Question about Acer TFT screen 17" AL1715MS Flat Panel LCD Monitor
When I turn on my computer it goes through the windows process and then the screen goes blank and says in a box " no input controls ". Help
  • 11,361 Answers
It is telling yopu it is not getting the video signal from PC or it may have problem. You should try it with another PC to find out if it is PC or Monitor problem, cables are good?.
Post back what you find.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 21, 2011
Please help me-- My computer is not turning on... Can I fix this?
probably motherboard problem, display adaptor (if you are not using card) .Try press F8 during startup windows. If there is a SAFE mode, reinstall the windows.
Mar 13, 2013 | Computers & Internet
Tip
How do you Sync your Gmail contacts with a Windows Mobile
<p>The process of manually entering your Gmail contacts in the address book of your Windows Mobile smartphone can be time consuming. In fact, this process even more frustrating if you regularly move from one device to another. Fortunately, the sync option in most smartphones, including Windows Mobile devices, makes it easier for you to use your Gmail contacts for different platforms. In Windows Mobile devices, this option made possible by Google Sync. Google recommends to make sure that you back up all contacts and calendars from your phone to your computer before continuing. <br /> <p><br /> <p>1. Start the Microsoft Exchange ActiveSync application on the Home screen of your Windows Mobile device. <br /> <p><br /> <p>2. Choose "Set your device to sync", "m.google.com" in the "Server Address" field, select "This server requires an encrypted connection (SSL)" and choose "Next." <br /> <p><br /> <p>3. Enter your Gmail credentials in the "User Name" and "Password" box, leave the "domain" box unchanged. If an error occurs due to the abandonment of the "Domain" field is blank, enter "Google" box. <br /> <p><br /> <p>4. Select "Next", select the "Contacts", click "Finish" and then click the "Sync" softkey. You have enabled the synchronization of your Gmail contacts on your Windows Mobile device. <br />
on Aug 18, 2011 | Microsoft Windows Mobile 2003 for Pocket...
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
When turning on my monitor the Acer name appears then disappears and a box that reads "no signal" appears. Then the screen goes blank and the blue power button turns yellow.
This means that your monitor is not receiving a signal from your computer. The easiest way to fix this is to plug the monitor into the computer. I hope this helps and have a nice day!
May 03, 2011 | Acer Computers & Internet
Created a 300 picture slide show on my pc. the screen will go blank after 30 minutes and i have to hit the return key or touch the pad. Is this a sleep setting issue or kodak?
I suspect you have a screen saver set up that blanks the computer screen after 30 minutes.
If you are running Window XP, right-click your mouse on the desktop, choose Properties, from the Display Properties dialog, click the Screen Saver tab, then in the Wait box, increase the amount of time before the screen saver activates. Click the OK button when you are through.
Good luck,
-- SalParadise
Feb 28, 2011 | Cameras
The T3025 Emachines Recovery CDs (3 of them with date of 2003) apparently copy without error to the hard drive. It looks like the Symantec "Ghost" program does the copy process. After the...
what you need to do is disable first the 3.5" Floppy drive in your cmos/bios setup before reinstalling the windows operating system.
this will make the windows installation successful.
Feb 11, 2011 | Computers & Internet
Computer not booting up
This sound like you might have corrupted windows systems files. See if you can restart the PC using the last known configuration. You can do the by pressing the F8 key during the windows startup process.
Mar 24, 2009 | Computers & Internet
Monitor displays breifly then goes to blank screen
If tried the monitor on two other computers with the same result -- definitly your monitor is faulty. Take it to the repair shop. To make double sure, run your computer with another monitor. If everything is fine now; you can blame the monitor.
Dec 17, 2008 | Dell Dimension 4600 PC Desktop
Hello, My color isn't right on my computer. The box that pops up says "RGB no input signal". How can I fix this problem? Thanks Debbie
REMOVED THE 15 PIN PLUG - I GET A SCREEN MESSAGE - SYSTEM CABLE DISCONNECT! WHEN I PLUG IT BACK IN THE MESSAGE RGB NO INPUT SIGNAL APPEARS FOR A FEW SECONDS THEN THE MONITOR GOES INTO STANDBY AND THE SCREEN STAYS BLANK,
I ALSO PLUGGED THE MONITOR INTO MY LAPTOP AND THE SAME MESSAGE APPEARED
Nov 18, 2008 | Computers & Internet
Monitor won't stay on. Error message comes up that says "no input signal", then monitor goes out.
Problem with the monitor, monitor cable, or video output. For monitor, if you have more than one input, make sure it's set to the correct one. Try a different cable. Try a different monitor. Check your video card settings--if you see the BIOS bootup screen while it's coming up then the Windows splash screen, then monitor blanks out, it's a Windows display setting. Boot into safe mode, then change settings--
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected (the top option)
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would.
Oct 31, 2008 | HP Computers & Internet
Acer TFT screen 17" AL1715MS Flat Panel LCD Monitor Logo
52 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
