Question about Car Audio & Video
I got a new deck second hand is what its looking like and it says enter security code well the person i bought it from is nowhere to found and Sony support will not help me out
  • Timothy Otis Mar 21, 2011
    its a Sony XAV-60
  • 19,396 Answers
Hi.
There is no master code for Sony old decks. The only solution is sending it to the nearest service center to be reset.
Please try giving me the deck model. I will try if there is a way to unlock the unit.
Regards.
Ginko.
Posted on Mar 21, 2011
  • Ginko
    Ginko Mar 21, 2011
    Hi.
    Sony XAV-60 is an in car video system. The code cannot be unlocked with the in-car stereo standard procedure.
    This units do not use master code (Sony master was 4357). The code is unique, and it is stored in a database held by Sony. The code is retrieved (not calculated) using the unit serial number. Sony operators are not able to do this by phone, and the unit must be sent in for repair. A small fee will be required.
    At this point the most important thing is not the code, but finding the seller to com-prove the genuinity of the unit. After that you will decide if to take the $500 unit to the police, or to the nearest Sony store for a $40 unlock.
    Regards.
    Ginko.
Keyless entery keypad how to reset
Each vehicle equipped with a keyless entry keypad is programmed with a five-digit entry code. This code is provided to the customer through a wallet card in the owner literature package. In addition, this code is available through a diagnostic tool and is also printed on the vehicle security module label. When entering codes each digit mst be entered within five seconds of the previous button press.
Do you know the original five-digit code ? You need the original to reset with a new one .
Programming/Erasing Personal Code
A unique personal five-digit code can be programmed by following these steps:
  1. Enter the factory set five-digit code (the keypad will illuminate when pressed).
  1. Press 1/2 within five seconds of Step 1.
  1. Enter the unique five-digit code.
The personal code does not substitute for the permanent factory set code. Either code can be used to access the vehicle. In addition, if a second personal code is programmed, it overwrites the previous personal code. To erase a personal code, carry out the following procedure:
  1. Enter factory set five-digit code.
  1. Press 7/8 and 9/0 at the same time within five seconds of Step 2.
The system now responds only to the factory set code.
If you do not know the code ,it is located on the vehicle security module located under the dash some where or in the trunk . Sorry I can't be more specific ,my service info doesn't show sable .
Feb 17, 2016 | 2003 Mercury Sable
RESETING INTRY DOOR CODES FOR A USED 2010 MECURY GRAND MARQUIS
You have to have the factory code to progam a new code in one code is perminantly programed the sedond code can be entered after the original code is put in. by following these steps
1. Enter the factory set code. Note: The keypad and the interior lamps
will illuminate when pressed.
2. Within five seconds press 1 • 2 on the keypad to enter the
programming mode.
3. Enter your personal 5-digit code. Each number must be entered
within five seconds of each other.
4. Press 1 • 2 to store the first personal code.
5. The doors will lock then unlock to confirm programming of the new
code.
To store a second personal code:
programming mode.
3. Enter a second personal 5-digit code. Each number must be entered
If you dont have the original code you will have to find a factory scanner to retrieve the code some places will do this for free others charge. The code cn usually be found in the owners manual on a card.... if not to the dealership is where you will have to go
Jun 03, 2011 | Mercury Grand Marquis Cars & Trucks
I just bought a 2002 explorer and it has a keypad entry system. There are no books with it. How do I find the code or enter a new code.
BEHIND DRIVER DOOR PANEL OR RIGHT SIDE REAR TRIM PANEL LOOK AT PASS SIDE REAR DOOR OPENING AND PULL REAR TRIM OUT THERE its a five digit code
To erase any personal code set by the prior owner, use these steps:
1. Use the keypad to enter the factory set code.
2. Within five seconds, press the 7/8 and 9/0 buttons simultaneously.
3. The system will now respond only to the factory set code.
You can program your own personal code via these steps:
2. Within five seconds, press the 1/2 button
3. Within five seconds, begin entering your personal five digit code.
(Each subsequent keypress must be within five seconds of the previous)
4. The system will now respond to both your new personal code and the factory set code.
5. Put the factory set code you wrote down in a safe place. It will always open your door, and it won't do you any good if locked inside your vehicle.
Hope this help
Sep 24, 2009 | 2002 Ford Explorer
Locked kenwood deck
Common Kenwood Security Codes
Many Kenwood radios are configured with the same security codes:
KCAR - This seems to be a "backdoor" to some Kenwood models.
3051 - This is the security code which is printed in the manual of many Kenwood models.
1234 - This is a security code commonly chosen by Kenwood owners.
Entering Your Kenwood Security Code
If the car battery fails or is disconnected, the Kenwood will ask for the security code.
The procedure to enter your security code differs on various models of Kenwood car stereos. Here are three of the more common procedures:
Type 1
During the code request mode, while holding the DISP key depressed, press and hold the Volume UP or DOWN key for 3 seconds until the "..." display disappears.
