Question about Brother DCP-9045CDN Laser Printer
Brother DCP9045CDN - HOW TO RESET THE FUSER UNIT AFTER A NEW ONE HAS BEEN FITTED
  • gerri261 Mar 22, 2011
    I've tried this: pressing menu, then 6, but this then lists time and date, so even by scrolling down to parts life and pressing 6 again it jumps back to Drum. I can't seem to get to the reset button for the Fuser. Any other ideas would be welcome. I've looked on the disk that was supplied with the printer but nothing is shown for this problem.
    I've tried all combinations but can't get to the reset button. I've tried Menu/6 but this takes me to time and date, pressing 6 again takes me back to Drum. Is there any other way to get to the reset button?
  • 610 Answers
Give this a try, press "menu", "6","6" keys. This should get you to the reset menu. Now scroll down until you find Fuser, press "ok" button then "1" to reset it.
Posted on Mar 21, 2011
  • mpb1972 Aug 23, 2011
    Parts Life Reset Function
    This function is provided for service personnel in order to reset the counter of each periodicalreplacement part and count the number of replacement times when replacing the periodicalreplacement parts.
    (1) Press the
    and
    9
    buttons at the same time in the readystatus.(2) The “Reset Menu” will appear on the LCD. Select theapplicable periodical replacement part by pressing the orbutton and press the
    OK
    button.< Periodical replacement parts are indicated on the LCD >- Drum - Belt Unit - PF Kit MP - PF Kit 1- PF Kit 2 - Fuser - Laser(3) When the
    OK
    button is pressed the “1. Reset 2. Exit”appears on the LCD. Press the
    button if resetting thecounter. If not, press the
    button.(4) Pressing the
    button accepts that the machine implementsthe counter reset.(5) The machine returns to the ready status.
    Note:
    - All periodical replacement parts are always indicated on the LCD even though their lives donot reach 0 %.- The PF kit 2 is always indicated even though Tray 2 is not installed, or it is not supported forthe model to be used.- The machine returns to the ready state automatically if no panel operation is implemented for60 seconds
There is no option to reset under machine info
I Suggest You To Watch
How do factory reset the network settings Brother To Fix Your Brother Printer Issue.In Case You Still Having Problem Then Follow Us For On:- Brother Printer Support
Oct 03, 2011 | Brother DCP9045CDN
Machine error 76
Thought I would read up here before going out. Found out it was a fuser error. Checked their fuser out, everything tested out okay but still got error 76 & 78 after doing reset. Guessed Thermistor. Returned with new thermistor (same as the 1200 series by the way) Part No. BROUL8902001. Fitted then reset using, "Power on while holding menu/set. key in 91, then key in 99 to exit" I think I had to power off but it was fine after that. Good as new!
Aug 13, 2010 | Brother MFC 9870 Laser Printer
I have replaced the fuser on Brother HL-4070cdw but the screen displays fuser unit end How do i clear the message Thank you
Look on page 115 under maintenence. Follow the instructions down to where it says Belt Unit, instead, find Fuser Unit then continue with reset instructions. Hope this helps.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_4040CDN_4040CN_4070CDW_EN_1037.PDF
Oct 27, 2009 | Brother HL-2040 Laser Printer
Brother 8460n Fuser Unit
Hit in sequence Menu,*,2,8,6,4
This will put it in maint. mode.
Press 88
That is parts counter reset, scroll down and hit ok on the part you want to reset the counter. :)
Jan 05, 2009 | Brother MFC-8460N All-In-One Printer
RESETTING FUSER LIFE ON BROTHER HL5140 PRINTER
How to reset the pf-kit message on a brother hl-5140.
May 17, 2008 | Brother HL 5140 Laser Printer
Paper Curling with Brother HL-2040
Replace fuser assembly/have fuser unit replaced if you have tried fresh quality paper from a unopened ream. The first versions of these had the fuser and exit assembly modified by brother to help eliminate excessive curl last 9 digits of serial number are higher than D5J760210 have already been modified, if lower ie D4Z99999 need to get mod. fitted.
Jan 10, 2008 | Brother HL-2040 Laser Printer
Hl5270 clear "replace fuser" error
To reset any of the consumables on your HL-5270 you have to press "Go" and "+" at exactly the same time. You will be given an extended reset menu.
Nov 13, 2007 | Brother HL-5270DN Laser Printer
Brother DCP-9045CDN Laser Printer Logo
2,489 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
