Question about Canon UC9 Camcorder
CANON UC9 HI8 Camcorder how do you set the time and date?
2 Suggested Answers
old marine
  • 2152 Answers
SOURCE: trying to find batterys for canon uc9 camcorder
Camcorder takes a Canon BP-711 battery. There are several battery manufacturers who make batteries to this specification. Use a search engine to find.
Posted on Jun 17, 2009
Why am I having difficulty rewinding and playing tapes?
Is the Canon UC9 a HI8 camera?? If not it wont play HI*.
Aug 21, 2015 | Canon UC9 Camcorder
When playing back a Hi8 video tape on my UC9 the tape stops after 15-20 minutes. What is going wrong? How can I fix it?
hi,
does that happens with all your tapes or for a specific one?
if for all:
the grease of the mechanism must have become hard with the dust and the time ! it is not easy to repair and i would recommend you to think about buying a second hand one on ebay for ex, because the repair will cost more than that !
if it is only with specific tapes, make them go fast forwards and fast rewind various times to re "flexibilise" the tape, because with time the turns of the plastic tape are a bit glued together, that can be used also when the recordings are really short clips, as when the motors goes and stop, it can make ridges on each side of the all tape (like waves) so FW and RW and it re rolls on a better way without interruption
cheers,
mich
Oct 30, 2014 | Canon UC9 Camcorder
Set date time display
The Date/Time command is in the DATE/TIME SETUP menu. See page 81 of this manual:
Oct 20, 2013 | Canon FS100 Flash Media Camcorder
Hi Donald. not sure how many calls you get from
The fault seems to be in the sensor and the mode switch of the loading system which is connected with the main controller processor and loading driver.
This can be a failure of the tape end detector which is a IR - infra red- emitter which is placed in the center of the tape tray and MUST feed continuous signal to the END IR detectors placed at either ends.
Also the tape seems to load with a false detection of the cassette within when the tray is closed for this reason of the failure along with a possible misplaced mode switch settings. This triggers to make the loading move without a reason and so can be due to failure of the the mode switch or unbalanced settings.You will need some experience to remove the tray unit, then check on the IR sensors and also check the settings of the loading drive and mode switch.
Nov 27, 2011 | Cameras
Canon ES5000 hi8 camcorder won't load a tape.
that is the mechanism alignement(mode switch)
plus a little gear who match with the other
you will need a very good tech to fix it.usely its the problem.
hope that will help
regards Alan
Jun 02, 2010 | Canon ES5000 Camcorder
Time/Date stamp doesn't show up...
this camcorder has a built in rechargeable battery for the memory of the date and time, if you do not use it for more than three months, it will discharge all the way; to recharge, you need to plug camera with ac power for 24 hours and the camera turned off. this should charge the internal battery complete.
Oct 08, 2009 | Sony Handycam DCR-TRV250E Digital...
Trying to find batterys for canon uc9 camcorder
Jun 17, 2009 | Canon Video Cameras
How do I change internal clock battery in sony trv68 hi8 camcorde
There is an internal battery, but it is a built in and I don't believe it can be removed. However there are clear instructions in the manual on page 69 that detail the steps you should go thru to recharge the exhausted lithium battery for the date.
Here's a link to the manual
http://www.henrys.com/manuals/sony/CCD-TRV58(En).pdf
Dec 11, 2008 | Sony Handycam CCD-TRV68 Camcorder
Problems with playback of HI8 tapes...
What's happening is that the tape in the cassette is being chewed on one side by the camera's tape transporting mechanism during playback, hence the distorted image and sound. The mechanism might be damaged (misalignment) or just dirty. Try not to play other tapes on this unit because they will become permanently damaged. The best way is to find another camcorder (if cleaning does not help). Note that some old cassettes of long recording time will exhibit this behavior more often because of thinner tape used.
Dec 06, 2007 | Video Cameras
Video Cameras Logo
78 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