Enter the security code using your Kenwood remote.
Type 2
Press the "Auto" button and "Track up" on the face of radio at the same time until the four dash lines disappear.
Type 3: Model# DPX-4020 and DPX-4030
Press and hold the 1 then the 6 preset keys until the display shows the letter 'C'.
Entering Letters on your Kenwood Remote
To enter a letter using your Kenwood remote, press a button once for the first letter, twice for the second letter, and three times for the third letter -- then press the Track Up or Next Track key to send the letter.
To send the letter 'A', press the 2 key once and then press the Track Up key. To send the letter 'B', press the 2 key twice and then press the Track up key.
Finally, when you are done entering all of the letters, press and hold the Track Up button for 3 seconds.
The key sequence to enter the security code KCAR is:
5
5
Track Up
Track Up
Track Up
7
7
Track Up
Your Kenwood should then enter tuner mode.
A Security Code Bug in some Kenwoods
There is a reported bug in the security code handling of some Kenwood stereos. In models with thie bug, the security code is stored incorrectly. The workaround is to enter the wrong security code.
In models with this bug, you have to decrement the third character of the security code by one. If your security code was 1111, you would enter your security code as 1101. If your security code was 9999, you would enter 9989.
Jun 10, 2009 | Kenwood KDC-MP528 CD Player
Need a code?
i brought a sony cdxm630 second hand and never got a code with it and manual tells me nothing bout a code plz help
Jun 03, 2009 | Sony CDX-M630 CD Player
How to reset keyless entry on 2005 taurus
To reset the personal code you will need the permanent code supplied by Ford. This will be on a white card left in the clove box or in the owners manual bag. This can also be retrived if you go to a Ford dealer. Expect to spend around $50 at the dealer unless they can help you out. Once you have that do the following. Good luck.
1.Enter the permanent factory remote keyless entry (RKE) keypad code.
2.Press the 1/2 button within 5 seconds to activate the programming mode. Holding the 1/2 button for more than 2 seconds after activation erases the stored personal code.
3.Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed. Entering any new personal code automatically erases the old personal code.
Feb 23, 2009 | Ford Vehicle Parts & Accessories
Door key pad, won't unlock door
  1. Enter the permanent factory remote keyless entry (RKE) keypad code.
  1. Press the 1/2 button within 5 seconds to activate the programming mode associated with the memory position 1 settings. Holding the 1/2 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 1 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 3/4 button within 5 seconds to activate the programming mode associated with the memory position 2 settings. Holding the 3/4 button for more than 2 seconds after activation erases the stored personal code.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed and associated with the memory position 2 settings. Entering any new personal code automatically erases the old personal code.
  1. Press the 5/6, 7/8, 9/0, 7/8 and 9/0 button within 5 seconds to activate the programming mode or allow the system to timeout.
  1. Within 5 seconds, enter the new 5-digit RKE keypad code. The door locks lock and unlock to confirm the new code is programmed. Entering any new personal code automatically erases the old personal code.
Jan 23, 2009 | 2005 Ford Freestyle
Resetting Security Code
master code for imei  355397009002339 is  3537356212.
After unlocking it goto security option.Now it will ask you for the password so enter 3537356212.And after entering this no it will ask you for a  new password..that's it enter new password for 2 times and you are done.
Sep 05, 2008 | Nokia 1100
PUK CODE ERROR
PUK (personal unlocking code) is a code to unlock security code. Any phone allows three trial of inserting security code; If we insert wrong code three time it ask for PUK., and that is your problem. You have to ask your provider to give you that code. For that you have to call your operator's care centre or help line from landline of other card of same operator. Operator on line will ask you about your mobile no. and 2-3 question regarding your personal detail and provide the PUK code. Enter the PUK given my him & your cell will be unlocked.
Jan 08, 2008 | Sony Ericsson K610i Cellular Phone
KCD-X590 is looking for a code that i never put in, and i bought the deck brand new
Method of clearing the programmable security
code (KDC-MP632U/X590)
1. While "– – – –" is being displayed, press [->> ] key for at
least 3 seconds while pressing [AUTO] or [TI] key.
This makes "– – – –" display disappear.
2. Using the remote controller, input "KCAR".
Press remote controller [5] key 2 times (Input for "K") and
then press [->> ] key.
Press remote controller [2] key 3 times (Input for "C") and
then press [ ->>] key.
Press remote controller [2] key once (Input for "A") and then
press [->> ] key.
Press remote controller [7] key 2 times (Input for "R") and
3. The security is released and the unit enters the STANDBY
mode.
4. If a wrong code is input, the unit goes into the Code Re-quest
mode.
Oct 14, 2007 | Kenwood KDC-X590 CD Player
Car Audio & Video Logo
19 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
