Question about Avanquest My Invoices & Estimates Deluxe (804526031483)
I can't add anything to the lines in the general info block. I have the titles listed but when i go to edit my invoice there is nowhere for me to click to edit. I'm using My Invoices & Estimates Deluxe 8.0.0.2
  • Anonymous Mar 24, 2014
    key for 9
  • 197 Answers
Do you have the invoice designer or have you desighned an invoice yet
Posted on Mar 22, 2011
Tip
Set up a GPRS data connection for email Please note: Please note that you need a...
Set up a GPRS data connection for email info.png boxAdd('subj0', cBoxClosed);
Please note: Please note that you need a POP3 email account in order to send and receive email messages on your phone. You cannot access web-based email accounts (e.g. Hotmail accounts). 1 Find "Access points"
  • Press the menu icon.
  • Press the fourth tab.
  • Press Phone settings.
  • Press Connectivity.
  • Press Access points.
2 Create new or edit existing data connection
  • To create a new data connection:
  • Press Add.
  • To edit an existing data connection:
  • Press the required data connection.
  • Press the icon to the bottom left.
  • Press Edit.
  • Press the Connection title input field.
  • Press C to clear the input field.
  • Key in EMAIL GPRS and press OK.
3 Select data bearer
  • Press the Bearer drop down list.
  • Press UMTS or GPRS.
  • Press OK.
4 Select authentication
  • Press the Authentication drop down list.
  • Press PAP or CHAP.
  • Press OK.
5 Enter username
  • Press the Username input field.
  • Key in user and press OK.
6 Enter password
  • Press the Password input field.
  • Key in one2one and press OK.
boxAdd('info6', cBoxClosed); The APN name general.t-mobile.uk must be in lower case letters. 7 Enter APN name
  • Press the APN input field.
  • Key in general.t-mobile.uk and press OK.
8 Save and exit
  • Press Save.
  • Press Disconnect to return to stand-by mode.
on Apr 30, 2008 | LG KU990 Viewty
No manual and am receiving unwanted calls at night just became threatening how do i block them
Using Call Block
If you subscribe to Caller ID, you can save phone numbers to the call block list. When a call comes in, the phone compares the received phone number to the numbers on the call block list. If the phone number is on the list, the phone replaces the caller's name with Call Blocked and disconnects the call. (The caller hears a reject tone.)
The call block list holds 20 entries, and all stations share the same list. You can add entries through the Call Blocking menu, by selecting Add Call Block in the CID menu, or by blocking incoming calls. (Only one station can edit the call block list at a time.)
Blocking incoming calls
  1. When the phone rings, wait until the display shows the Caller ID information (usually after the second ring).
  2. If you want to block the call and add this number to the call block list, press Block.
  3. When the phone asks you to confirm, press Menu/select or Block. Blocking an incoming call from an "Unknown" or "Private" number is the same as selecting Unknown Number or Private Number from the Call Blocking menu.
Call Blocking menu options
  1. With the phone in standby, open the menu and select Call Blocking.
  2. Choose one of these options:
  • Create New(Handset only) - Add an entry to your call block list. The phone will prompt you to enter a name & phone number.
  • Private Number(Handset only) - Block all calls from numbers reported by CID as "Private." (This does not count as one of the 20 entries.)
  • Unknown Number(Handset only) - Block all calls from numbers reported by CID as "Unknown". (This does not count as one of the 20 entries.)
Call block entry options
  1. With the phone in standby, open the call block list and find the entry you want.
  2. Press Menu/select to open the individual entry menu. Choose one of these options:
  • Edit(Handset only) - Edit this entry. The phone will prompt you to edit the name & phone number.
  • Delete - Erase this entry from the list & allow calls from this number.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 20, 2011 | Uniden DECT21883 Trio Cordless Phone
How do i cancel or del a invoice
This is from the Quickbooks help menu. To void an invoice
  1. Go to the Company menu, choose Lists, and then click Chart of Accounts.
  2. Double-click the Accounts Receivable account.
  3. In the Accounts Receivable register, select the transaction you want to void.
    Invoices are marked INV in the Type column.
