The serial number is what you are getting after you hold the 1 and 6 down. It ends there unless you have access to Honda's Internal Network. You put the serial number in the system and you get the secret code. You can call a dealer, but they probably won't give it to you due to you may have stolen the stereo and read the serial number off the bottom of the stereo. Try looking in your papers when you bought the car for the theft codes or a little white sticker stuck inside the fuse box or glove box when the tech pdi'd the car.
Hi..i need to find the code for my 2004 acura tsx stereo .my battery died and when i turned it on it says code
i pushed the 1 and 6 at the same time and it gave me this #s u 1002 and L 0718 can u please help me
my email adress is [email protected]
thanks in advance
I need the code for 2000 Acura TL and how to input the code.
Write down the serial number when you push 1 and 6. If you purchased the car from a dealer they should give you the code over the phone. Otherwise take the car to an Acura dealer, they should give you the code without charge.
Hi..i need to find the code for my 2005 acura tl stereo .my battery died and when i turned it on it says code
i pushed the 1 and 6 at the same time and it gave me this #s u 1112 and L 5745 can u please help me
Hi can you tell me te code for the stereo for a 2000 acura 3.2 tl
Do you need to find out what it is, or how to enter it? Need more information than that to help you.
how do I get radio code for a 2002 acura tl
how to find my radio code
please help i need the code to a 2003 acura tl type s i dont want to search for a serial number or call the dealer i just want the code. it may sound rude but many attemps have been tried with the dealer and they are trying to charge $100 just for a code.
I have A 2008 Acura TSX and my car died one time and now it is asking me for a code for my radio i did a batter test and a fuse test and they both work do you know the code?
I bought a 2004 acura tl and I had to replace the battery. The radio displays "code" and will not work. I called the prior owner and they don't have the code.
2003 serial u3006 l1810 i need code thankssssssssss
