Question about HP VP6310 Multimedia Projector
When we turn the projector on it gets hot then it shuts off.
    Scholar:
  • 146 Answers
Check that fans are running and screens/ filters for fans are clean and free of debris
also what are hours on bulb - if bulb is too old that could be causing issues also
Posted on Mar 21, 2011
Why is our Proxima Desktop Projector 8000 turning off after a period of time?
There is a THERMAL fuse that is used to prevent fires and electrical destruction of the unit. Lamps get very hot and unless the AIR flow is good, the temperature gets too hot and shuts down the system. The fan speed may be too low, the unit may need to be cooled down with an exterior fan? Try options.
Jan 04, 2015 | Office Equipment & Supplies
Infocus in104 projetor problem: power off, temp red, lamp green
Most probably failure of the thermistor or thermal fuse that detects the temperature of the lamp housing - so the projector thinks it's hot even when it's cold. Unfortunately it will need a trip to an authorised service centre for repairs
Apr 04, 2014 | InFocus IN104 Projector
NEC NP 1150
The temperature in the classroom is to hot. Turn down the
temperature in the classroom or get a small fan and place it near the
projector. The projector is running at border line and just needs a few
degrees of cooling...
Jul 20, 2010 | NEC NP1150 Projector
Optoma EP7155 gets very hot and shuts down.
Hi
Possible filter problem since its overheating. clean up filters and make sure that you use projector in an open area so air can cool it off while running.
Hope this helps
Mar 26, 2010 | Optoma EP7155 Projector
Projector turns on for about 30 seconds then shuts down. the fan kicks up high, and led light flashes yellow for about 4 min until the fan shuts off. does not feel hot so overheating does not seem to be...
if the lamp lights and then shuts down, replace the lamp. it's at the end of it's life. to rule out overheating, blow the projector out with canned air. dust retains the heat that the projector is trying to expell. also see if all of the fans are working. if you do get an image for a short time, try to get into the menu to reset the settings to factory default. lastly, if all else fails, you have a ballast issue. unfortunately, infocus no longer sells parts for this model.
Nov 28, 2009 | InFocus LP 630 Multimedia Projector
Projector turns on and works for about 2 minutes, then shuts off
You may have to reset the bulb hour counter. Go thru the setup menus and see if you can do it from there. Infocus projectors make you jump thru the hoop.
Aug 30, 2009 | Mitsubishi XD480U Multimedia Projector
Lamp goes out after 10-15 seconds
Recently had a similar issue.
When I took the lamp out (Let it cool for awhile first), there was dust all over one side preventing air from the fans from cooling the lamp, so it shut itself off after getting too hot.
Apr 27, 2009 | Sanyo PLC XU48 Multimedia Projector
Christie DS+60 projector turns off spontaneously
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
LAMP FAILURES
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
Jan 16, 2009 | Christie DS+60 Multimedia Projector
Sanyo PLC-XF46N projector shuts down before powering up completely
The Fix Ya rep suggested that I try the "Reset" button located next to the Audio out on the side of the projector; this solution proved to be the fix I needed. I was able to get the lamps to warm up and get into the menu to cut back the bulbs/power consumption on start-up, allowing the projector to function for a problem-free 4 hour period Unfortunately, I had the same issue this morning, but the same fix worked again.
Jul 06, 2008 | Sanyo PLC-XF46N LCD Projector
HP VP6310 Multimedia Projector Logo
109 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
