Question about Epson Stylus CX4100 All-In-One InkJet Printer
My Epson CX-4100 printer/scanner shows error "E" in the LED display for "Copy". All other lights blinking as well. Never had this problem.
  • 684 Answers
Turn off the Printer and Unplug it from the Power Supply.
Remove the Cartridges from the Printer!!!!!
On the Backside of the Cartridge you would see a Copper Stripe, Wipe the Copper Stripe using a Paper Towel!
Reinsert the Cartridges and Restart the Printer.
Good Luck!!!
Posted on Sep 17, 2011
Communication error 21000068 when resetting my epson t60
i want to resetter my epson stylus printer t60 ink pad counters
Mar 30, 2013 | Epson STYLUS PHOTO T60 INKJET PRINTER
Epson 610 Workforce Printer Error; Light Bar won't reset
Sound like the scanner is the issue, is it under warranty? OR the Scanner may be locked, check for the scanner release device unlock it,.
Dec 17, 2012 | Epson Workforce 610 All-In-One InkJet...
E-90 error message on Epson CX6000
If the error code E-90 appears on your Stylus CX control panel display, the print head may not be able to move back and forth freely.
If the ink cartridge cover is not completely closed, the print head may have trouble moving back and forth. Follow these steps to close the ink cartridge cover:
  1. Turn off the Stylus CX.
  2. Lift up the scanner.
  3. Press down on the ink cartridge cover to make sure it is completely closed.
  4. Close the scanner and turn the Stylus CX back on.
Also
If the packing materials are not removed, the print head will be unable to move and the error code E-90 may appear on the control panel display. Follow these steps to remove the packing materials:
  2. Lift up the scanner to access the printer area.
  3. Remove the tape from the ink cartridge holder.
  5. Close the scanner.
  6. Turn the Stylus CX back on.
Aug 07, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Power and error botton blinking epson cx 2900
Could be ink cartridge no contact, or it is dirty. Or if you try to print and this printer that flag a message " end of service life......parts." . You should reset it counter using third party software. In kinda connection with ink pad.
Apr 18, 2009 | Epson Office Equipment & Supplies
Cartridge holder does not move to
Hi
have you tried pressing it down for 3 seconds? on the printer utility on your computeris there an option to change cartridge? pls check that, if all fails then that's a hardware issue. call epson for replacement.
Hope this help
Dec 20, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson Stylus CX4600
If all of the lights on the control panel are flashing and you see the letter E in the Copy window, the print head may not be able to move back and forth freely. Follow these steps:
  2. Open the scanner.
  3. Remove any jammed paper or other obstructions from the paper path.
  4. Carefully lower the scanner.
  5. Turn the Stylus CX back on.
alert_note.gif Note: If you can't remove the paper or foreign object yourself, do not use force and do not disassemble the Stylus CX.
And the last thing you could do, is to check if the rod where your carriage slide is dry...if so put a little bit of oil on it
Apr 03, 2008 | Epson Stylus CX4600 All-In-One InkJet...
Scaner Epson CX-5400 error message
What is the error message? SCANNER ERROR?
If that is what you getting, turn printer off then open scanner cover- on the left hand side there is a toggle log for scanner, position it to unlock then turn printer on then try scanning/copying again.
if your having a different error message pls indicate the exact error that you are getting.
Feb 22, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson stylus cx 5400
Press the menu button until Copy Mode appears
Feb 15, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX4100 All-In-One InkJet Printer Logo
358 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
