Question about Garden
Have lost instructions for Wickes 200w Palm Sander - how to fix on sand paper. Also what aluminium base has attached to it?
b0sslady2001
  • 357 Answers
SOURCE: How to attach sand paper to the Kirby Turbo Sander attachment?
There is a plastic guard around the edges that comes off. Then, there are clamps that hold each end of the sandpaper. If you can't see the clips, then the guard is still on and needs to be removed. Hope this helps...
Marci
Posted on Jul 25, 2008
mikeymiddles
  • 58 Answers
SOURCE: Orbital sander flicking the sand paper off
You did not specify how the sanding discs are meant to be attached to your sander's backing pad.  My experience with this type of problem is material from the sanding process builds up on the backing pad and does not allow the sanding discs to adhere properly.  If you have a velcro type system, clean the hooks on the sander's backing bad by soaking the pad's face in a plate of paint thinner for 20 to 30 minutes then use a wire brush to remove the rest of the paint physically.    For adhesive pads clean the sander's backing pad surface with denatured alcohol.  Do not use isopropryl or rubbing alcohol as this may not be 100% alcohol and could contain a lubricant like glycerin.  When the sander's backing pad is completely dry and clean it will hold adhesive backed pads fine.    Flaky paint is best scraped off before sanding, use a wide putty knife or a paint scaper to remove large flakes before sanding.  This will minimize airborne dust and cleanup.    For best results with adhesives, always keep your surfaces  clean!    Good luck and happy sanding!  Michael Mittelsdorf
Posted on Jan 10, 2009
  • 104 Answers
SOURCE: no sanding action and motor just buzzes
It will probably be the shaft from the motor to the orbital cam which is on the flat plate that you connect the sandpaper to , either the shaft or the bottom cam is broken [probably the shaft has snapped ] you can do a cheap repair with a good glue to reconnect the shaft [but you wont be able to push too hard again] or if you can get the parts just replace the shaft into the motor . they are really simple things to work on
Posted on May 23, 2009
  • 142 Answers
SOURCE: I can't find parts for a Craftsman 5" Orbital Palm Sander
a band aid fix, if the hook and loop is wore out, but the pad is ok, is to get a peel and stick hook and loop pad that you can stick on the pad
Posted on Jul 22, 2009
rowdy45176
  • 2176 Answers
SOURCE: Clarke FM1700 buffer-sander, problems with using it
what is the condition of the felt pad on the driver?? The sander should not be that hard, usually you need to lift up or slightly bear down to get the machine to move left or right. Are there any exposed nails in the area you are sanding and check the grit for the sanding conditions
Posted on Aug 25, 2009
What is the usages of a PALM SANDER?
What an odd question .....
To sand small areas that are otherwise inaccessible to orbital sanders.
Apr 07, 2018 | Tools & Hardware - Others
Why is my 5" sanding disks not sticking to my sander?
The holes are to suction dust for a vacuum attachment or dust collection bag. The sander will have a very smooth pad almost shiny if it takes stick-on discs (PSA). If not it will be a velcro pad and in that case you need the velcro discs. This description sounds like you have a velcro pad. Sticky discs wont stick to a velcro pad.
Apr 24, 2016 | Sander Tools & Hardware - Others
When I bought my sander it has what i would describe as a rubber pad onj the sander. Is this the sanding pad?
That sounds right. It is probably the type that uses adhesive backed paper. You stick the paper to the rubber pad.
Jul 14, 2012 | Dewalt DW 411 HAND PALM SANDER
Can't figure out how to load the sand paper on to the mouse sander
Just stick the sand paper sheet to the base of the mouse sander... it's velcro it will hold... match the forme of the paper with the forme of the sander's base... that's all...
Cheers!
Aug 06, 2011 | Black & Decker Mouse Sander/Polisher
How to replace the sand paper on skil sander hi speed 439
the skil 439 is a palm orbital finish sander. To replace the paper, pop the springs off the side where they take a 90 degree turn towards the work surface. To replace paper, rip a piece of standard sand paper into quarters, reverse removal and done. It's a pretty nice older sander and yes I have one.
Jul 11, 2011 | Garden
How does the sand paper attach to the removeable bases? There is a screw that keeps the base on. Nothing is sticky to hold it there? The piece that is like velcro is great but it somehow needs to be...
the velcro piece should have a removeable or i should say a peel off paper like a sticker and then stick the velcro to the base off sander if it was not on when you got it. it was not put on at the factory cause they give you the option of using stick on sheat of sandpaper or hook & loop (velcro).
Apr 07, 2011 | Black & Decker Mouse Sander/Polisher
DW411 Can I put a velcro pad on this sander so I don't have to fumble around trying to get sand paper on it
Dewalt is not going to make an accessory for you to do so, since that sander was designed to use 1/4 sheet sandpaper, and therefore takes standard paper clamped in place. You could make your own base for the sander out of thin plywood or some other suitable material, covered perhaps with a laminate or rubber surface, that would accept PSA (pressure sensitive adhesive) sandpaper, which you can buy in rolls appropriately sized for your sander. Or you can try some kind of after-market conversion kit such as this one (See also here, etc.)
If you really want a hook and loop base on your sander, I recommend you bite the bullet and simply purchase a random orbital sander with a H&L pad. Then you'll of course have to buy the perforated paper discs to go with it....
But you'll easily be able to change grits, and the performance and quality of your sanding will improve.
You might check the reviews in various woodworking magazines before you make a purchase, just so you know what you're likely to get for your money. There's a vast array of machines made, and the quality varies accordingly, and depends to some extent on your budget and intended use.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Dec 20, 2010 | Dewalt DW411 quarter - sheet palm grip...
How do I secure a piece of sandpaper on the dewalt orbit palm sander?
I think your model holds the paper with glue that is on the sand paper.Just take apart the back cover of the sand paper to expose the glue.
Nov 08, 2010 | Dewalt DW421 5'' orbital sander
Jul 22, 2009 | Tools & Hardware - Others
How to remove round sander for iron shaped one
You need to remove the allen head cap screw in the center of the base, then remove the washer, and pull the base straight down off the sander. If you can't get it to pull off, try gently rocking it a little as you exert pressure to pull it off.
Random orbit sanding base
With this sanding base, you can use the tool as a random orbit sander.
Fitting and removing the sanding base (fig. B)
- Place the sanding base (3) onto the spindle (10).
- Place the washer (7) onto the spindle.
- Insert the Allen screw (8) into the screw hole in the spindle.
- Tighten the Allen screw using the Allen key (9) supplied.
- To remove the sanding base, remove the Allen screw (8) and washer (7).
Fitting sanding sheets (fig. C)
- Hold the tool with the sanding base (3) facing upwards.
- Place the sanding sheet (11) onto the sanding base (3). The holes in the sheet do not need
to line up with the holes in the base.
Large detail sanding base
With this sanding base, you can use the tool as a detail sander or an orbital sander.
Fitting and removing the sanding base (fig. D & E)
For detail sanding, the pointed end should face forward as in fig. D. For sanding large areas,
the pointed end should face to the back as in fig. E.
- Place the sanding base (12) onto the spindle (10). Make sure that the legs of the base
locate into the tool.
You can also view the factory manual here: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/479727-00,MS1000%20SANDER.pdf
Be patient, and good luck! Let me know if this doesn't solve your problem and you still need help!
Mar 08, 2009 | Black & Decker Black And Decker Cyclone 4...
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
