Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Clutch won't engage on my craftsman model 971.271552. How can I adjust the clutch pedal so it will engage.
SOURCE: I have 16 hp Craftsman riding mower with a Kohler engine.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
Posted on Mar 12, 2009
  • 33 Answers
SOURCE: Clutch/Brake Pedal Problem
first off your biggest problem is its built by MTD.they build about 90% of the riding lawn mowers you see in the stores that are 20 horse and under,every thing from a yard machine to a craftsman to a cub cadet. you need to get under it and fallow the linkage from your pedal to your rear transaxle. that link is adjustable if it is not , then the arm it attaches to is .you need to adjust it whichever way takes slack out of the belt, if all the adjustment is out then replace the belt and adjust it accordingly
Posted on May 02, 2009
wadembly
  • 513 Answers
SOURCE: Craftsman LT 2000, model # 917.272234. When I am
what is happening tom is the blades are cutting more than the deck can discharge (spit out) try changing the mowing deck to a higher setting & try that if that works then that is the problem also try cleaning out the top & botton of deck there could be alot of old grass caught under there causing some of it aslo if i can further help e-mail me wade at wadembly@aol.com
Posted on Jun 28, 2009
  • 22 Answers
SOURCE: Blades won't engage when the engage knob is pulled
there is no adjustment drop deck all the way down spray all moving parts with wd40 mash clutch all the way down release quickly several times crank and try
Posted on Sep 02, 2009
mickey813
  • 472 Answers
SOURCE: Clutch wont engage on 80's model craftsman belt
SOUNDS LIKE YOUR TRANS IS WORE OUT IT MAY BE A BAD PULLEY
Posted on Oct 08, 2009
When shift lever is moved ouut of neutral mower takes off without using brake/clutch pedal pressing that pedal does no good craftsman 24 hp 42 inch cut
this should never happen. sounds like the belt is too tight as the pressing of the pedal should engage the drive train. Look for an adjustment being out or possibly a broken retractor spring. Be sure to pull spark plug wire while trouble shooting as you do not want to have the engine start.
Aug 01, 2017 | Craftsman Garden
Blades won'e engage
Your belt may be on wrong or slipping.
May 23, 2013 | Craftsman Garden
Craftsman lawn tractor parking brake won't engage
are you holding the lever while lifting your foot of the pedal?
Jun 27, 2012 | Garden
Craftsman Lawn Tractor 17hp 42 model 917.271662 auto trans idles and bucks when cutting grass
The symptom that you are feeling is that your transmission is not fully engaging correctly. Basically you have a few different things to try depending on the trans that is on your machine. Drain the fluid and re-install new fluid, adjust your brake/clutch to make sure that you are fully disengaged and fully engaged when you release the pedal. If none of those 2 cure your issue then you are looking at a trans rebuild or replacement
May 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a Craftsman lawn tractor model 917.288030. When you turn key to start nothing happens. Battery is ok. I have replaced ign switch. I have swaped selenoid with known good one. I have swaped out impact...
Hi and welcome to FixYa. I am Kelly.
Here are the 3 safety switches.
Seat
Clutch Brake
and PTO Clutch
More ofthen than not the PTO Clutch gets a gap greater than 0.020 between the clutch and the clutch plate and the safety switch is not made. There are 3 bolts with springs and 3 slots in the PTO clutch. Adjust the tension on the springs until the gap is 0.020. Then try a start.
If it does not work:
Check out this diagram.. it is for your mower:
http://c.searspartsdirect.com/lis_png/PLDM/P0905008-00011.png
I found your particular model here: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Riding-mower-tractor-Parts/Model-917288030/0247/1509200/P0905008/00011?blt=06&prst=0&shdMod=917288030
Parts can be located by choosing the diagrams under the small schematic. I think if you adjust the clutch you will be fine. The seat has to be occupied / switch shorted and the clutch brake pedal made to get power to the solenoid.
Respond ehre is you need more help.... Better yet let me know if the PTO clutch adjustment corrected the problem.
Thanks for choosing FixYa,
Kelly
Jun 05, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman riding mower Model 917.270824
I do not believe there is a manual available to the public for troubleshooting, however, you have at least 3 switches to tell the mower to stop when blades are engaged or clutch pedal released.
Seat switch
pedal switch
mower engage switch
The pedal and mower lever switches are identical, and have two sides, one for starting, one for blades turning. One side can fail. The pedal switch is on the frame very close to the pivot point of the pedal/shaft. The mower switch will be under the dash close to the bottom of the lever.
1) Locate and inspect the switches for broken or pinch wires, switch housing, or loose mounting, and how each lever or pedal engages the swtich.
2) This is a picture of the wiring so that you can get a better idea of location.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=917270824&productCategoryId=1509200&brandId=0247&modelName=TRACTOR&diagramPageId=00011&componentDescription=SCHEMATIC%20DIAGRAM-TRACTOR&documentId=P0811014&blt=06
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=917270824&productCategoryId=1509200&brandId=0247&modelName=TRACTOR&diagramPageId=00001&componentDescription=ELECTRICAL&documentId=P0811014&blt=06
Nov 11, 2009 | Craftsman Garden
I have rjdeing lawnmower with a BRIGGS&STRATTON 13.5 OHL WHEN YOU PUT IT IN GEAR AND ENGAGE THE BLADE IT LOSES POWER WQNT RUN. FAMLEY 4BSXS.3442VM 275943
if you mean that when you let off the clutch pedal and/or engage the blades, the engine dies, lift the seat and make sure the connector is firmly plugged into the switch attached to the seat.
Sep 28, 2009 | Briggs & Stratton Garden
Drive belt keep falling off
you have belt guides near your pulleys that helps to keep the belt on during no engagement
you need to check to see if they are missing or bent and adjust as close to the pulley and belt as possible without interfereing with the belt and pulleys while engaged.IE: no rubbing against the pulley or belt while engaged or moving.
May 31, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman model # 917.273064 won't stay running when clutch is re
You only have three saftey switches on your mower one on clutch pedal,one on deck engage,one on seat,be sure all are working you can check them by crossing the switches one by one .
May 08, 2009 | Garden
Apr 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
62 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
