Question about Samsung Digimax 530 Digital Camera
I purchased a SD card 4gb for digimax 530 but the camera is telling me that there is a "card error", did I get the wrong SD Card?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
You didn't get an SD card at all, but an SDHC card. While it fits into the slot, it is electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Posted on Mar 21, 2011
When insert maxell maxdata 4 gb memory card camera says card read error
The A402 works with MMC and SD cards. Your 4GB card is an SDHC card. While it fits into the slot, it's electronically incompatible and won't work with the camera. You need to use an SD card, 2GB or smaller.
Mar 18, 2013 | Samsung Digimax A402 Digital Camera
Memory card after formatting, say check card (samsung camera)
Probably, especially if your card is a 4GB or larger SDHC card, then it's definitely the wrong card. The older Digimax S800 camera can only use standard SD cards (2GB or less). Fortunately, these are very inexpensive these days, and may be found on Amazon if your local store no longer carries them.For others reading this experiencing similar problems, please see this article.
Nov 27, 2011 | PNY 4GB Secure Digital High Capacity...
L830 Digital camera - says "card locked" Tried to move the tab at the side of the memory card but still locked?
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out (sorry, an A540 can only use 2GB or less standard SD cards. These are very inexpensive these days, and are available on Amazon if your local store no longer carries them). There are also other common causes if the above didn't help, with troubleshooting steps for this problem listed here.
Sep 15, 2011 | Samsung Digimax L830 Digital Camera
I bought an 4gig SD (HC)? card for my Camera. On start up, the Camera reads "FORMAT SET:OK" but when I select OK it Says CARD ERROR!. I've traded the "defective" one in for a...
The A402 works with MMC and SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible. You need to use cards 2GB and smaller.
Jan 15, 2011 | Samsung Digimax A402 Digital Camera
Installed a Sandisk 4 GB memory card and camera says "CARD ERROR". What gives?
The A402 is designed to work with SD cards. Your 4GB card is actually an SDHC card. While SDHC cards will fit into SD devices, they will not work. You'll have to stay with SD cards, 2GB and smaller.
Jul 29, 2010 | Samsung Digimax A402 Digital Camera
I purchased a 8gig sd card and tried to put it in
The camera only supports SD memory (limit 2GB), not SDHC (4GB and more). The manual claims up to 1GB guaranteed, though the camera recognizes my 2GB card card.
Nov 29, 2009 | Samsung Digimax D53 Digital Camera
Is the vivitar dvr 530 compatible with sdhc cards
Plug the SD card with contact terminals facing away from battery. It most likely is using internal memory which is much smaller. All cards under 4gb are normal SD. The camera should be able to format the card, or use an adapter and windows will format (default settings).
Jan 03, 2009 | Vivitar DVR 530 Flash Media Camcorder
Samsung Digimax 530 Digital Camera Logo
238 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
