Question about HP Photosmart C5580 All-In-One InkJet Printer
Printer keeps shutting down and coming up with error messages this is only one of the 824C1500
  • 684 Answers
Turn off the Printer and Unplug it from the Power Supply.
Remove the Cartridges from the Printer!!!!!
On the Backside of the Cartridge you would see a Copper Stripe, Wipe the Copper Stripe using a Paper Towel!
Reinsert the Cartridges and Restart the Printer.
Good Luck!!!
Posted on Sep 17, 2011
Printer error has occurred - says to cancel printing and shut off, then start again. I wasn't printing and there is nothing to cancel. Shut down numerous times and won't clear & start.
Brand, model, operating system, source of the error message all help in exploring an issue. The printer was shut down several times and the error message did not clear? If the printer is shut off for a significant time allowing discharge of any capacitors (which are similar to batteries) and yet you get an error message when you power back up, it suggests that there is a mechanical problem or inking problem. This would require troubleshooting of the device. You might find help for that on the manufacturer's site. HP, for instance, has a diagnostic program that can be downloaded.
Sep 01, 2017 | PRINTER Office Equipment & Supplies
HP PRINTER C7280 ALL IN ONE PRINTER. ERROR CODE ON printer LED SCREEN- INK SYSTEM FAILURE as above code.
Getting the blue screen on the printer LCD with the on/off switch symbol and the error 824C1500. Get a new and different error message each time I unplug the printer, wait a minute or so and then re-plug it in. I responds to no button pushing and will not turn off at all. Is there a simple fix for this problem or is it a throw-away?
for more help visit https://cbrtechsolutions.net
Oct 07, 2010 | Office Equipment & Supplies
Error 0xc19a0035, printer seems to be stuck in shut down mode now. We were out of yellow ink, I have been trying to print in b/w but just kept giving me the above error message, I have replaced the...
Hello there is this link you can try
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Problem starts with "paper jam" messager. Can not shut down as light keeps blinking and "shutting down" message is on screen.
hi!!!! in your case,try to unplug the power of your printer and check the material that stock inside the printer that can cause the printer paper jam and after you check to plug it back.It is normal when the printer is blinking when the printer is paper jam because that is the error when your printer is paper jam.
May 11, 2009 | Office Equipment & Supplies
Error message 0xc 180001
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the printer off. Keep holding the buttons down until the printer shuts off and then turn it back on.
If it then turns itself off again, turn it back on; it should start the calibration sequence (it takes about 5 minutes) and when it finishes, you should have a working printer again!
Apr 24, 2009 | HP Photosmart C3180 All-In-One InkJet...
Error message shows up on printer screen oxc18a0101
Found this link that tells you how to reset the printer.
http://www.fixyourownprinter.com/forums/printer/39471
Excerpt on resetting the printer from the post linked to above:
These are from the link above:
Reset the system by holding down the OK, Cancel, Black, and Color buttons down at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turn it back on.
Apr 05, 2009 | HP Photosmart 3310 All-In-One InkJet...
Hp photosmart printer c4280 all in one error message
Is it make your PC shut down.
Please uncheck the printer from Msconfig:
Start --> Run --> Type in --> msconfig --> go to Start up Tab --> uncheck printer entries -- > Reboot PC.
Then check for it. Let me know if I can assist you further.
Regards
Ellin
Sep 25, 2008 | HP PhotoSmart C4280 Laser Printer
HP Photosmart D7460 problem
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
/Putte
May 15, 2008 | HP Photosmart D7460 Printer
Samsung CLP 500 series Laser Printer
If the messages are because the two units have reached their rated page count, you need to reset this via the printer menu system - see user handbook
Nov 12, 2007 | Samsung CLP-500 Laser Printer
HP Photosmart C5580 All-In-One InkJet Printer Logo
567 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
