT REMOVEABLE WITHOUT SPECIAL TOOLS AND REQUIRES A TECHNICIAN TO DO THE JOB. THEY DID NOT KNOW WHERE TO GET THE LAMP NOR HOW TO REMOVE IT. IS THERE A SERVICE WHICH SPECIALIZES IN TACKLING TOUGH PROBLEMS LIKE THIS? OTHER OPTIONS? THE IST RESPONSE WAS NOT ADEQUATE FOR MY PARTICULAR NEEDS. I'M LOOKING FOR A SOLUTION TO THE PROBLEM, IF YOU CAN HELP AT ALL. IT SEEMS THAT THIS ISSUE IS NEAR IMPOSSIBLE TO DEAL WITH, THOUGH. THANKS FOR WHATEVER HELP YOU CAN GIVE ME.
  • PhotoDude Aug 07, 2008
    Yes, the solution was helpful and opened up another avenue for me to deal with the problem. Thank you so much.
    Bern
    Genius:
  • 1,269 Answers
Replacing the lamp is a very sensitive task in fixing the scanner. The manufacturer is right that it requires skilled scanner technician to do it. However, its worth giving a try replacing the lamp by yourself. The problem is where else can you find the exact lamp size or part number like yours. If ever you found a spare lamp, go to the site below for instructions on how to carefully replace the lamp
http://www.instructables.com/id/Scanner-Parts---Desk-Lamp/
hope that helps
Posted on Aug 04, 2008
    Genius:
  • 1,665 Answers
You must replace your Xe-gas cold cathode fluorescent lamp type
  • 19,396 Answers
Well you find a bad guy who gave you some pure rubbish at customer service. Next time get his name and report.
Microtek provides replacements on request, at least in UK, we got a lamp from them 2 moths ago.
If you cannot get replacement from Microtek try here
Replacement Lamps from the scanner parts and ...Regarding the assemblage, the bulb is very delicate and will blow if touched, have the job done by a good repairman at a local computer repair shop.
  • 2,427 Answers
Well the company is right, basically its not repaied, however it can be. firstly you will need to get a replacement lamp, you can get this from an onld scanner that uses the same voltage as your, or more preferible on just like your..
Ok now if you touch it with your hand thats the end of the bulp, use surgical gloves and hold the edges near the contacts.
  1. Open up the scanner
  2. carefully remove the carige unit(part that moves back and forth)
  3. surn it over to see the bulb
  4. remove and replace the bulb.
Once it is the bulb it should be operational, now generally these things are tossed out and a new one replaced. However if you think you want to have a go at it, by all means do, you cant spoil it twice.
Posted on Aug 03, 2008
  • 2,326 Answers
I'm sure the lamp replacement is not a difficult task but finding the lamp itself could be a problem since even the manufacturers are not very helpful.
Did you ask them if they carry the lamp?
Where i can find a driver for my Microtek Scanner 3840 for Windows 7 64 bit. Maybe you can send me a download link? thnx.
3840 is an old scanner and the latest driver for it in microtek website is for xp. but you can try using the win7 64-bit driver of ArtixScan DI 1210 which you can download here:
http://support.microtek.com/downloads/drv_specific.phtml?slct_os=22&prod=127&bymdlnme=1
after downloading, DON'T INSTALL it. put it in a folder, then using your WINRAR, extract it (right-click then click Extract Here). Then MANUALLY UPDATE your driver by browsing to your folder when windows detect your printer or click add printer in Devices and Printers in Control Panel.
Sep 05, 2011 | Microtek scanmaker 3840
Win7 or Vista 64 bit drivers for ArtixScan 4000tf
Microtek only supply drivers up to XP for this scanner.
Jan 03, 2010 | Microtek ArtixScan 4000tf Film Scanner
Blue dots appearing on screen n bulb blew twice
IT NEEDS A LIGHT ENGINE. COST A LOT TO REPAIR.
Oct 06, 2009 | Televison & Video
ScanWizard Pro 6.03 cannot locate scanner
Need to refer you to my brother-in-law. Robert. 435-770-0637.
Mar 31, 2017 | Microtek Office Equipment & Supplies
Microtek ArtixScan 4000tf - pc won't recognise scanner
http://202.39.72.2/installer/windows/swprotx/swprotx_7100.exe - driver
if helped rate fixya
Apr 09, 2009 | Microtek ArtixScan 4000tf Film Scanner
Getting scanner driver
i have microtek scan maker 3600 model and i want to driver download from net
Nov 15, 2008 | Acer Office Equipment & Supplies
Microtek scanmaker 9800 XL
I just ordered a replacement bulb from a company in California. I sent them the assembly and they are trying to replicate it for me. I am expecting delivery within one week. If you want to email me I will let you know how it works. You can email randi@suzy.com.
Jun 06, 2008 | Microtek ScanMaker 9800XL Flatbed Scanner
No scan with Microtek Artixscan 120 tf
When you say -'normal' prescan you do mean you get an image? If this is so I would remove all software. Do a disc clean Reboot the computer Re install the original supplied software-ignore for the time being any down loaded upgrade, Come back tell me what you have
Aug 31, 2007 | Microtek ArtixScan 120tf Film Scanner
Microtek artix scan 120tf
CCD failing or processor fault If you can correct the faults in an image editor then thats OK do that. other wise a new scanner - these things are generally not a repair opti
May 30, 2007 | Microtek ArtixScan 120tf Film Scanner
139 people viewed this question
jasbo
jasbo
