Question about Dryers
Need manual for sears kenmore dryer model 11064942300"
    Master:
  • 894 Answers
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kenmore model by clicking the link below.
11064942300 KENMORE ELECTRIC DRYER Manual Sears PartsDirect
You can purchase a wide variety of high quality appliances replacement parts direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/appliances
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Posted on Apr 27, 2018
5 Suggested Answers
SOURCE: Need schematic for Sears Kenmore Dryer model number 11063032102
Thanks, I will try that.
Posted on Mar 28, 2008
SOURCE: Sears Kenmore Dryer #86681100
I took the top off of the dryer to access the door switch. Took the number off the part and went to Trible's appliance parts and got a replacement. Works fine now.
Posted on Apr 01, 2008
Illeagle
  • 525 Answers
SOURCE: Our dryer, described below, takes
Your complaint is:"Our dryer, described below, takes between 4 and 6 hours to dry, though it's advertised as "heavy duty" and "extra large capacity.""
White Kenmore 5.8 cu. ft. Super Capacity Gas Dryer
Sears item# 02690412000 Mfr. model# 90412
Based on the information provided above, I am unable to provide a positive solution to your issue. Your model number is incomplete! I have provided some common solutions to help guide you in your search. This information is for a non-specific brand model, gas dryer.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these:
Vent
Flame sensor/gas valve
Internal ductwork
Cycling thermostat
Lint Filter Vent: Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Also note that, to maximize drying efficiency, the vent should be as short as possible.
Flame sensor or gas valve coils: This is the most likely cause. Click links below. http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3449&PPStack=1 http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3229&PPStack=1 There's a flame sensor near the igniter. If it's defective, the gas may shut off prematurely. Another common problem occurs when one of the electrical coils on the gas valve fails intermittently. If this happens, the flame shuts off before the thermostat sends a signal, which can greatly prolong the drying time. If the sensor or the coils are causing the flame to shut off, replace them.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 14, 2008
SOURCE: Kenmore Dryer, model 86950100 PARTS
I was just looking for a part for mine, too. On the tag inside the front door is the pre-printed prefix 110. that goes with the 86950100 that's printed later. So, I entered 110.86950100 and found the information for my model.
My unit has been working reliably for many years now, and some parts are not available anymore. I think I bought it in about 1985. I replaced a thermal cut-off switch in 2009 for $15 locally. I also have a matching washer. I've never had any failures with it. Bear in mind that I was single for 20 of those years with only a few girlfriend-hours on them. :-)
The direct link to Sears parts for my specific model is http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.86950100.
Hope this helps.
Posted on Jan 22, 2010
Sears Electric Dryer is flashing F01 What is wrong?
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Error code on dryer F01 - Kenmore Elite HE3 Dryer - iFixit
https://www.ifixit.com/.../Error+code+on+dryer+F01 Traduire cette page The F01 indicates a failed electronic machine control board. This error code can ... The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
Dryer Sears / Kenmore HE3 - F01 Error Code Main Circuit ...
2q==? 7:35 https://www.youtube.com/watch?v=eWqrn5klxm0 20 avr. 2015 - Ajout? par Jim Dandy Sears Kenmore Dryer Model HE3 - F01 Error Code. Main Circuit Board Repair - Electronic Control Board ...
Error code F1 on Kenmore HE2 electric dryer appeared ...
www.shopyourway.com > ... > Questions Traduire cette page Sears Kenmore HE2 electric dryer; model #11087571601. F1 error message appeared ... Power it back up and see if you still get the F01 error code. If not, then I ...
What does the error code F-01 mean on my Kenmore front ...
www.shopyourway.com > ... > Questions Traduire cette page By unplugging and plugging in the electrical cord, I got the dryer to work again. ... What does the error code F-01 mean on my Kenmore front loaded HE2 dryer? ... My kenmore washing machine 110.46462500 is flashing an error code F.01 ...
Feb 04, 2016 | Sears Kenmore Elite Electric Dryer 69278
Need an owner's manual for Sears Kenmore sewing machine model #14813022
It sounds stupid but GOOGLE Taylor Sewing Machines.... They bought the old Sears design . Manuals are almost identical
Dec 14, 2013 | Dryers
I need owners manual to kenmore dryer model/stock 67832791 67832, SN MG2720493
11067832791 KENMORE ELECTRIC DRYER Manual Sears PartsDirect
Ava B.
Jul 31, 2012 | Kenmore Dryers
Sears kenmore elite dryer manual no. 417.84082500
https://www.searspartsdirect.com/partsdirect/user-manuals/41784082500-kenmore-parts-manual
Ava B.
Jun 07, 2012 | Kenmore Dryer Sears Elite
Kenmore h2 dryer convert from propane to gas
Contact Sears with the model number and they can provide the parts and instructions, it will not be more than $25.00
Feb 07, 2012 | Kenmore Dryers
I have a Kenmore thats about 10 years old. Model No. C110-6070092....type Dr-4 stackable. It gets too hot to touch inside the back wall, so hot that I have to yell "OW!" Can this be repaired,...
I don't have that model number repair manual so went to the Sears website and plugged that model number in and it says they don't recognize that model number.
Jun 09, 2011 | Kenmore Dryers
Need owners manual for sears kenmore elect dryer model 700.
Please visit THIS LINK.
Enter the FULL model number - then after choosing OK, the link to the manual will appear on the right side.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 24, 2010 | Kenmore Dryers
I need the installation Instructions for a Kenmore 500 Dryer
While this manual is not for your specific Kenmore dryer, the Kenmoreinstall directions for the model in the manual will be the same. Start on page 5
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0502231.pdf
Nov 21, 2009 | Kenmore 500 6952 Dryer
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Dryers Logo
67 people viewed this question
Top Dryers Experts
