Question about Sony PlayStation Portable (PSP) Slim (PSP-2000) Console
Hi, I have bought PSP 2000 with firmware version 5.03. The shopkeeper hacked it for me and installed chickhen software on the memory card. I ran it several times but now I am facing a problem. When I click on Hen to run it, PSP restarts and I can not load my games. Please advise. Thanks
  • 77 Answers
If you can't load only the NEW games that require higher Firmware versions, then you need to update Prometheus. Unfortunately, I can't help you with that here. Just google it.
Posted on Mar 21, 2011
How to chicken?
Hello there Sir/Madam! My name is Alex and I work under FixYa.com expert team surveillance.
Firstly make sure your PSP-3000 or TA88v3 PSP-2000 has PSP Firmware 5.03 installed. Check in your PSP XMB go to Settings/ System Settings / System infomation. If you don't have PSP 5.03 installed download it here. Create a folder called UPDATE in PSP/GAME on your memory stick and place the eboot from the archive into the folder. Run the 5.03 Firmware update from GAME / Memory stick and you will have 5.03. The firmware required to run ChickHEN.
Now download the ChickHEN R2 release from here. Open the CHickHEN R2 archive and place the folder inside Slim with gif images into your PSP memory stick location like so PSP/PHOTO (later it will be PSP/PHOTO/ChickHEN). Now place the h.bin into the root of your memory stick pro duo. Where the folders PSP, MUSIC etc are located.
Ok next step place the memory stick into the PSP. We have found this step helps ChickHEN boot with less attempts, go your PSP XMB, to settings and Restore Default Settings. Your PSP will reset, now go back into settings and turn off UMD Auto-Start and UMD Cache. We found ChickHEN loads in 2-3 goes after doing this.
Now go into Photo / Memory Stick and ChickHEN. And wait, you will see five egg giff images, these will start to load thumbnails. Your PSP may freeze and reset. Just keep retrying and ChickHEN R2 will load up....But if you see flashing colors, your PSP will reboot into ChickHEN your homebrew ready!
With ChickHEN R2 loaded now starts the fun part. (P.S You can put your PSP into standby now so you don't have to go through the whole process again)
Hope this helped and/or advised you on your next move.Please rate my solution, thanks in advance. Wish you good day
Adzic A.
May 09, 2011 | Sony PlayStation Portable (PSP) Console
Tip
How to hack a psp without pandora ?
Since ChickHEN is out PSP-2000 owners with a TA88v2 or less or a TA90v1 motherboard now have the option to now install Custom Firmware without the need of a Pandora battery.We have put together a Easy installer that contains everything you’ll need. Hellcats Recovery flasher, ChickHEN, PSP firmware update 5.00.
Warning make sure you only try this on a PSP that will accept PSP Custom Firmware flashing (Custom IPL) otherwise you will brick your PSP!!! PSP-3000’s will not take CFW. Check your PSP will take CFWhere. Or run ChickHEN first, then when ChickHEN is loaded run PSPident from the Game XMB menu. (PSPIdent with install with this easy installer)
Steps to install CFW on a PSP Slim without a Pandora battery.
1. Check and triple check you have a hackable PSP that will accept
custom firmware flashing without resulting in a BRICKED PSP. Make sure you have a PSP with a TA88v2 or below only + or TAv90v1. If your PSP has a TA88v3 or above or is a PSP-3000 DO NOT proceed!!! You will brick your PSP.
Run the installer and point it to your Memory stick Pro Duo root.
2. If you don’t have don’t have PSP firmware 5.03. Get that here: PSP Firmware 5.03 Make a folder called UPDATE in your PSP/GAME folder and place the eboot in there on your memory stick pro duo.
3. Now lets run ChickHEN to have a homebrew enabled environment. In your PSP go to photo then click the ChickHEN photo and wait. If the PSP jams, please retry. If it flashes colours and reboots you have loaded ChicKHEN. Check your system info to be sure it say’s 5.03 ChickHEN R2. If you need help getting ChickHEN to run please visit this post.
4. Now with your PSP rebooted in ChickHEN go to your PSP XMB game menu and run Hellcats Recovery and install 5.00 M33!!! Your PSP will reboot, follow the instuctions to install PSP Custom Firmware 5.00 M33. After your done you can update to 5.00 M33-6
Easy ChickHEN CFW installer (Without Pandora) (27.9 MiB,)
visit www.newzgadgets.co.nr
on Mar 10, 2010 | Video Game Consoles & Games
My psp was already modified, installed iso games in iso folder, and already played it but when i turned it off, my games was lost and my plugins does not work. when my memory stick was inserted to my psp...
Hey there! This means that the Mod on your PSP 3000 is not up to date as the 3000 uses a different mod than the one used for your PSP 2000. That is why.
