Question about Yamaha RX-V595 Receiver
Problem with potentiometer Does anybody know where is possible to buy volume- potentiometer for Yamaha RX-V595RDS? When I turn receiver on sometimes one output chanel (speaker) is silent till I turn potentiometr to the right and back few times.
    Brigadier General:
  • 8,546 Answers
A little more triage would be in order before you take a knife to it.
Turn the volue to something in the middle.
If it's only an analog source doing it I would suspect a bad switch contact somewhere in the signal path. Typically, it might be a switch you rarely use, like a Tape Monitor or Mute. It's wise to occasionally (with power OFF) manipulate all manual controls throughput their ranges a number of times to wipe oxides from their contacts.
Posted on Mar 21, 2011
I need codes for a Yamaha rx-v2500 receiver. The codes listed turn it on but not off. Can you help??
Joseph, codes 0081,0082,0176, 0186, 1176, the attached manual may have more codes.
Yamaha rx-v2500 receiver, try the auto programming feature on your remote to set up universal remote. It is possible the remote may not support your equipment and you will have to replace with compatible remote. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RC Yamaha RX V2500 Receiver and DVR PVR 5 HELP
Codes for Universal Remotes Codes for Universal Remotes How to Program Universal Remote
Yamaha RX V2500 Owner Manual Setting Remote Control Codes
Aug 08, 2016 | Yamaha Audio Players & Recorders
No sound on left front speaker
you need to set up the individual volume levels for each speaker.
do a sound test tone which will check for a signal from each speaker.
if you hear the speakers at different volumes you know you need to adjust the ones that are too weak. hope this helps
Mar 27, 2014 | Yamaha RX-V420 Receiver
Yamaha receiver picture disappears and reappears when changing volume
I had the same problem with HDMI input to the RX-V373 from a DirecTV receiver. The RX-V373 volume display and menus on the screen are HD only, which forces the monitor to switch modes when viewing SD.
My solution was to turn off 480i and 480p signals from the DirecTV receiver, and also turn off its native output. The DirecTV receiver then upconverts SD signals to HD. Changing RX-V373 volume then doesn't affect monitor video mode.
May 10, 2012 | Yamaha Audio Players & Recorders
LOSS OF BASS IS THERE A FUSE IN THE RECEIVER FOR THIS
Jeff, The speaker it self may be fused. Check the attached links,instruction and guides, Good luck
Yamaha V905 Owner Manual
YAMAHA RX V595 V905 RX V595RDS Service Manual free download schematics...
Feb 27, 2011 | Yamaha R-V905 Receiver
My yamaha keeps turning off as soon as i turn it on...
Buy yourself a 120mm 12volt computer case fan and a 12volt power pack. Mount the fan with some double sided tape to the grill on top of your AVR. Have the fan mounted so it draws air out of the amp and turn it on when you know you are going to crank up the volume. Try and buy a fan with the lowest noise level so it isn't annoying
Dec 10, 2010 | Yamaha RX-V595 Receiver
My Yamaha RX-V661 shuts off at moderate volumes.
Try to disconnect speakers one by one and see if any of them causes the problem.
Nov 05, 2009 | Yamaha RX-V661 Receiver
Volume dial doesn't work well anymore - when turning louder, sometimes turns volume lower or just stays at the same volume level
Some manufacturers allow you to set a max volume limit so you don't blow your ears off.  Check the users manual to see how to turn it off.
Also, have tech support install a new potentiometer for you.
Oct 25, 2009 | Rotel RX-975 Receiver
Yamaha RX-890
I have the same problem with a RX-V995 Yamaha Reveiver.
Tim
Sep 05, 2008 | Yamaha RX-V995 Receiver
Volume control
Do you have the volume at -5dB when listening to source 1? That would in most cases be far beyond the receivers capabilities when listening on an average loud recording from a standard source. I would guess that your source has a way to low signal.
However, i assume the answer to the question is this:
There is a way to trim the levels of each source (Input). It can be adjusted -6dB to +6dB.
Select the input you want to adjust. Hit Set Menu on the remote. Then Manual Setup -> Input Menu - > Volume Trim. Adjust up or down. In your case adjust your source 1 to + 6dB and all other inputs to -6dB.
Regards Alex
Mar 02, 2008 | Yamaha RX-V657 Receiver
Jvc rx 318 receiver
The problem you describe is common to JVC amps. This control has a motor mounted on the back of the circuit card that drives the volume control up or down using the remote control for this system. The looseness of the volume control cannot be repaired. The shaft has separated from the potentiometer. I don't know if JVC has this part any longer but it has to be replaced as a unit (volume control card).
Nov 07, 2007 | JVC RX-318 Receiver
Yamaha RX-V595 Receiver Logo
100 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
