Question about Dishwashers
Got a new Kenmore dish washer in mid January. Worked fine for a couple of weeks then so-called "clean" dishes were covered with a residue from, I assume, was the dishwasher soap. I tried cascade action pacs, then cascade powder and finally, cascade gel. Nothing helped. I ended up having to use SOS pads to get the "crud" off of the dishes and silverware, and use regular dish soap to hand clean each dish and saucer and bowl...as well as each knive, spoon and fork! I have finally stopped using the "new" Kenmore dishwasher. I am not sure if the problem is with the cascade or with the Kenmore. Not knowing which manufacturer to contact first...cascade or kenmore...I decide on cascade. Thanks for any help you can give. R. Eckrich
  • reckrich Mar 21, 2011
    Thanks for you input. I have always used Cascade powdered detergent; only started with the liquid and gel after I used my new dishwasher for several weeks and noticed neither dishes nor silverward were getting clean. Everything was cloudy, dusty, gritty!. I will try the vinegar although for the past few days I have been washing by hand.
    Brigadier General:
  • 3,513 Answers
Hi
Add some vinegar to each load along with the detergent you are using, also stop heat drying your dishes. Never use liquid or gel detergent .Dishwashers have some delicate parts and the gel and liquid dishwasher detergents tend to gum up the works, especially around the soap door area. Avoid gels and liquids and stick with powdered dishwasher detergents.
Also check this bellow link to read for the article to get helpful information:-
http://fixitnow.com/2005/02/appliance-repair-revelation-dishwasher.htm
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Mar 21, 2011
  • Aparajita Batabyal
    Aparajita Batabyal Mar 21, 2011
    Hi
    Try using vinegar as i suggested and continue using Cascade powdered detergent,but try avoiding gel and liquid detergent.
    Thanks for contacting fixya.com
Dishwasher is going on 3.5 yrs old, it worked well for the 1st year but for the last year & half it has been leaving gritty residue on all the dishes. To the point, dishes are being hand washed to...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101//
Mar 22, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
The dishwasher does not get my dishes clean. it leaves heavy residue on all that is in the washer. it worked fine but now it is not getting the dishes, silverware and glasses clean at all.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Dishwasher Residue and Film on Dishes
heatman101
Nov 29, 2010 | GE Nautilus 24" Built-in Dishwasher
My Jenn-Air dishwasher, Model #JDB1100AWW, is now not cleaning the dishes well. We have had it for approximately 5 years and up to the last several weeks, it has worked well. Now, however, after the load...
heatman101
Oct 18, 2010 | Jenn-Air 24 in. JDB1100AW Built-in...
Dish water not emptying out after a full cycle.
heatman101
Feb 22, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
Kenmore 17033 dishwasher will not clen dishes
USE JET DRY and clean the system every once in awhile by running it through a cycle with no dishes and use washer cleaner for that model.
Jan 07, 2010 | Kenmore 24 in. 17033 Built-in Dishwasher
Dishes not rinsing well,
I would check the bottom drain area. Sometimes food can stay down there and block the drain or get back around onto the next load.
Apr 06, 2009 | Kenmore Dishwashers
Kenmore Dishwasher
the problem is hard water. go to www.dishwahserfilter.com and get the difi filtration system.
Nov 12, 2008 | Kenmore Elite 45986 Front Load Washer
Dishes are not coming out fully clean
first if the pump is running and you can hear it washing it should clean now hot water cleans dishes not the washer the hotter the better at least 130-135 degrees modern dish washers use less water than older models so if you don't get the water as hot as you can stand it at the sink before you turn the washer on you can fill it with cold water second its important that you use jet dry and if your dishes aren't dry at the end of the cycle then on most washers you can turn the disp up for more hope that helps let me know
Dec 01, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Residue of dood,spices on dishes after cleaning
I would suggest calling whirlpool to have a tech come out and look at it. Your appliance is still under warranty if it is under 1 yr old. It will cover parts and labor.
Nov 17, 2007 | Whirlpool 24 in. DU915PWP Built-in...
New dishwasher leaving powder residue on dishes.
the problem is hard water and there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
Sep 06, 2006 | Kenmore 13869 / 13864 / 13862 Dishwasher
Dishwashers Logo
345 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