You will have to install the the ChickHEN for the PSP 3000.
Here's the website for hacking your PSP 3000:
http://www.psp-hacks.com/2009/12/15/psp-custom-firmware-5-50-gen-d3-and-5-03-gen-c-for-hen-released/
Please rate and comment, thank you.
Apr 17, 2011 | Video Game Consoles & Games
I really need help to hack my psp 3000 version 6.2.. can someone plz help me..??=(
Hi rosyhini_95, Based onyour concern, I suggest trying the following steps: 1. Connect the PSP to your PC with a USBcable. 2. Press the "home" button on thePSP --> atthe lower left of the screen you can see the home button. 3. Use the left-right directional buttons tofind "Settings", then the up-down buttons to find "USB Connection"on the PSP. 4. Press the "X" button, your PSPshould display "USB Connection". 5. Please wait until your computer tells youthat a new USB device has been connected, then show you a new generic harddrive, usually E: or F: 6. Click on the drive letter thatcorresponds to the PSP unit. 7. place the h.bin file in your MS root andthe chickHEN folder with images in PSP/PHOTO on your memory stick pro duo. -> if you don't have that folderPSP/PHOTO don't worry just create it and place the folder in there. -> you would put the Slim ChickHEN folderin PSP/PHOTO so it looks like PSP/PHOTO/ChickHEN with the pretty egg gifsinside. 8. Now you need to make sure that you havePSP Firmware 5.03 installed. If you dont have you can download it here: 9. Ok now in the PSP XMB go to Photo's /Memory stick and then the chickHEN folder and wait! If it works you'll see afew colours flash and then your PSP is rebooting itself loading up the chickHENhomebrew environment. Now you can go to Game in the XMB and load some homebrew. 10 . You can download the CHickHEN R2 forFirmware 5.03 here:
Hope ithelps, Thank youfor using FixYa.
Dec 20, 2010 | Sony PSP (Piano Black)
I have a psp 5.51 and now i want to hack it but i haven't got any hack for it please help
With PSP3000 models there is at present No Permanent hack/cfw for it.You can install cfw(custom firmware) on it using chickHen + a cfw. To do this you put chickHen + your cfw on your mem stick and run chickHen first then you can install the cfw which turns the psp operating system into a hacked psp.But if you turn off the psp or the battery is allowed to run flat then the cfw will die,meaning when you re-charge your psp and boot it up, your psp will not run backups again until you re-install chickHen + cfw.Do a search on google or youtube for "howto install chickHen or cfw on PSP3000" .
Oct 25, 2010 | Sony PSP-3000 Black Console
Formatted my psp and now it can't detect games.
  1. You need to download first ChickHEN R2 software from the internet and copy it to the PICTURE folder of your Memory Stick.
  2. After that you need to run the ChickHEN software to update your PSP firmware version.
  3. After that you need to copy the 5.03 GEN-C to your Memory Stick and run this update.
Jan 24, 2010 | Sony PlayStation Portable (PSP) Console
How can i play the games from memeory card in psp 3000 slim model game
ok well i just bought mine but it was used and i looked at the official firmware and it was 4.20, so i used the official update 5.03 and then updated it to that official firmware and then i used chickhen for my firmware 5.03 and then i used Gen A to play psp and playstation games! if you look in system settings then look at system info youl will see ur firmware, if it is below 5.03 then use this method with these files
http://rapidshare.com/files/307164750/psp_3001_only_for_5.03_and_below.rar.html
ok download this file i made for you, then extract all 4 files.
extract psp 5.01 fw update and put the eboot file in a folder named UPDATE and place that folder in your psp. hook your psp up to your computer and go to psp then game and put the update folder in game.
now make sure you have a full battery or at least a half charged batt with the charger on it! repeat keep your chrager on at all times from now on. now go to ur psp and chose the game option and the update folder will be there and hit x and it will go to the update process and just hit yes and agree to the terms and it will update the psp to ofw 5.03 and it will ask to shutdown. now turn on the psp and check system info to see if it is 5.03. it should be
no hook the psp back up to the computer and go to the picture folder and delete and pictures you have. now extract the chickhen file and put the slim picture folder with the files in the picture folder. put the chckhen for psp slim in the picture folder on your psp[ make sure that the pictures are in the chickhen fold} just open the slim folder and put the chickhen folder in ur psp picture folder k
and make sure you also put the h.bin in the root of the psp. this means the first folder you see when you open the psp. if you dont know what root of a card is then find out, its the very first folder thing that comes up when you open ur psp memory stick on ur computer
ok see the folder psp and others thats your root. put the h.bin file there,
ok and now you can put the 5-03gen-for-hen files in your psp. hook uo your psp to the computer and go to PSP then GAME look to see what the name if your psp drive is and run the the file called lauch me in the gen file for hen and it will bring up a menu. select what psp you have 3001 for you and then chose full install and psp install chose yes and then put the drive letter or name in the psp unit drive box. for instance if your psp drive name is G then just put G. you can see what the drive name or letter is by looking at the root folder and look up at the right top corner and it will say the name. then hit start and it will finish pretty quicly.