  4. Go to the Edit menu and click Void Invoice.
    Note that VOID appears in the memo field in the register. The charge is removed from the Amt Chrg column, and 0.00 appears in the Amt Paid column.
  5. Click Record.
    The voided invoice will no longer appear in the list of invoices you've created, but it will still be listed in the Accounts Receivable register.
    If you change your mind, click Restore.
To delete an invoice
Important: Deleting an invoice is irreversible.
  3. In the Accounts Receivable register, select the transaction you want to delete.
  4. Go to the Edit menu and click Delete Invoice.
  5. When prompted, click OK.
    The deleted invoice will no longer appear in the list of invoices you've created, and it will not be listed in the Accounts Receivable register.
Dec 12, 2009 | Intuit QuickBooks Pro 2008: Windows
Customize Quicken 2006 Premier invoice
Go to create a new invoice. In the top right corner, there is a box with a drop down called Layout. It says Invoice Default, but if you click on the down arrow, <Customize> will be an option. Choose it. In the list on the left, you will see Logo amd Company Address. That's where you can customize your invoice to show company info.
Jul 13, 2009 | Computers & Internet
Remove data from Accounts Receivable / Aging Report
SOrry I'm not 100% sure of the incorrect calculation - Is this a reconciliation control error from Balances to A/R?
You will need to add the client back into your report as currently it is showing in one report and not another - giving you a difference.
Mar 11, 2009 | Avanquest ProVenture Invoices...
I have Quickbooks 6.0 for mac and my customers are complaining about how I don't have any deposits reflected on their invoices. How can I make that happen?
Add a payment item into you item list. That will let you put a deposit onto the invoice. Let me know if you need help in doing that.
Dec 15, 2008 | Intuit QuickBooks Pro Edition 6.0 (279667)...
Nintendo ds lite
ok here are the steps
1. go out
2. in the right hand side at the bottom is a grey button called info
3. a list comes up with the titles: trainer info, friend list,trainer scclomplisments and settings click trainer info
4. at the right at the top there is edit. click edit
5. choose what you want to edit
6. change it using the stylus and the letters on the touch "keybord"
hope i helped!
Nov 06, 2008 | Nintendo DS Lite Console
LINE 100
If Sale Line 100 is an Excel Template then it is simple.
The Templates are just preformatted spreadsheets which are edited just like any other spreadsheet.
If you mean that you are using the Template to create another document but wanting all the fields to be the same as the Invoice then I suggest the following method:
Copy the Template fron Worksheet 1 onto Worksheet 2.
Add and remove any fields that you wnt to add or remove (Prices would be deleted on this copy and the title would be changed from Invoice to Delivery Docket, etc)
Then (on Worksheet 2) in the fields that you want to be the same - click on the cell you want the same Data in and hit the = sign. Then go to Worksheet 1 and Click on the cell that you want the data to be the same. Hit Enter. This will send you back to Worksheet 2 and you will see that any data entered into the cell in Worksheet 1 will now also appear in Worksheet 2.
Repeat this process for all the cells you want copied from worksheet 1.
When you complete the data in Worksheet 1 (the Invoice) all the data selected will automatically appear in the cells selected on Worksheet 2.
Try this on worksheet 2 select cell A1, type =, then open worksheet 1 and select B1. You will be returned to worksheet 2 and the formula in cell A1 will now read =Sheet1!A1. Enter anything into Shhet 1 A1 and you will see that it appears in the appropriate cell on Sheet 2.
When you want to print off the Invoice and the Delivery Docket - you only have to open each Worksheet and hit Print and a copy of each worksheet will be printed giving you an Invoice and a Delivery Docket with the appropriate info on each printout (eg if you exclude prices from the Del. Docket then after completing all the details in the Invoice will create a Del Docket with all the relevant information other than the prices.
Does this answer your question?
Apr 25, 2008 | Computers & Internet
Avanquest My Invoices & Estimates Deluxe (804526031483) Logo
114 people viewed this question
Top Avanquest Computers & Internet Experts
Alun Cox
Chris Larocque
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
