Question about Minuteman C46000-00 Self Contained Carpet Extractor Vacuum
The minuteman C46000-00 is leaving stripes in the carpet. They are dark and seems to be not cleaning those areas. I removed all of the jets and made sure they were clear.
How to take spraybar off
There should be screws attached to base? Minuteman is the worst.
Apr 04, 2014 | Minuteman C46000-00 Self Contained Carpet...
How to clean your carpet?
Clean the carpet with regular vacuum, baking soda or vinegar is the best cleaning option to remove the stain or dirt over the carpet and also helpful to make long life of carpet with cleaning.
_________________________
crawl space vapor barrier seal
Jun 28, 2012 | Vacuums
Looking for part number 831238 1/6hp brush motor
Try these people:
http://www.michco.com/p-102421-minuteman-ambassador.aspx
1- 800-331-3339
CustServe@Michco.com
831238-2
Item On Page-7-8 Ref# 128
Qty Required-1
This item replaces part#(s): 831238
Apr 16, 2010 | Minuteman C46000-00 Self Contained Carpet...
How much is a brush motor? Is it easy to replace or am i better off buying a new minuteman?
A new Brush motor is $305.02
Try these people:
MOTOR, 1/6HP 120VDC X17 831238-2
Qty Required-1
  • 1-800-331-3339
  • Michigan Company Inc.
    2011 N. High St.
    Lansing, MI 48906
    Phone: (517) 484-9312 or 800-331-3339 US only Monday - Friday 8AM- 5PM EST Excluding National Holidays.
    FAX: 517-484-9836
    E-Mail: CustomerService@Michco.com
    Dec 30, 2009 | Minuteman C46000-00 Self Contained Carpet...
    Jets quit spraying
    My Minuteman c46000-00 isn't pumping any fluid through the jets. Would this be an alkaline problem, and if so, will baking soda and vinegar clear it up?
    Also, where can I get a fix-it manual for this unit.
    Does anyone know how old this unit might be??
    Tks for your help!
    Rick
    Dec 11, 2009 | Minuteman C46000-00 Self Contained Carpet...
    Not dispersing water all I need is a manual.
    I had the same prob. If you have water/soap solution at the upholstery handle, and no water/soap at the front jets, then the jets are clogged. remove the water tank, and you'll see the 2 jets (mine are red) at the front of the machine. Carefully release thw jets by squeezing the 2 tabs on top and lift out. Remove the hose that goes to the jet and clean out the jet (I used a toothpick) and rinse well. I also flushed out the system (hoses) by leaving off the jets and replacing the tanks (water and soap) I filled the soap tank with water too. Then I turned on the machine and let it run for a few minutes (I taped open the lever on the handle) to make it easy on me. Then replace the jets where you took them out, and all should be fine now. I suggest that when your finished using you machine to do your carpets, rinse out the lines with water in both tanks, to prevent soap from drying in the hoses.
    Apr 06, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
    Minuteman C46000-00 Self Contained Carpet Extractor Vacuum Logo
    61 people viewed this question
    Top Minuteman Vacuums Experts
    Are you a Minuteman Vacuum Expert? Answer questions, earn points and help others