ok now go to ur pictures folder and open the chickhen and dont press anything and it should load if not then try again and when it does go green and load go to ur game folder and run the installer loader file and the hit L or R to install custom firmware then whens its done hit O and it will load in the fully hacked mode which lets you play psp games and psx games as well.
you never have to install the custom firmware and but you have to uyse the loader every time you turn it completely off.
see when you turn it off completely then hack is gone but all you have to do is run Chickhen again from the picture folder the run the installer loader and hit just O and it will load fully hacked again. you must repeat this step when ypu turn it off
Nov 14, 2009 | Sony PlayStation Portable (PSP) Slim...
Runescape on my psp
freewebs. com/ roshanb/ runescapeonpsp.htm helps(take out spaces)
Latest CFWEnabler : 05/07/2009
Download:
http://2f19b96d.seriousfiles.com
Changelog:
- Fixed a bug when playing within Infraestructure
- New system version
- Improved the Pops flashing system
- New update server.
Just copy the CFWEnabler folder into /PSP/GAME , then go to Games and run the installer
1)INSTALLING 5.03 OFFICIAL AND LOADING CHICKHEN R2
a)INSTALLING 5.03 OFFICIAL
Firstly, you CANNOT do this unless you hava a PSP with Version =<5.03 . To check your PSP FW go to Settings-> SystemSettings-> System Information . If the version is 5.03 , skip thispart and follow the guide below to install ChickHEN . If you have alower version follow this GUIDE in order to install OFW 5.03 .
-Download 5.03 OFW (http://135ff34d.seriousfiles.com)
-Connect your PSP to your PC via USB and create a folder in PSP/GAME named UPDATE.
-Copy the .EBOOT file in PSP/GAME/UPDATE.
-Run the update from your PSP .
Now you should have a 5.03 OFW PSP , just what you need in order to load the Tiff Exploit.
b)LOADING CHICKHEN R2
Some useful tips for those who can't get the ChickHEN to work :
-Restore Default Settings
-Set UMD Auto Start and Cache OFF.
-Make sure you're on 5.03 OFW
-Format Memory Stick. ( this will erase all the data from your MSso you'd better backup your files on your PC before doing it )
-Try another method as this video shows :
(http://ad452dd7.linkbucks.com)
-Don't give up , just try and be patient.
Note that the files needed for PSP 2000 and 3000 series are different than the ones needed for PSP 1000 so don't screw it up.
DOWNLOAD:
FOR PSP SLIM ( 2000 & 3000 ) :
-Download ChickHEN R2 Easy to Load
(http://0639570b.thesefiles.com)
FOR CLASSIC PSP ( 1000 ) :
-Download ChickHEN R2 Easy to load
(http://d249d993.thesefiles.com)
-Copy h.bin to the Memory Stick ROOT .
-Copy ChickHEN folder to PSP/PHOTO ( create one if needed )
-Navigate to your PHOTOS folder , and enter the ChickHEN folder.And wait, you will see some images, these will start to loadthumbnails.Go all the way down to the last image. Your PSP may freezeand reset. Just keep retrying and ChickHEN R2 will load up….But if yousee flashing colors, your PSP will reboot loading the ChickHEN.
For those who can't load the ChickHEN files check above for useful tips and remember to restore default settings.
Check your PSP's version to make sure. If the version is somethinglike 5.03 ChickHEN R2 you should be fine and ready to install CFW.
2)INSTALLING CUSTOM FIRMWARE
Do NOT try this on any PSP 3000 or PSP 2000 unhackable mobo's this is only for PSP Phat and 2000 hackable series.
This will permanently install CFW onto your PSP
ChickHEN must be enabled.
-Download Recovery Flasher 1.60
(http://926291d9.thesefiles.com)
-Download 5.0 OFW
(http://a3b04c08.thesefiles.com) -direct download
-Copy the Recovery folder to PSP/GAME .
-Also copy the 5.0 official update renamed as 500.pbp to PSP/GAME/RECOVERY folder .
-Go to GAME and run the program and install 5.0 M33-6 !
In the end , press SELECT while in XMB and change UMD Iso Mode to''M33 Driver'' or ''Sony NP9660''. I also recommend formatting memorystick. Place your CSO/ISO games to the ISO folder on your memory stickroot.
GUIDE created by : PSPgamen OF AFTERDAWN
Any questions ? probs ? post here !
Enjoy :)
Aug 26, 2009 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Slim (PSP-2000) Console Logo
70 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
