Question about Canon PIXMA MX330 Multifunction InkJet Color Printer
Clean Print Head Lines coming out in printed
Clean Print Head Lines coming out in printed materials.
  • 51 Answers
Hi as you have cleaned the heads the next step is to replace the print heads or some people claim that cleaning the heads with some expensive liquid works I have not had any luck with this.
so I would suggest you look up Canon PIXMA MX330 print head, on Amazon at about £47. so not cheep but very simple to fit
good luck
Ian
Posted on Mar 21, 2011
Lines wiggle canon mx310 printer
Open the printer where the cartridges are and clean the plastic material that is fixed at the print head. You can see the plastic attached to each side and the print head is running its length. It has thin lines or strokes on it. Clean it and see the results.
Sep 09, 2014 | Office Equipment & Supplies
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
How can you clean print heads for the HP C4480 All-In-One? "Best quality photos" prints well, but text has lines and smudge marks. Cleaned spongy material below cartridges but can't clean roller....
just take out the ink cartridge and clean off the bottom of it, that is the print head. you may need to clean under the plastic piece that it sits in. That may have hair or fuzz on it that is dragging across print.
Apr 08, 2011 | HP Photosmart C4480 All-In-One InkJet...
When I print pictures on my Kodak 5300 printer there are lines all through them. I have cleaned the print head two times, one after another and the lines are still there. What will remove the lines?
If they are white lines keep trying to clean the print head. If they are black lines you need to physically clean the bottom of the print heads with a damp cloth.
Feb 11, 2011 | Kodak EASYSHARE 5300 All-In-One InkJet...
Epson R230 printing unwanted lines
The problem is waste ink around head sprayer (at (bottom plate of head). Turn of printer. Move head to center. Put wet tissue (with hot water) at head cleaning mechanic pad. Move head to parking position. wait till 10 minutes. check it. You can repeat 3 times.
Jun 09, 2009 | Epson STYLUS R230 InkJet Photo Printer
Printing heads of my iP 90
Hi, I'm no expert, but I have this printer and I just had the same type of problem. My printed material had lines through the black ink which was nearly unreadable. After going over all of the steps that canon suggested with cleaning the print heads, I finally had to remove the print head and clean it manually. That helped alot. I also ordered a new genuine canon print head on ebay for $45.00, which is a good price for that.
Did you follow the instructions on the printer instructions for cleaning? Did you try deep cleaning? I'm not sure exactly what type of cleaning you are talking about. I can guide you through the steps, once I know what you need.
Connie
May 02, 2009 | Canon PIXMA iP90 Mobile Printer
Printed pages have white lines
Adjust the properties of your print mode the default is normal change it to best. the printing speed will change but the print quality will be good.
Apr 27, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Backlit print problem on Mimaki JV33
Hello Mimaki Backlit person,
I had a similar problem with an HP flatbed printer on backlit material. I corrected it (mostly) by lowering the print head to the sheet. Yeah, sounds crazy, and you might have to use a profile which uses less ink, but not only did it clean up the white areas, it sharpened the color edges. Even more important to have clean material and machinery, of course.
I would think that lowering the head would cause blurring and smears, but no. Also, the material I was using had been changed by our supplier, which explained why it worked great before and not now. Suppliers frequently swap items for cheaper material, even replacing one option with their cheaper choice, telling me "OH, it's the same thing."
Yeah, right. Good Luck!
Apr 07, 2009 | Office Equipment & Supplies
Hp photosmart 7960
For Photosmart 7960...
Hit MENU
Select "TOOLS" by hitting OK
Select "Clean Cartridges" by hitting OK
Carefully review printed output for white lines on printed areas
If white lines appear:
Select "SECOND level cleaning" by hitting OK
Select "THIRD level cleaning" by hitting OK.
Jan 17, 2008 | HP PhotoSmart 7960 InkJet Printer
Canon PIXMA MX330 Multifunction InkJet Color Printer Logo
246 people viewed this question
old marine
old marine
